    MAVSDK example program on VOXL 2 not running
    VOXL SDK
    • A
      achanana
      I am working with the Starling (QRB5165 VOXL 2 running sdk-1.2.0). I am trying to follow the voxl-docker-mavsdk-cpp tutorial to get the takeoff and land script to work.
      I was able to get the docker server running and pulled the MAVSDK image. However, I get the following error when trying to execute the takeoff and land script:
      root@m0054:/home/MAVSDK/examples/takeoff_land#  ./takeoff_and_land udp://:14551
      [03:15:33|Info ] MAVSDK version: 0.28.0 (mavsdk_impl.cpp:26)
      [03:15:33|Debug] New: System ID: 0 Comp ID: 0 (mavsdk_impl.cpp:377)
      Waiting to discover system...
      No system found, exiting.
      This is the output I got from voxl-inspect-services:
      voxl2:~$ voxl-inspect-services
      Scanning services...
       Service Name             |  Enabled  |   Running   |  CPU Usage
       docker-autorun           | Disabled  | Not Running |
       modallink-relink         | Disabled  | Not Running |
       voxl-camera-server       |  Enabled  |   Running   |    90.9%
       voxl-cpu-monitor         |  Enabled  |   Running   |     0.4%
       voxl-dfs-server          | Disabled  | Not Running |
       voxl-feature-tracker     | Disabled  | Not Running |
       voxl-flow-server         | Disabled  | Not Running |
       voxl-imu-server          |  Enabled  |   Running   |     3.8%
       voxl-lepton-server       | Disabled  | Not Running |
       voxl-mapper              | Disabled  | Not Running |
       voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
       voxl-mavlink-server      |  Enabled  |   Running   |     2.6%
       voxl-modem               | Disabled  | Not Running |
       voxl-neopixel-manager    | Disabled  | Not Running |
       voxl-open-vins-server    | Disabled  | Not Running |
       voxl-portal              |  Enabled  |   Running   |     0.7%
       voxl-px4-imu-server      |  Enabled  | Not Running |
       voxl-px4                 |  Enabled  |   Running   |    24.6%
       voxl-qvio-server         |  Enabled  |   Running   |    34.3%
       voxl-rangefinder-server  | Disabled  | Not Running |
       voxl-remote-id           | Disabled  | Not Running |
       voxl-softap              |  Enabled  |  Completed  |
       voxl-static-ip           | Disabled  | Not Running |
       voxl-streamer            |  Enabled  |   Running   |     0.0%
       voxl-tag-detector        | Disabled  | Not Running |
       voxl-tflite-server       |  Enabled  |   Running   |     3.1%
       voxl-time-sync           | Disabled  | Not Running |
       voxl-uvc-server          | Disabled  | Not Running |
       voxl-vision-hub          |  Enabled  |   Running   |     2.6%
       voxl-wait-for-fs         |  Enabled  |  Completed  |
      Do you have any idea what might be the issue here? Should voxl-px4-imu-server be running? Could that be the issue?
      Thanks for your help!
      • ModeratorM
        Moderator ModalAI Team
        @achanana said in MAVSDK example program on VOXL 2 not running:
        voxl-px4-imu-server
        is for the Qualcomm Flight RB5 architecture and is not relevant to Starling
        It is likely your voxl-mavlink-server is not configured properly. MAVSDK communicates with the port opened up in voxl-mavlink-server
