    ekf2 problem
    VOXL Flight Deck
    473
    • Z
      znn
      Hi, I have an error with ekf2.
      The local position data status is invalid.
      I'm using PX4 version 1.11.
      Does modified library with changes is necessary?
      • modaltbM
        modaltb ModalAI Team
        @znn ,
        Are you using the ModalAI PX4 "1.11.3-0.0.5" ? https://docs.modalai.com/flight-core-firmware/#v111-change-log
        Or from PX4 mainline?
        Z 2 Replies Last reply Reply Quote 0
        • Z
          znn @modaltb
          @modaltb From PX4 mainline.
          I used Qgroundcontrol and select the current stable release.
          • Z
            znn @modaltb
            @modaltb I think the basic problem is on the internet.
            I tried
            • opkg install voxl-suite
            and I got opkg_download_backend fail error
            and with the following command
            • ping www.modalai.com
            the error comes up.
            Is the ekf2 problem related to this internet problem?
            In some forum pages, the microhard radio has to be disable but i'm not using microhard.
            Is there something i can do?
            Here some additional info about VOXL.
            Z Eric KatzfeyE 2 Replies Last reply Reply Quote 0
            • Z
              znn @znn
              @znn
                Eric Katzfey ModalAI Team @znn
                @znn This looks like you are in "soft ap" mode on wifi. You need to be in station mode on wifi in order to get access to the network. https://docs.modalai.com/wifi-setup/#configure-station-mode
                • Z
                  znn @Eric Katzfey
                  @Eric-Katzfey Thanks, but i've been tried with station mode so far. I'll check again.
                  I think the RX part in wlan0 should not be zero, right?
                  Thank you for the reply.
                  • Z
                    znn @Eric Katzfey
                    @Eric-Katzfey The main cause was system image version. The internet problem has solved!
                    now i'll try again the QGC setup.
                    Thanks a lot.
