    Supporting Tattu Pro Battery via UAVCAN Integration
    Flight Core v2
    2115
    • W
      Will
      I am linking the CAN interface of the Tattu Pro Battery ((https://genstattu.com/tattu-pro-22000mah-44-4v-25c-12s-1p-lipo-smart-battery-pack-with-as150u-f-plug/)) to the J8 connector and compiling version v1.14.0-2.0.64-dev with the specified configuration enabled:
      CONFIG_DRIVERS_UAVCAN=y
      CONFIG_BOARD_UAVCAN_INTERFACES=1
      CONFIG_BOARD_UAVCAN_TIMER_OVERRIDE=2
      Here is the version information for the board and firmware
      nsh> ver all
      HW arch: MODALAI_FC_V2
      HW type: V2003000
      HW version: 0x003
      HW revision: 0x000
      PX4 git-hash: 996e85e9360801dd9ec11b7149a524e38231dcc6
      PX4 version: 1.14.0 0 (17694720)
      Vendor version: 2.0.64 0 (33570816)
      OS: NuttX
      OS version: Release 11.0.0 (184549631)
      OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
      Build datetime: Dec 26 2023 12:23:55
      Build uri: localhost
      Build variant: default
      Toolchain: GNU GCC, 9.3.1 20200408 (release)
      PX4GUID: 0006000000003333363031315105003a001c
      MCU: STM32H7[4|5]xxx, rev. V
      Below is the error indicating the issue where I am unable to retrieve battery information:
      nsh> uavcan
      INFO  [uavcan] usage:
          uavcan {start|status|stop|shrink|update}
                  param [set|get|list|save] <node-id> <name> <value>|r
      nsh> uavcan start
      INFO  [uavcan] already started
      nsh> uavcan status
      Pool allocator status:
          Capacity hard/soft: 500/250 blocks
          Reserved:  13 blocks
          Allocated: 10 blocks
      UAVCAN node status:
          Internal failures: 0
          Transfer errors:   0
          RX transfers:      0
          TX transfers:      6922
      CAN1 status:
          HW errors: 2476
          IO errors: 2476
          RX frames: 10302
          TX frames: 8289
      ESC outputs:
      INFO  [mixer_module] Param prefix: UAVCAN_EC
      control latency: 0 events, 0us elapsed, 0.00us avg, min 0us max 0us 0.000us rms
      Channel Configuration:
      Channel 0: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Channel 1: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Channel 2: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Channel 3: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Channel 4: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Channel 5: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Channel 6: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Channel 7: func:   0, value: 0, failsafe: 65535, disarmed: 65535, min: 1, max: 8191
      Servo outputs:
      INFO  [mixer_module] Param prefix: UAVCAN_SV
      Channel 0: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Channel 1: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Channel 2: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Channel 3: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Channel 4: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Channel 5: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Channel 6: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Channel 7: func:   0, value: 0, failsafe: 500, disarmed: 500, min: 0, max: 1000
      Sensor 'gnss':
      Sensor 'mag':
      Online nodes (Node ID, Health, Mode):
      uavcan: cycle time: 163407 events, 2350932us elapsed, 14.39us avg, min 6us max 709us 21.106us rms
      uavcan: cycle interval: 163407 events, 2814.40us avg, min 15us max 4373us 624.775us rms
      nsh>
      nsh> uavcan param list 107
      Failed to get param: -1
      Here is an example from the Tattu Pro document. However, I am unable to achieve the same result. Please assist in checking if I have missed anything to enable UAVCAN. Thanks.
      • ModeratorM
        Moderator ModalAI Team
        We do not have any experience with that product. Have you asked on the PX4 forums?
