  3. Attempting to get the motors spinning with no luck
3 Posts 2 Posters 512 Views 1 Watching
  • M Offline
    M Offline
    mascenzi
    Hello, I'll keep it simple. I'm just attempting to get the motors spinning at this point. Here is what I have and what I'm seeing.
    Hardware:
    As you can see from the wiring this is my component list
    • Voxl2
    • 4in1 ESC
    • Expander Board
    • Power Module
    • USB Expansion
    • USB adapter for Wifi antenna
    • Four T-Motor F90 motors
    Software:
    • QGroundControl Version 4.3
    • Voxl
      • System-image 1.7.1
      • Kernel 4.19.125
      • hw version m0054
      • voxl-suite 1.1.0
      • Packages
        • voxl-px4 1.14.0-2.0.55
    If you need any other version information, let me know and I'll update the OP.
    I believe I have the VOXL2 configured for proper communication. If I run voxl-inspect-services, the following services are active.
    • voxl-cpu-monitor Enabled Running
    • voxl-imu-server Enabled Running
    • voxl-mavlink-server Enabled Running
    • voxl-portal Enabled Running
    • voxl-px4 Enabled Running
    • voxl-softap Enabled Running
    • voxl-vision-hub Enabled Running
    • voxl-wait-for-fs Enabled Running
    When I run voxl-inspect-mavlink mavlink_to_gcs I see heartbeat and other informations update rates.
    QGroundControl:
    • Airframe - Quadrotor x
    • Vehicle - Generic Quadcopter
    • Firmware v. - 1.14.0
    • CustomerFW ver. - 2.0.55
    • Sensors:
      * Gryo - Check
      * Accelerometer - Check
      * Level Horizon - Check
      * Compas - Failed: No Mags found
    • Actuators Setup
      * Configuration - VOXL ESC
    I've worked through the Voxl Dev Bootcamp. I've also used the following links for reference.
    Modalai: Using VOXL ESCs with PX4
    PXF: Modalai VOXL 2
    Any help would be much appreciated.
    • M mascenzi
      Hardware:
      • Voxl2
      • 4in1 ESC
      • Expander Board
      • Power Module
      • USB Expansion
      Software:
      • Voxl
        • Kernel 4.19.125
        • hw version m0054
        • voxl-suite 1.1.0
        • Packages
      QGroundControl:
      • Sensors:
        * Gryo - Check
      • Actuators Setup
      PXF: Modalai VOXL 2
      @mascenzi , with ModalAI ESC you don't need the M0065 expander. You need to connect the ESC J2 (6-pin Hirose connector) to VOXL2 J18 (4-pin JST GH) using MCBL-00029 : https://www.modalai.com/collections/cables-1/products/mcbl-00029 . Communication between ESC and Voxl2 will happen using UART.
      M 1 Reply Last reply
        M Offline
        M Offline
        mascenzi
        @Alex-Kushleyev thank you so much for reaching out with support. I had to tear down the voxl2 setup and build out a pixhawk unit so I could complete thrust testing for our initial frame design. I will get the voxl2 model back up and running and test out your configuration. I actually don't think we have that cable. I'll have to put in order in for it. I'll post back with verification once I have the result.
