  3. Supporting Tattu Pro Battery via UAVCAN Integration
flight-core-v2
11 Posts 3 Posters 3.1k Views 1 Watching
  • W Offline
    W Offline
    Will
    I am linking the CAN interface of the Tattu Pro Battery ((https://genstattu.com/tattu-pro-22000mah-44-4v-25c-12s-1p-lipo-smart-battery-pack-with-as150u-f-plug/)) to the J8 connector and compiling version v1.14.0-2.0.64-dev with the specified configuration enabled:
    CONFIG_DRIVERS_UAVCAN=y
    CONFIG_BOARD_UAVCAN_INTERFACES=1
    CONFIG_BOARD_UAVCAN_TIMER_OVERRIDE=2
    Here is the version information for the board and firmware
    nsh> ver all
    HW arch: MODALAI_FC_V2
    HW type: V2003000
    HW version: 0x003
    HW revision: 0x000
    PX4 git-hash: 996e85e9360801dd9ec11b7149a524e38231dcc6
    PX4 version: 1.14.0 0 (17694720)
    Vendor version: 2.0.64 0 (33570816)
    OS: NuttX
    OS version: Release 11.0.0 (184549631)
    OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
    Build datetime: Dec 26 2023 12:23:55
    Build uri: localhost
    Build variant: default
    Toolchain: GNU GCC, 9.3.1 20200408 (release)
    PX4GUID: 0006000000003333363031315105003a001c
    MCU: STM32H7[4|5]xxx, rev. V
    Below is the error indicating the issue where I am unable to retrieve battery information:
    nsh> uavcan
    INFO  [uavcan] usage:
        uavcan {start|status|stop|shrink|update}
                param [set|get|list|save] <node-id> <name> <value>|r
    nsh> uavcan start
    INFO  [uavcan] already started
    nsh> uavcan status
    Pool allocator status:
        Capacity hard/soft: 500/250 blocks
        Reserved:  13 blocks
        Allocated: 10 blocks
    UAVCAN node status:
        Internal failures: 0
        Transfer errors:   0
        RX transfers:      0
        TX transfers:      6922
    CAN1 status:
        HW errors: 2476
        IO errors: 2476
        RX frames: 10302
        TX frames: 8289
    ESC outputs:
    INFO  [mixer_module] Param prefix: UAVCAN_EC
    control latency: 0 events, 0us elapsed, 0.00us avg, min 0us max 0us 0.000us rms
    Channel Configuration:
    Channel 0: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Channel 1: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Channel 2: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Channel 3: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Channel 4: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Channel 5: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Channel 6: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Channel 7: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
    Servo outputs:
    INFO  [mixer_module] Param prefix: UAVCAN_SV
    Channel 0: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Channel 1: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Channel 2: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Channel 3: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Channel 4: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Channel 5: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Channel 6: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Channel 7: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
    Sensor 'gnss':
    Sensor 'mag':
    Online nodes (Node ID, Health, Mode):
    uavcan: cycle time: 163407 events, 2350932us elapsed, 14.39us avg, min 6us max 709us 21.106us rms
    uavcan: cycle interval: 163407 events, 2814.40us avg, min 15us max 4373us 624.775us rms
    nsh>
    nsh> uavcan param list 107
    Failed to get param: -1
    Here is an example from the Tattu Pro document. However, I am unable to achieve the same result. Please assist in checking if I have missed anything to enable UAVCAN. Thanks.
    • ModeratorM Offline
      We do not have any experience with that product. Have you asked on the PX4 forums?
      W 1 Reply Last reply
      • ModeratorM Moderator
        W Offline
        W Offline
        Will
        @Moderator , I've observed a mention on the provided web address that states, "CAN “Silent” pin (STBY) is controlled by STM32 PD15 pin (default pulled-LOW in hardware)", does this imply that I need to set PD15 to a high level to enable the CAN bus? If so, could you please provide instructions on configuring PD15 on FCv2? Thank you.
        https://docs.modalai.com/flight-core-v2-datasheets-connectors/
        • W Will
          W Offline
          W Offline
          Will
          @Moderator , I mistakenly connected the PC USB port to FCv2 J8 (CAN bus) instead of J3. Could this potentially cause damage to the board? Currently, QGC cannot establish a connection to FCv2 through the serial port, and the PC fails to recognize any ttyUSBx port. Interestingly, I am still able to use STLink to connect to FCv2 via J2. When I connect J3 to the PC, the LED initially blinks green for a few seconds and then switches to green and white intermittently. Despite this, the USB port is not recognized by the PC. I would appreciate your assistance in troubleshooting this issue. Thank you.