        W 1 Reply Last reply Reply Quote 0
        • W
          Will @Moderator
          @Moderator , I've observed a mention on the provided web address that states, "CAN “Silent” pin (STBY) is controlled by STM32 PD15 pin (default pulled-LOW in hardware)", does this imply that I need to set PD15 to a high level to enable the CAN bus? If so, could you please provide instructions on configuring PD15 on FCv2? Thank you.
          https://docs.modalai.com/flight-core-v2-datasheets-connectors/
          • W
            Will @Will
            @Moderator , I mistakenly connected the PC USB port to FCv2 J8 (CAN bus) instead of J3. Could this potentially cause damage to the board? Currently, QGC cannot establish a connection to FCv2 through the serial port, and the PC fails to recognize any ttyUSBx port. Interestingly, I am still able to use STLink to connect to FCv2 via J2. When I connect J3 to the PC, the LED initially blinks green for a few seconds and then switches to green and white intermittently. Despite this, the USB port is not recognized by the PC. I would appreciate your assistance in troubleshooting this issue. Thank you.
            W VinnyV 2 Replies Last reply Reply Quote 0
            • W
              Will @Will
              @Moderator , Here is the PX4 system console log. Could you please assist in examining why the J3 USB connector is not functioning? Thank you.
              [boot] Rev 0x0 : Ver 0x3 V230
              [boot] Fault Log info File No 4 Length 3177 flags:0x01 state:1
              [boot] Fault Log is Armed
              sercon: Registering CDC/ACM serial driver
              sercon: Successfully registered the CDC/ACM serial driver
              ERROR [PX4_MTD] failed to initialize mtd driver
              ERROR [PX4_MTD] mtd failure[hardfault_log] Fault Log is Armed
              : -5 bus 2 address 0 class 1
              HW type: V230
              HW version: 0x00000003
              HW revision: 0x00000000
              FW git-hash: 259b3c097773507e581e2930093e4958f7726381
              FW version: Release 1.13.2 (17629951)
              FW git-branch: modalai-1.13.2
              OS: NuttX
              OS git-hash: 91bece51afbe7da9db12e3695cdbb4f4bba4bc83
              Build datetime: Dec  8 2023 23:35:12
              INFO  [param] selected parameter default file /fs/microsd/params
              INFO  [param] importing from '/fs/microsd/params'
              INFO  [parameters] BSON document size 1752 bytes, decoded 1752 bytes (INT32:40, FLOAT:46)
              INFO  [param] selected parameter backup file /fs/microsd/parameters_backup.bson
              Board architecture defaults: /etc/init.d/rc.board_arch_defaults
              Board defaults: /etc/init.d/rc.board_defaults
              nsh: tone_alarm: command not found
              INFO  [dataman] data manager file '/fs/microsd/dataman' size is 62560 bytes
              Loading airframe: /etc/init.d/airframes/4015_holybro_s500
              INFO  [uavcan] Node ID 1, bitrate 1000000
              Board sensors: /etc/init.d/rc.board_sensors
              INFO  [voxlpm] Failed to init voxlpm type: 0 on bus: 3, but will try again periodically.
              voxlpm #0 on I2C bus 3 (external) address 0x44
              WARN  [SPI_I2C] Already running on bus 3
              WARN  [SPI_I2C] voxlpm: no instance started (no device on bus?)
              icm42688p #0 on SPI bus 1 rotation 12
              icm42688p #1 on SPI bus 2 rotation 12
              icp20100 #0 on I2C bus 4 (external) address 0x63
              INFO  [init] Mixer: /etc/mixers/quad_x.main.mix on /dev/uavcan/esc
              INFO  [init] setting PWM_AUX_OUT none
              ekf2 [670:237]
              Starting Main GPS on /dev/ttyS0
              Starting MAVLink on /dev/ttyS6
              INFO  [mavlink] mode: Onboard, data rate: 46080 B/s on /dev/ttyS6 @ 921600B
              WARN  [mavlink] stream SCALED_PRESSURE not found
              ERROR [mavlink] configure_streams_to_default() failed
              Addons script: /fs/microsd/etc/extras.txt
              nsh: BMP388: command not found
              NuttShell (NSH) NuttX-11.0.0
              • W
                Will @Will
                @Moderator , the board is currently operational somehow. I made adjustments to the code, setting PD15 to a high level and modifying the parameters of UAVCAN_SUB_BAT to 1 and UAVCAN_ENABLE to 2 or 3, following the guidelines on this page (https://docs.px4.io/v1.12/zh/uavcan/pomegranate_systems_pm.html). Despite these modifications, I am still unable to retrieve battery information. I will also explore the PX4 forum for potential solutions. However, if you have additional suggestions, please feel free to share. Thank you.
