  2. Software Development
  3. ROS
  4. running uxrce_client with voxl2-px4
4 Posts 2 Posters 1.8k Views
  • Kyuhyong YouK Offline
    Kyuhyong You
    I just wondering if volx2-px4 can run uxrce_dds_client as described here.
    https://docs.px4.io/main/en/middleware/uxrce_dds.html
    I was able to build install ros2 on voxl2 and uxrce_dds_agent and runs ok with external FC.
    I also found voxl-px4 runs with v1.14.0 version
    pxh> ver mcu
    UNKNOWN MCU
    pxh> ver hw
    HW arch: MODALAI_VOXL2
    pxh> ver all
    PX4 git-hash:
    PX4 version: 1.14.0 0 (17694720)
    Vendor version: 2.0.34 0 (33563136)
    OS: Linux
    OS version: Release 4.19.125 (68386303)
    Build datetime: Jun  7 2023 14:33:27
    Build uri: localhost
    Build variant: default
    Toolchain: GNU GCC, 7.5.0
    PX4GUID:
    UNKNOWN MCU
    Is it possible to run dds client?
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @Kyuhyong-You the voxl2 on sdk 1.1.0 runs the dds_client out the gate. You can see here in the executable of PX4 that we spin up the dds client:
      Link Preview Image
      px4-firmware/boards/modalai/voxl2/target/voxl-px4-start at 557d402e84e0a3ea122a0383270ff680d920bb7e · modalai/px4-firmware
      PX4 Autopilot Software. Contribute to modalai/px4-firmware development by creating an account on GitHub.
      favicon
      GitHub (github.com)
      # Start microdds_client for ros2 offboard messages from agent over localhost microdds_client start -t udp -h 127.0.0.1 -p 8888
      In order to communicate - make sure you have voxl-microdds-agent installed via apt-get as well as configured. Then you should be able to communicate over the bridge:
      Here are the instructions: https://docs.modalai.com/ros2-installation-voxl2/
      Kyuhyong YouK 1 Reply Last reply
        Link Preview Image
        favicon
        GitHub (github.com)
        Kyuhyong You
        @Zachary-Lowell-0
        Thanks for your comment!
        So it means px4 on voxl2 is running microdds_client which is not compatible with uxrce_dds_cleint on the PX4 release/1.14.0
        And the microdds_client will start automatically when px4 on voxl2 service is up and running?
          Zachary Lowell 0
          Sure thing @Kyuhyong-You . That is correct - currently the voxl2 runs the microdds client instead of the uxrce dds client on 1.14.0 stable. The microdds client starts automatically on the voxl2 when px4 is instantiated - if not, feel free to build PX4 yourself and flash it on the board via the instructions here:
          Link Preview Image
          VOXL 2 PX4 Developer and Build Guide
          favicon
          There is also another service available on SDK 1.1 (https://docs.modalai.com/sdk-1.1-release-notes/) called microdds-agent which spins up the agent to listen to localhost port 8888 and allow for comms similar to mavsdk.
          Link Preview Image
          ROS2 Installation VOXL 2
          favicon