          W VinnyV 2 Replies Last reply
          • W Will
            W Offline
            W Offline
            Will
            @Moderator , Here is the PX4 system console log. Could you please assist in examining why the J3 USB connector is not functioning? Thank you.
            [boot] Rev 0x0 : Ver 0x3 V230
            [boot] Fault Log info File No 4 Length 3177 flags:0x01 state:1
            [boot] Fault Log is Armed
            sercon: Registering CDC/ACM serial driver
            sercon: Successfully registered the CDC/ACM serial driver
            ERROR [PX4_MTD] failed to initialize mtd driver
            ERROR [PX4_MTD] mtd failure[hardfault_log] Fault Log is Armed
            : -5 bus 2 address 0 class 1
            HW type: V230
            HW version: 0x00000003
            HW revision: 0x00000000
            FW git-hash: 259b3c097773507e581e2930093e4958f7726381
            FW version: Release 1.13.2 (17629951)
            FW git-branch: modalai-1.13.2
            OS: NuttX
            OS git-hash: 91bece51afbe7da9db12e3695cdbb4f4bba4bc83
            Build datetime: Dec  8 2023 23:35:12
            INFO  [param] selected parameter default file /fs/microsd/params
            INFO  [param] importing from '/fs/microsd/params'
            INFO  [parameters] BSON document size 1752 bytes, decoded 1752 bytes (INT32:40, FLOAT:46)
            INFO  [param] selected parameter backup file /fs/microsd/parameters_backup.bson
            Board architecture defaults: /etc/init.d/rc.board_arch_defaults
            Board defaults: /etc/init.d/rc.board_defaults
            nsh: tone_alarm: command not found
            INFO  [dataman] data manager file '/fs/microsd/dataman' size is 62560 bytes
            Loading airframe: /etc/init.d/airframes/4015_holybro_s500
            INFO  [uavcan] Node ID 1, bitrate 1000000
            Board sensors: /etc/init.d/rc.board_sensors
            INFO  [voxlpm] Failed to init voxlpm type: 0 on bus: 3, but will try again periodically.
            voxlpm #0 on I2C bus 3 (external) address 0x44
            WARN  [SPI_I2C] Already running on bus 3
            WARN  [SPI_I2C] voxlpm: no instance started (no device on bus?)
            icm42688p #0 on SPI bus 1 rotation 12
            icm42688p #1 on SPI bus 2 rotation 12
            icp20100 #0 on I2C bus 4 (external) address 0x63
            INFO  [init] Mixer: /etc/mixers/quad_x.main.mix on /dev/uavcan/esc
            INFO  [init] setting PWM_AUX_OUT none
            ekf2 [670:237]
            Starting Main GPS on /dev/ttyS0
            Starting MAVLink on /dev/ttyS6
            INFO  [mavlink] mode: Onboard, data rate: 46080 B/s on /dev/ttyS6 @ 921600B
            WARN  [mavlink] stream SCALED_PRESSURE not found
            ERROR [mavlink] configure_streams_to_default() failed
            Addons script: /fs/microsd/etc/extras.txt
            nsh: BMP388: command not found
            INFO  [logger] logger started (mode=all)
            NuttShell (NSH) NuttX-11.0.0
            • W Will
              HW type: V230
              OS: NuttX
              ekf2 [670:237]
              W Offline
              W Offline
              Will
              wrote on last edited by Will
              @Moderator , the board is currently operational somehow. I made adjustments to the code, setting PD15 to a high level and modifying the parameters of UAVCAN_SUB_BAT to 1 and UAVCAN_ENABLE to 2 or 3, following the guidelines on this page (https://docs.px4.io/v1.12/zh/uavcan/pomegranate_systems_pm.html). Despite these modifications, I am still unable to retrieve battery information. I will also explore the PX4 forum for potential solutions. However, if you have additional suggestions, please feel free to share. Thank you.
