  2. VOXL Dev Kits
  3. VOXL Flight Deck
  4. ekf2 problem
ekf2 problem
Scheduled Pinned Locked Moved VOXL Flight Deck
8 Posts 3 Posters 1.7k Views 3 Watching
  • Z Offline
    Z Offline
    znn
    Hi, I have an error with ekf2.
    The local position data status is invalid.
    I'm using PX4 version 1.11.
    Does modified library with changes is necessary?
      @znn ,
      Are you using the ModalAI PX4 "1.11.3-0.0.5" ? https://docs.modalai.com/flight-core-firmware/#v111-change-log
      Or from PX4 mainline?
      Z 2 Replies Last reply
      • modaltbM modaltb
        @znn ,
        Z Offline
        Z Offline
        znn
        @modaltb From PX4 mainline.
        I used Qgroundcontrol and select the current stable release.
        • modaltbM modaltb
          @znn ,
          Z Offline
          Z Offline
          znn
          wrote on last edited by znn
          @modaltb I think the basic problem is on the internet.
          I tried
          • opkg install voxl-suite
          and I got opkg_download_backend fail error
          and with the following command
          • ping www.modalai.com
          the error comes up.
          Is the ekf2 problem related to this internet problem?
          In some forum pages, the microhard radio has to be disable but i'm not using microhard.
          Is there something i can do?
          Here some additional info about VOXL.
          Z Eric KatzfeyE 2 Replies Last reply
          • Z znn
            I tried
            the error comes up.
            Z Offline
            Z Offline
            znn
            @znn
            • Z znn
              I tried
              the error comes up.
              @znn This looks like you are in "soft ap" mode on wifi. You need to be in station mode on wifi in order to get access to the network. https://docs.modalai.com/wifi-setup/#configure-station-mode
                Z Offline
                Z Offline
                znn
                @Eric-Katzfey Thanks, but i've been tried with station mode so far. I'll check again.
                I think the RX part in wlan0 should not be zero, right?
                Thank you for the reply.
                  Z Offline
                  Z Offline
                  znn
                  @Eric-Katzfey The main cause was system image version. The internet problem has solved!
                  now i'll try again the QGC setup.
                  Thanks a lot.