                diff --git a/boards/modalai/fc-v2/src/board_config.h b/boards/modalai/fc-v2/src/board_config.h
                index 987f692b22..e7a7c83ef7 100644
                --- a/boards/modalai/fc-v2/src/board_config.h
                +++ b/boards/modalai/fc-v2/src/board_config.h
                @@ -213,6 +213,7 @@
                 /* Spare GPIO */
                 #define CAN1_SILENT                       /* PD15 */  (GPIO_OUTPUT|GPIO_PUSHPULL|GPIO_SPEED_2MHz|GPIO_OUTPUT_CLEAR|GPIO_PORTD|GPIO_PIN15)
                +#define CAN1_SILENT_PULL_HIGH()  px4_arch_gpiowrite(CAN1_SILENT, 1)
                 /* For primary/backup signaling with VOXL, 2 pins on J4 are exposed */
                 // GPIO_VOXL_STATUS_OUT/ GPIO_VOXL_STATUS_IN are for v1 Spare MSS Communications Interface and J4 tests
                diff --git a/boards/modalai/fc-v2/src/init.c b/boards/modalai/fc-v2/src/init.c
                index dbc6ec4637..55ad6aab6c 100644
                --- a/boards/modalai/fc-v2/src/init.c
                +++ b/boards/modalai/fc-v2/src/init.c
                @@ -211,6 +211,8 @@ __EXPORT int board_app_initialize(uintptr_t arg)
                        /* Power on Interfaces */
                        board_spi_reset(10, 0xffff);
                        VDD_3V3_SPEKTRUM_POWER_EN(true);
                +       CAN1_SILENT_PULL_HIGH();
                nsh> uavcan status
                    Reserved:  6 blocks
                    Allocated: 6 blocks
                UAVCAN node status:
                    Transfer errors:   0
                    RX transfers:      0
                    TX transfers:      1079
                CAN1 status:
                    HW errors: 310
                    IO errors: 310
                    RX frames: 2224
                    TX frames: 1296
                ESC outputs:
                Servo outputs:
                Sensor 'battery':
                Sensor 'mag':
                uavcan: cycle time: 25877 events, 363400us elapsed, 14.04us avg, min 6us max 587us 24.085us rms
                uavcan: cycle interval: 25877 events, 2747.60us avg, min 15us max 3734us 716.959us rms
                • VinnyV
                  Vinny ModalAI Team @Will
                  @Will said in Supporting Tattu Pro Battery via UAVCAN Integration:
                  @Moderator , I mistakenly connected the PC USB port to FCv2 J8 (CAN bus) instead of J3. Could this potentially cause damage to the board? . Despite this, the USB port is not recognized by the PC. I would appreciate your assistance in troubleshooting this issue. Thank you.
                  Hi Will,
                  I can only speak to the Hardware aspects here....
                  If the PC's USB port is connected to the FCv2 J8 CANBUS port, I think the FCv2 hardware will be OK, but you more than likely may have damaged your PC port.
                  Here are the effects that I can see:
                  1. 5V from your USB VBUS is shorting out our 5V main supply on FCv2. However, our front-end power mux will block reverse current, and not feed into the power module or the source of the 5V for the FCv2
                  2. That 5V that is shorted to VBUS is sent to a LDO Regulator before powering the STM at 3.3V, so the STM part should be protected as well
                  3. The D+/D- lines of your USB port were likely driven by the CAN XCVR to invalid states, but as long as no actual data was being transmitted, it is likely both D+/D- and CANH/CANL were in "tri-state" mode, avoiding any contention. If the D+/D- were driving out, it is unlikely they can damage the CAN XCVR pins and the shunt resistor across the CAN XCVR will also protect the inputs.
                  4. GND is connected to GND, so nothing was actually shorted to GND, which is good.
                  So, I am not surprised you still see the FCv2 functioning, but your PC USB port may be dead/damaged and if you encounter any issues, I'd first try swapping PC ports.
