  3. QGroundControl parameters are missing from firmware
starling
8 Posts 2 Posters 2.9k Views 1 Watching
  • S Offline
    S Offline
    smilon
    wrote on last edited by smilon
    Re: QGroundControl parameters are missing from firmware
    I have been facing the same problem on my newly aqcuired StarlingV2 after I did a few nominal tests with QGroundControl. Steps:
    • I only slightly modified voxl-vision-hub, voxl-tag-detector, tag_location conf files for AprilTag fixed frame relocalization. After rebooting I got this error on QGroundcontrol. Only changed the parameters as this docu states https://docs.modalai.com/voxl-vision-hub-apriltag-relocalization/
    • In order to overcome it I then ran voxl-configure-mpa to reset to factory default and I am getting the following error:
    Not really sure how to proceed since resetting to factory defaults should bring back the original calibration files no? Feels like the problem is elsewhere and I would first like to be sure before wasting time in calibration.
    Best,
    Milton
    S 1 Reply Last reply
    • S smilon
      Best,
      Milton
      S Offline
      S Offline
      smilon
      After power cycling, I am now getting the following QGC error:
      Further on, running voxl-esc setup_starling_v2 gives the following error:
      Error calling voxl_uart_init
      [ERROR] Unknown board detected:
      disabling bridge
      bridge disabled
      EXITING VOXL-ESC WITH ERROR
      If you could please send me the calibration files as soon as possible and I will do a factory flash of the SDK as mentioned in Starling V2 voxl-configure-mpa fails to execute voxl-esc setup_starling_v2 and voxl-elrs --scan
      Model Serial #: M23000001JJ
      • S smilon
        disabling bridge
        bridge disabled
        @smilon You have to scroll up to see the actual errors. It looks like the two following commands are what generated errors:
        voxl-elrs --scan
        The calibration status is fine, you can generate the missing parameters_level.cal by calibrating level via. QGroundControl, but that wouldn't cause the errors that are occurring above
          voxl-elrs --scan
          S Offline
          S Offline
          smilon
          @tom Thanks for the quick reply. I will calibrate the level tomorrow via QGC. Is there any idea why the original issue, prior to running voxl-configure-mpa occurred? Could it hint to some wrongly defined config files on my side?
          • S smilon
            @smilon In order for things to be setup properly, px4 params, etc. voxl-configure-mpa + a reboot are required. So if either of those weren't completed before booting up QGC then that could've been the cause. Sometimes a reboot of QGC can solve that issue as well as it does some weird caching sometimes
              S Offline
              S Offline
              smilon
              @tom Sorry to bother you again. But I am facing issues where I'm missing several QGC params such as battery percent and some RC params. Also attempting to calibrate the level via QGC is unresponsive and generally QGC itself seems unresponsive to any command I give. Even though I'm getting a "Ready to Fly" state. I can't arm the drone since I can't calibrate the level. I also can't run voxl-configure-mpa sucessfully unless I can solve the "voxl-esc setup_startling_v2" error. Any ideas on how to move onwards?
              • S smilon
                S Offline
                S Offline
                smilon
                It seems the error is in the ESC, no clue why unrelated px4 parameters are being deleted. However I can't discover the esc when i run:
                voxl-esc scan
                or
                voxl-esc detect
                The ESC wiring looks fine and I have not put more than 30minutes of flight time in the Starling, so I'm guessing its a firmware issue. Looks like it would be better if I can perform a factory reset and you can send me the calibration files for my model (M23000001JJ)?
                • S smilon
                  voxl-esc scan
                  or
                  voxl-esc detect
                  @smilon Yeah that's worth a try. You can also pull the calibration files off before performing a factory reset by locating them in /data/modalai and from host running adb pull /data/modalai/* . and then pushing them back on after
                  • S smilon referenced this topic on
