    RTSP Streaming (to QGC on Android) issues on VOXL Mini
    VOXL 2 Mini
    1832
    • A
      AndriiHlyvko
      Hi, I seem to have issues with streaming rtsp video from voxl mini to QGC on an Android tablet. Initially when I connect from QGC I see the video feed but when I close out QGC and try to open the video stream again I don't see any video. Previously I have been using the same configuration to stream from the VOXL2 and I haven't seen this problem. I tried installing different versions of the voxl-streamer on the mini but it did not help. I am running SDK version 1.1.2 on the Mini. Has anyone seen this problem before?
      Thanks.
        Alex Kushleyev ModalAI Team @AndriiHlyvko
        @AndriiHlyvko , can you please run the voxl-streamer in foreground (you can stop the background service using systemctl stop voxl-streamer), run it from command line and see if it outputs any useful information during your QGC connection / disconnection? also, i believe there is a debug mode (-v 0) which may give you more information.
        A 2 Replies Last reply Reply Quote 0
        • A
          AndriiHlyvko @Alex Kushleyev
          @Alex-Kushleyev I ran voxl-streamer in verbose mode in two cases: when I got the video and when I didn't. The voxl-streamer output was the same in both cases (only the port was different). I didn't see any errors either.
          anyways here is the output:
          voxl2-mini:/$ voxl-streamer -v 0
          DEBUG:   Using input:     hires_small_encoded
          DEBUG:   Using RTSP port: 8900
          DEBUG:   Using bitrate:   1000000
          DEBUG:   Using decimator: 1
          Waiting for pipe hires_small_encoded to appear
          Found Pipe
          detected following stats from pipe:
          w: 1024 h: 768 fps: 15 format: H265
          DEBUG:   Frame rate is: 15
          DEBUG:   Made rtsp_server
          DEBUG:   Created RTSP server main loop context
          DEBUG:   Created RTSP server main loop source for callback
          DEBUG:   Created timeout loop source for callback
          DEBUG:   Got 3 from gst_rtsp_server_attach
          Stream available at rtsp://127.0.0.1:8900/live
          A new client rtsp://192.168.168.10:52296(null) has connected, total clients: 1
          Camera server Connected
          DEBUG:   Meta data from incoming frame:
          DEBUG:          magic_number 0x564F584C
          DEBUG:          timestamp_ns: 95891853324
          DEBUG:          frame_id: -1
          DEBUG:          width: 1024
          DEBUG:          height: 768
          DEBUG:          size_bytes: 77
          DEBUG:          stride: 1024
          DEBUG:          exposure_ns: 270328
          DEBUG:          gain: 54
          DEBUG:          format: 4
          DEBUG:   Saving h265 SPS
          DEBUG:   Creating media pipeline for RTSP client
          DEBUG:   Made empty pipeline
          DEBUG:   Made test_source
          DEBUG:   Made test_caps_filter
          DEBUG:   Made overlay_queue
          DEBUG:   Made image_overlay
          DEBUG:   Made scaler_queue
          DEBUG:   Made scaler
          DEBUG:   Made converter_queue
          DEBUG:   Made video_converter
          DEBUG:   Made rotator_queue
          DEBUG:   Made video_rotate
          DEBUG:   Made video_rotate_filter
          DEBUG:   Made app_source
          DEBUG:   Made app_source_filter
          DEBUG:   Made encoder_queue
          DEBUG:   Made omx_encoder
          DEBUG:   Made omx_h265_encoder
          DEBUG:   Made h264_parser
          DEBUG:   Made h265_parser
          DEBUG:   Made rtp_filter
          DEBUG:   Made rtp_queue
          DEBUG:   Made rtp_payload
          DEBUG:   Made rtp_h265_payload
          VERBOSE: *** Start feeding ***
          DEBUG:   SPS accepted
          VERBOSE: Frame 1 accepted
          VERBOSE: Frame 2 accepted
          • A
            @Alex-Kushleyev I am pretty confident right now that this issue is not a modalai issue but a QGC issue. I tried using VLC on Android and it works fine every time but whenever I switch into QGC is when I see the problem.
              @AndriiHlyvko , hmm.. interesting! I am not sure what to suggest, i don't think we have seen this issue. If the RTSP stream is working via VLC, it should also work in QGC.. Both VOXL2 and VOXL2 mini can run the same VOXL2 SDK version (though not exactly the same kernel and a few other things, hence different sdk release files), so essentially the same version of voxl-camera-server, voxl-streamer, voxl-px4, etc.
              • VinnyV
                Vinny ModalAI Team @Alex Kushleyev
                @AndriiHlyvko @Alex-Kushleyev
                Are you using USB-C for this connection?
                Voxl2 Mini differs from Voxl 2 in that USB-C cable lengths need to be shorter on V2 Mini compared to Voxl 2.
                Voxl 2 uses a re-driver IC to boost the signals on USB-C, whereas to keep V2 Mini small, we removed that part.
                So, not sure if that is a factor or not, but maybe try using a shorter USB-C cable on V2 Mini.
                I have heard of several folks (even internally) that use very long USB-C cables on Voxl 2, then when they try Voxl 2 mini, they forget to use a shorter cable, and some things with USB communications start to fail randomly.
                Give it a shot. Not sure if one mode or another for your stream tries to use faster speeds, but that can possibly explain it.
                • A
                  AndriiHlyvko @Vinny
                  @Vinny and @Alex-Kushleyev I've narrowed down what the exact problem is. Apparently QGC is not good with H265 video streaming. Once I set the encoding to H264 in voxl-camera config file the video streaming works well. Also FYI I am using microhard radio for the voxl to QGC connection.
                    @AndriiHlyvko , thank you for following up with your solution!
