  3. RTSP Streaming (to QGC on Android) issues on VOXL Mini
voxl-2-mini
8 Posts 3 Posters 2.3k Views 2 Watching
  • A Offline
    AndriiHlyvko
    wrote on last edited by AndriiHlyvko
    Hi, I seem to have issues with streaming rtsp video from voxl mini to QGC on an Android tablet. Initially when I connect from QGC I see the video feed but when I close out QGC and try to open the video stream again I don't see any video. Previously I have been using the same configuration to stream from the VOXL2 and I haven't seen this problem. I tried installing different versions of the voxl-streamer on the mini but it did not help. I am running SDK version 1.1.2 on the Mini. Has anyone seen this problem before?
    Thanks.
    • A AndriiHlyvko
      Thanks.
      @AndriiHlyvko , can you please run the voxl-streamer in foreground (you can stop the background service using systemctl stop voxl-streamer), run it from command line and see if it outputs any useful information during your QGC connection / disconnection? also, i believe there is a debug mode (-v 0) which may give you more information.
      A 2 Replies Last reply
        AndriiHlyvko
        @Alex-Kushleyev I ran voxl-streamer in verbose mode in two cases: when I got the video and when I didn't. The voxl-streamer output was the same in both cases (only the port was different). I didn't see any errors either.
        anyways here is the output:
        voxl2-mini:/$ voxl-streamer -v 0
        DEBUG:   Using input:     hires_small_encoded
        DEBUG:   Using RTSP port: 8900
        DEBUG:   Using bitrate:   1000000
        DEBUG:   Using decimator: 1
        Waiting for pipe hires_small_encoded to appear
        Found Pipe
        detected following stats from pipe:
        w: 1024 h: 768 fps: 15 format: H265
        DEBUG:   Frame rate is: 15
        DEBUG:   Made rtsp_server
        DEBUG:   Created RTSP server main loop context
        DEBUG:   Created RTSP server main loop source for callback
        DEBUG:   Created timeout loop source for callback
        DEBUG:   Got 3 from gst_rtsp_server_attach
        Stream available at rtsp://127.0.0.1:8900/live
        A new client rtsp://192.168.168.10:52296(null) has connected, total clients: 1
        Camera server Connected
        DEBUG:   Meta data from incoming frame:
        DEBUG:          magic_number 0x564F584C
        DEBUG:          timestamp_ns: 95891853324
        DEBUG:          frame_id: -1
        DEBUG:          width: 1024
        DEBUG:          height: 768
        DEBUG:          size_bytes: 77
        DEBUG:          stride: 1024
        DEBUG:          exposure_ns: 270328
        DEBUG:          gain: 54
        DEBUG:          format: 4
        DEBUG:   Saving h265 SPS
        DEBUG:   Creating media pipeline for RTSP client
        DEBUG:   Made empty pipeline
        DEBUG:   Made test_source
        DEBUG:   Made test_caps_filter
        DEBUG:   Made overlay_queue
        DEBUG:   Made image_overlay
        DEBUG:   Made scaler_queue
        DEBUG:   Made scaler
        DEBUG:   Made converter_queue
        DEBUG:   Made video_converter
        DEBUG:   Made rotator_queue
        DEBUG:   Made video_rotate
        DEBUG:   Made video_rotate_filter
        DEBUG:   Made app_source
        DEBUG:   Made app_source_filter
        DEBUG:   Made encoder_queue
        DEBUG:   Made omx_encoder
        DEBUG:   Made omx_h265_encoder
        DEBUG:   Made h264_parser
        DEBUG:   Made h265_parser
        DEBUG:   Made rtp_filter
        DEBUG:   Made rtp_queue
        DEBUG:   Made rtp_payload
        DEBUG:   Made rtp_h265_payload
        VERBOSE: *** Start feeding ***
        DEBUG:   SPS accepted
        VERBOSE: Frame 1 accepted
        VERBOSE: Frame 2 accepted
          AndriiHlyvko
          @Alex-Kushleyev I am pretty confident right now that this issue is not a modalai issue but a QGC issue. I tried using VLC on Android and it works fine every time but whenever I switch into QGC is when I see the problem.
          • A AndriiHlyvko
            @AndriiHlyvko , hmm.. interesting! I am not sure what to suggest, i don't think we have seen this issue. If the RTSP stream is working via VLC, it should also work in QGC.. Both VOXL2 and VOXL2 mini can run the same VOXL2 SDK version (though not exactly the same kernel and a few other things, hence different sdk release files), so essentially the same version of voxl-camera-server, voxl-streamer, voxl-px4, etc.
            VinnyV 1 Reply Last reply
              @AndriiHlyvko @Alex-Kushleyev
              Are you using USB-C for this connection?
              Voxl2 Mini differs from Voxl 2 in that USB-C cable lengths need to be shorter on V2 Mini compared to Voxl 2.
              Voxl 2 uses a re-driver IC to boost the signals on USB-C, whereas to keep V2 Mini small, we removed that part.
              So, not sure if that is a factor or not, but maybe try using a shorter USB-C cable on V2 Mini.
              I have heard of several folks (even internally) that use very long USB-C cables on Voxl 2, then when they try Voxl 2 mini, they forget to use a shorter cable, and some things with USB communications start to fail randomly.
              Give it a shot. Not sure if one mode or another for your stream tries to use faster speeds, but that can possibly explain it.
              A 1 Reply Last reply
              • VinnyV Vinny
                AndriiHlyvko
                @Vinny and @Alex-Kushleyev I've narrowed down what the exact problem is. Apparently QGC is not good with H265 video streaming. Once I set the encoding to H264 in voxl-camera config file the video streaming works well. Also FYI I am using microhard radio for the voxl to QGC connection.
                • A AndriiHlyvko
                  @AndriiHlyvko , thank you for following up with your solution!