              diff --git a/boards/modalai/fc-v2/src/board_config.h b/boards/modalai/fc-v2/src/board_config.h
              index 987f692b22..e7a7c83ef7 100644
              --- a/boards/modalai/fc-v2/src/board_config.h
              +++ b/boards/modalai/fc-v2/src/board_config.h
              @@ -213,6 +213,7 @@
               /* Spare GPIO */
               #define CAN1_SILENT                       /* PD15 */  (GPIO_OUTPUT|GPIO_PUSHPULL|GPIO_SPEED_2MHz|GPIO_OUTPUT_CLEAR|GPIO_PORTD|GPIO_PIN15)
              +#define CAN1_SILENT_PULL_HIGH()  px4_arch_gpiowrite(CAN1_SILENT, 1)
               /* For primary/backup signaling with VOXL, 2 pins on J4 are exposed */
               // GPIO_VOXL_STATUS_OUT/ GPIO_VOXL_STATUS_IN are for v1 Spare MSS Communications Interface and J4 tests
              diff --git a/boards/modalai/fc-v2/src/init.c b/boards/modalai/fc-v2/src/init.c
              index dbc6ec4637..55ad6aab6c 100644
              --- a/boards/modalai/fc-v2/src/init.c
              +++ b/boards/modalai/fc-v2/src/init.c
              @@ -211,6 +211,8 @@ __EXPORT int board_app_initialize(uintptr_t arg)
                      /* Power on Interfaces */
                      board_spi_reset(10, 0xffff);
                      VDD_3V3_SPEKTRUM_POWER_EN(true);
              +       CAN1_SILENT_PULL_HIGH();
              nsh> uavcan status
                  Reserved:  6 blocks
                  Allocated: 6 blocks
              UAVCAN node status:
                  Transfer errors:   0
                  RX transfers:      0
                  TX transfers:      1079
              CAN1 status:
                  HW errors: 310
                  IO errors: 310
                  RX frames: 2224
                  TX frames: 1296
              ESC outputs:
              Servo outputs:
              Sensor 'battery':
              Sensor 'mag':
              uavcan: cycle time: 25877 events, 363400us elapsed, 14.04us avg, min 6us max 587us 24.085us rms
              uavcan: cycle interval: 25877 events, 2747.60us avg, min 15us max 3734us 716.959us rms
              • W Will
                VinnyV Offline
                VinnyV Offline
                Vinny
                @Will said in Supporting Tattu Pro Battery via UAVCAN Integration:
                @Moderator , I mistakenly connected the PC USB port to FCv2 J8 (CAN bus) instead of J3. Could this potentially cause damage to the board? . Despite this, the USB port is not recognized by the PC. I would appreciate your assistance in troubleshooting this issue. Thank you.
                Hi Will,
                I can only speak to the Hardware aspects here....
                If the PC's USB port is connected to the FCv2 J8 CANBUS port, I think the FCv2 hardware will be OK, but you more than likely may have damaged your PC port.
                Here are the effects that I can see:
                1. 5V from your USB VBUS is shorting out our 5V main supply on FCv2. However, our front-end power mux will block reverse current, and not feed into the power module or the source of the 5V for the FCv2
                2. That 5V that is shorted to VBUS is sent to a LDO Regulator before powering the STM at 3.3V, so the STM part should be protected as well
                3. The D+/D- lines of your USB port were likely driven by the CAN XCVR to invalid states, but as long as no actual data was being transmitted, it is likely both D+/D- and CANH/CANL were in "tri-state" mode, avoiding any contention. If the D+/D- were driving out, it is unlikely they can damage the CAN XCVR pins and the shunt resistor across the CAN XCVR will also protect the inputs.
                4. GND is connected to GND, so nothing was actually shorted to GND, which is good.
                So, I am not surprised you still see the FCv2 functioning, but your PC USB port may be dead/damaged and if you encounter any issues, I'd first try swapping PC ports.
                Hope that helps!
                • VinnyV Vinny
                  Hi Will,
                  Hope that helps!
