running uxrce_client with voxl2-px4
I just wondering if volx2-px4 can run uxrce_dds_client as described here.
https://docs.px4.io/main/en/middleware/uxrce_dds.htmlI was able to build install ros2 on voxl2 and uxrce_dds_agent and runs ok with external FC.
I also found voxl-px4 runs with v1.14.0 version
pxh> ver mcu UNKNOWN MCU pxh> ver hw HW arch: MODALAI_VOXL2 pxh> ver all HW arch: MODALAI_VOXL2 PX4 git-hash: PX4 version: 1.14.0 0 (17694720) Vendor version: 2.0.34 0 (33563136) OS: Linux OS version: Release 4.19.125 (68386303) Build datetime: Jun 7 2023 14:33:27 Build uri: localhost Build variant: default Toolchain: GNU GCC, 7.5.0 PX4GUID: UNKNOWN MCUIs it possible to run dds client?
@Kyuhyong-You the voxl2 on sdk 1.1.0 runs the dds_client out the gate. You can see here in the executable of PX4 that we spin up the dds client:
px4-firmware/boards/modalai/voxl2/target/voxl-px4-start at 557d402e84e0a3ea122a0383270ff680d920bb7e · modalai/px4-firmware
PX4 Autopilot Software. Contribute to modalai/px4-firmware development by creating an account on GitHub.
GitHub (github.com)
# Start microdds_client for ros2 offboard messages from agent over localhost microdds_client start -t udp -h 127.0.0.1 -p 8888In order to communicate - make sure you have
voxl-microdds-agentinstalled via apt-get as well as configured. Then you should be able to communicate over the bridge:Here are the instructions: https://docs.modalai.com/ros2-installation-voxl2/
GitHub (github.com)
@Zachary-Lowell-0
Thanks for your comment!So it means px4 on voxl2 is running microdds_client which is not compatible with uxrce_dds_cleint on the PX4 release/1.14.0
And the microdds_client will start automatically when px4 on voxl2 service is up and running? -
Sure thing @Kyuhyong-You . That is correct - currently the voxl2 runs the microdds client instead of the uxrce dds client on 1.14.0 stable. The microdds client starts automatically on the voxl2 when px4 is instantiated - if not, feel free to build PX4 yourself and flash it on the board via the instructions here:
VOXL 2 PX4 Developer and Build Guide
There is also another service available on SDK 1.1 (https://docs.modalai.com/sdk-1.1-release-notes/) called microdds-agent which spins up the agent to listen to localhost port 8888 and allow for comms similar to mavsdk.
ROS2 Installation VOXL 2