                  Hope that helps!
                  • W
                    Will @Vinny
                    @Vinny , I've examined the port on my PC, and surprisingly, it's still functioning properly. Subsequently, I conducted two tests intentionally: one without the battery and the second with the battery. In both tests, I connected the PC's USB port to the FCv2 J8 CANBUS port and probed J8 pin1 (5P0V from the power-in source). Surprisingly, the board successfully booted in both scenarios, as indicated by the console log. This result raises a question: are both methods correct for booting the board?
                    Additionally, I encountered an issue where I couldn't retrieve information about the 3S battery from i2c bu3, even when connected to the power monitor board. Do I need to enable any other configurations for this? Thanks.
                    • PC's USB port to J8 without battery
                    • PC's USB port to J8 with battery
                    • Booting console log
                    [boot] Rev 0x0 : Ver 0x3 V2003000
                    ERROR [PX4_MTD] mtd fail[hardfault_log] Fault Log is Armed
                    ure: -5 bus 2 address 0 class 1
                    nsh: sysinit: fopen failed: No such file or directory
                    HW type: V2003000
                    HW version: 0x003
                    HW revision: 0x000
                    OS: NuttX
                    Build datetime: Jan  3 2024 15:59:58
                    INFO  [parameters] BSON document size 1487 bytes, decoded 1487 bytes (INT32:29, FLOAT:44)
                    Loading airframe: /etc/init.d/airframes/4001_quad_x
                    icp201xx #0 on I2C bus 4 (external) address 0x63
                    nsh: icm20948_i2c_passthrough: command not found
                    nsh: battery_status: command not found
                    ekf2 [591:237]
                    nsh> WARN  [health_and_arming_checks] Preflight Fail: height estimate not stable
                    WARN  [health_and_arming_checks] Preflight Fail: height estimate error
                    WARN  [health_and_arming_checks] Preflight Fail: Crash dumps present on SD, vehicle needs service
                    nsh> WARN  [health_and_arming_checks] Preflight Fail: Crash dumps present on SD, vehicle needs service
                    • Unable to detect battery from i2c bus 3
                    nsh> i2cdetect -b 3
                    Scanning I2C bus: 3
                         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
                    00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
                    • VinnyV
                      @Vinny , I connected the PC's USB port to the FCv2 J8 CANBUS port and probed J8 pin1 (5P0V from the power-in source). Surprisingly, the board successfully booted in both scenarios, as indicated by the console log. This result raises a question: are both methods correct for booting the board?
                      Please only use the two documented power inputs as shown in our user guides:
                      https://docs.modalai.com/flight-core-v2-power/
                      Other modes are at your own risk as you are bypassing safety and protection features by using PTO ports (power tap off) as power inputs.
                      To use the power monitor functions correctly, you must use the power module to provide power to J13 without introducing setup and configuration anomalies.
                      For additional help with trying to see battery status in QGC I'm not the right person, so feel free to ping again after you are sure you have a correct configuration, or you are welcome to start a new thread or search our forum for similar cases (I know there have been others that have difficulty seeing battery info).
                      • W
                        Will @Vinny
                        @Vinny , Thank you for the information. I acknowledge the potential risks involved. Unfortunately, I've encountered an issue as I am no longer able to establish a connection between FCv2 and GCS through the J3 USB port. However, I can still access the console via J2 and connect GCS through J5, which is sufficient for my needs. I plan to initiate a separate discussion for the power monitor to retrieve battery information. If you have any suggestions on how to read Tattu Pro Battery through J8 CANbus, please share them with me. (here is the post on PX4 forum, https://discuss.px4.io/t/supporting-tattu-pro-battery-via-uavcan-integration/36145) Thanks again.
                        • VinnyV
                          @Will Have you considered purchasing another one? They are not expensive, and might be much more worth it than your time lost to fight a non-functional USB on the MCU.
                          Food for thought...
                          Sadly, I am not one of the SW experts in our team... just HW.
                          Tag me anytime you have HW related questions!
