    running uxrce_client with voxl2-px4
    ROS
    • Kyuhyong YouK
      Kyuhyong You
      I just wondering if volx2-px4 can run uxrce_dds_client as described here.
      https://docs.px4.io/main/en/middleware/uxrce_dds.html
      I was able to build install ros2 on voxl2 and uxrce_dds_agent and runs ok with external FC.
      I also found voxl-px4 runs with v1.14.0 version
      pxh> ver mcu
      UNKNOWN MCU
      pxh> ver hw
      HW arch: MODALAI_VOXL2
      pxh> ver all
      PX4 git-hash:
      PX4 version: 1.14.0 0 (17694720)
      Vendor version: 2.0.34 0 (33563136)
      OS: Linux
      OS version: Release 4.19.125 (68386303)
      Build datetime: Jun  7 2023 14:33:27
      Build uri: localhost
      Build variant: default
      Toolchain: GNU GCC, 7.5.0
      PX4GUID:
      UNKNOWN MCU
      Is it possible to run dds client?
      • Zachary Lowell 0Z
        Zachary Lowell 0 ModalAI Team
        @Kyuhyong-You the voxl2 on sdk 1.1.0 runs the dds_client out the gate. You can see here in the executable of PX4 that we spin up the dds client:
        https://github.com/modalai/px4-firmware/blob/557d402e84e0a3ea122a0383270ff680d920bb7e/boards/modalai/voxl2/target/voxl-px4-start#L213
        # Start microdds_client for ros2 offboard messages from agent over localhost microdds_client start -t udp -h 127.0.0.1 -p 8888
        In order to communicate - make sure you have voxl-microdds-agent installed via apt-get as well as configured. Then you should be able to communicate over the bridge:
        Here are the instructions: https://docs.modalai.com/ros2-installation-voxl2/
        Kyuhyong YouK 1 Reply Last reply Reply Quote 0
        • Kyuhyong YouK
          Kyuhyong You @Zachary Lowell 0
          @Zachary-Lowell-0
          Thanks for your comment!
          So it means px4 on voxl2 is running microdds_client which is not compatible with uxrce_dds_cleint on the PX4 release/1.14.0
          And the microdds_client will start automatically when px4 on voxl2 service is up and running?
          • Zachary Lowell 0Z
            Sure thing @Kyuhyong-You . That is correct - currently the voxl2 runs the microdds client instead of the uxrce dds client on 1.14.0 stable. The microdds client starts automatically on the voxl2 when px4 is instantiated - if not, feel free to build PX4 yourself and flash it on the board via the instructions here:
            https://docs.modalai.com/voxl-px4-dev-build-guide/
            There is also another service available on SDK 1.1 (https://docs.modalai.com/sdk-1.1-release-notes/) called microdds-agent which spins up the agent to listen to localhost port 8888 and allow for comms similar to mavsdk.