                  W Offline
                  W Offline
                  Will
                  @Vinny , I've examined the port on my PC, and surprisingly, it's still functioning properly. Subsequently, I conducted two tests intentionally: one without the battery and the second with the battery. In both tests, I connected the PC's USB port to the FCv2 J8 CANBUS port and probed J8 pin1 (5P0V from the power-in source). Surprisingly, the board successfully booted in both scenarios, as indicated by the console log. This result raises a question: are both methods correct for booting the board?
                  Additionally, I encountered an issue where I couldn't retrieve information about the 3S battery from i2c bu3, even when connected to the power monitor board. Do I need to enable any other configurations for this? Thanks.
                  • PC's USB port to J8 without battery
                  • PC's USB port to J8 with battery
                  • Booting console log
                  [boot] Rev 0x0 : Ver 0x3 V2003000
                  ERROR [PX4_MTD] mtd fail[hardfault_log] Fault Log is Armed
                  ure: -5 bus 2 address 0 class 1
                  nsh: sysinit: fopen failed: No such file or directory
                  HW type: V2003000
                  HW version: 0x003
                  HW revision: 0x000
                  OS: NuttX
                  Build datetime: Jan  3 2024 15:59:58
                  INFO  [parameters] BSON document size 1487 bytes, decoded 1487 bytes (INT32:29, FLOAT:44)
                  Loading airframe: /etc/init.d/airframes/4001_quad_x
                  icp201xx #0 on I2C bus 4 (external) address 0x63
                  nsh: icm20948_i2c_passthrough: command not found
                  nsh: battery_status: command not found
                  ekf2 [591:237]
                  nsh> WARN  [health_and_arming_checks] Preflight Fail: height estimate not stable
                  WARN  [health_and_arming_checks] Preflight Fail: height estimate error
                  WARN  [health_and_arming_checks] Preflight Fail: Crash dumps present on SD, vehicle needs service
                  nsh> WARN  [health_and_arming_checks] Preflight Fail: Crash dumps present on SD, vehicle needs service
                  • Unable to detect battery from i2c bus 3
                  nsh> i2cdetect -b 3
                  Scanning I2C bus: 3
                       0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                  00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                  VinnyV 1 Reply Last reply
                  • W Will
                    HW type: V2003000
                    HW version: 0x003
                    HW revision: 0x000
                    OS: NuttX
                    ekf2 [591:237]
                    nsh> i2cdetect -b 3
                    Scanning I2C bus: 3
                    VinnyV Offline
                    VinnyV Offline
                    Vinny
                    @Vinny , I connected the PC's USB port to the FCv2 J8 CANBUS port and probed J8 pin1 (5P0V from the power-in source). Surprisingly, the board successfully booted in both scenarios, as indicated by the console log. This result raises a question: are both methods correct for booting the board?
                    Please only use the two documented power inputs as shown in our user guides:
                    https://docs.modalai.com/flight-core-v2-power/
                    Other modes are at your own risk as you are bypassing safety and protection features by using PTO ports (power tap off) as power inputs.
                    To use the power monitor functions correctly, you must use the power module to provide power to J13 without introducing setup and configuration anomalies.
                    For additional help with trying to see battery status in QGC I'm not the right person, so feel free to ping again after you are sure you have a correct configuration, or you are welcome to start a new thread or search our forum for similar cases (I know there have been others that have difficulty seeing battery info).
                    • VinnyV Vinny
                      W Offline
                      W Offline
                      Will
                      @Vinny , Thank you for the information. I acknowledge the potential risks involved. Unfortunately, I've encountered an issue as I am no longer able to establish a connection between FCv2 and GCS through the J3 USB port. However, I can still access the console via J2 and connect GCS through J5, which is sufficient for my needs. I plan to initiate a separate discussion for the power monitor to retrieve battery information. If you have any suggestions on how to read Tattu Pro Battery through J8 CANbus, please share them with me. (here is the post on PX4 forum, https://discuss.px4.io/t/supporting-tattu-pro-battery-via-uavcan-integration/36145) Thanks again.
                      • W Will
                        VinnyV Offline
                        VinnyV Offline
                        Vinny
                        wrote on last edited by Vinny
                        #11
                        @Will Have you considered purchasing another one? They are not expensive, and might be much more worth it than your time lost to fight a non-functional USB on the MCU.
                        Food for thought...
                        Sadly, I am not one of the SW experts in our team... just HW.
                        Tag me anytime you have HW related questions!
