  3. VOXL/VOXL2 Power Module Query
2 Posts 2 Posters 646 Views 1 Watching
  • R Offline
    R Offline
    rohitpillai
    I am curious to know why there are 2x XT60 connectors on the Power module. Can either the Male or Female end of the connector be used to power the VOXL/VOXL2? Or should we only use the Male connector (the connector that connects to the wall power supply)?
    VinnyV 1 Reply Last reply
    • R rohitpillai
      VinnyV Online
      VinnyV Online
      Vinny
      Hi @rohitpillai
      The intent of the power module is to take direct 2S-6S battery via the XT-60-M, and then pass that power input to two places:
      1. a 5V DC/DC for VOXL / VOXL 2 using the Molex 4-pin with MCBL-00001 (https://docs.modalai.com/cable-datasheets/#mcbl-00001), not the XT-60
      2. Output using the XT-60-F to an ESC/Other VBAT based item in your platform.
      Both are measured by the sense resistor when connected properly as we instruct.
      In some instances, as in the case of a VOXL 2 Mini, we have configured the Power Module to not output a downstream VBAT using the XT60-F (https://docs.modalai.com/voxl2-mini-power/#voxl-power-module), but a user is easily able to do so.
      Hope this helps!
