    Flying multiple RB5s
    1192
    • T
      tahawaru
      I want to fly more than ONE RB5(https://docs.modalai.com/qualcommflightrb5/) using 1 single laptop running Ubuntu 22.04.
      I'm using MAVSDK-python.
      My understanding at the moment is that the only the port 14550 is working.
      The examples given in https://github.com/mavlink/MAVSDK-Python or https://github.com/julianblanco/MAVFleetControl work for a single drone but not for more than 1.
      Any help on this topic?
      Best wishes,
      Massa
      • ModeratorM
        Moderator ModalAI Team @tahawaru
        Please see the documentation for mavlink routing here: https://docs.modalai.com/mavlink/#mavlink-routing-on-voxl
        It shows how to configure the IP and port
        T 1 Reply Last reply Reply Quote 0
        • T
          tahawaru @Moderator
          @Moderator
          "Up to 16 simultaneous external UDP connections can be established with voxl-mavlink-server. These can be connections to qGroundControl, MAVROS, MAVSDK, or any custom software on the same network as VOXL. voxl-mavlink-server listens for mavlink heartbeats on the standard mavlink port 14550 and opens a new link when it receives a heartbeat from a new IP. Each link receives all mavlink data coming from the autopilot and any messages received on the UDP port will be forwarded to the autopilot."
          Do you have a sample code to implement the UDP connections? or a reference for implementation?
          Can we change the port 14550 or add new ones? if yes, how?
          Best wishes,
          ModeratorM 2 Replies Last reply Reply Quote 0
          • ModeratorM
            • ModeratorM
              @tahawaru you'll need to change the code here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mavlink-server/-/blob/master/src/gcs_io.c?ref_type=heads#L59
              if you consider making this a parameter, we are always open to merge requests!
              • T
                tahawaru @Moderator
                @Moderator
                1)
                I want to change line 59 on the file gcs_io.c only like this
                #define GCS_UDP_PORT 14552 // default in QGC
                then build the voxl-mavlink-server, replace voxl-mavlink-server_1.3.2_arm64.deb by the generated .deb file to the voxl sdk.
                Then flash 1 rb5 with it to test if it works.
                is this approach valid?
                I have cloned and opened the voxl-mavlink-server (from the link you've sent me above) with Visual Studio Code.
                I get the following error:
                cannot open source file "c_library_v2/common/mavlink.h" (dependency of "gcs_io.h")
                Could you help on this?
                Best wishes,
                • ModeratorM
                  @tahawaru did you follow the build instructions in the README?
                  • T
                    tahawaru @Moderator
                    @Moderator
                    I have followed the build instructions and got the voxl-mavlink-server built.
                    I'm currently testing it with different ports (other than 14550).
                    Thank you for your support.
