  3. Flying multiple RB5s
8 Posts 2 Posters 1.5k Views
  • T Offline
    T Offline
    tahawaru
    I want to fly more than ONE RB5(https://docs.modalai.com/qualcommflightrb5/) using 1 single laptop running Ubuntu 22.04.
    I'm using MAVSDK-python.
    My understanding at the moment is that the only the port 14550 is working.
    The examples given in https://github.com/mavlink/MAVSDK-Python or https://github.com/julianblanco/MAVFleetControl work for a single drone but not for more than 1.
    Any help on this topic?
    Best wishes,
    Massa
    ModeratorM 1 Reply Last reply
    • T tahawaru
      Best wishes,
      Massa
      Please see the documentation for mavlink routing here: https://docs.modalai.com/mavlink/#mavlink-routing-on-voxl
      It shows how to configure the IP and port
      T 1 Reply Last reply
      • ModeratorM Moderator
        T Offline
        T Offline
        tahawaru
        @Moderator
        "Up to 16 simultaneous external UDP connections can be established with voxl-mavlink-server. These can be connections to qGroundControl, MAVROS, MAVSDK, or any custom software on the same network as VOXL. voxl-mavlink-server listens for mavlink heartbeats on the standard mavlink port 14550 and opens a new link when it receives a heartbeat from a new IP. Each link receives all mavlink data coming from the autopilot and any messages received on the UDP port will be forwarded to the autopilot."
        Do you have a sample code to implement the UDP connections? or a reference for implementation?
        Can we change the port 14550 or add new ones? if yes, how?
        Best wishes,
        ModeratorM 2 Replies Last reply
        • T tahawaru
          @Moderator
          Best wishes,
          • T tahawaru
            @Moderator
            Best wishes,
            @tahawaru you'll need to change the code here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mavlink-server/-/blob/master/src/gcs_io.c?ref_type=heads#L59
            if you consider making this a parameter, we are always open to merge requests!
              T Offline
              T Offline
              tahawaru
              @Moderator
              1)
              I want to change line 59 on the file gcs_io.c only like this
              #define GCS_UDP_PORT 14552 // default in QGC
              then build the voxl-mavlink-server, replace voxl-mavlink-server_1.3.2_arm64.deb by the generated .deb file to the voxl sdk.
              Then flash 1 rb5 with it to test if it works.
              is this approach valid?
              I have cloned and opened the voxl-mavlink-server (from the link you've sent me above) with Visual Studio Code.
              I get the following error:
              cannot open source file "c_library_v2/common/mavlink.h" (dependency of "gcs_io.h")
              Could you help on this?
              Best wishes,
              • T tahawaru
                @Moderator
                1)
                Best wishes,
                @tahawaru did you follow the build instructions in the README?
                  T Offline
                  T Offline
                  tahawaru
                  @Moderator
                  I have followed the build instructions and got the voxl-mavlink-server built.
                  I'm currently testing it with different ports (other than 14550).
                  Thank you for your support.
