  3. VOXL2 Stuck in Fastboot
3 Posts 3 Posters 1.7k Views 1 Watching
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    My VOXL2 is stuck in fastboot. I tried to
    1. QDL
    2. Force fastboot using button on VOXL2 and reflash
    Neither of these could get the VOXL2 out of Fastboot. It seemed like something was corrupted on the board (it was the filesystem I believe)
    Here are the steps I took to fix it
    1. Download the system image from: https://developer.modalai.com/asset
    2. unzip the file tar -xzf voxl2_SDK_1.0.0.tar.gz
    3. navigate into the file folder, and the "system-image" folder there within cd voxl2_SDK_1.0.0/system-image
    4. Factory reset flash using flash-system-image.sh -f
    5. You should now see the "Qualcomm-KONA" device, and you should be able to adb in
    6. navigate back to the root of the folder "voxl2_SDK_1.0.0"
    7. run the install script ./install.sh
    8. follow the prompts
    You should be good to go from here. I found this information from this other post: https://forum.modalai.com/topic/1931/voxl2-not-coming-out-of-fastboot?_=1698713877796
    But thought I would type this up to make it a bit more concise incase anyone came across this same issue in the future
    tomT S 2 Replies Last reply
    • wilkinsafW wilkinsaf
      1. QDL
      @wilkinsaf This is really helpful, thanks!
      • H HLaGrone referenced this topic on
        1. QDL
        S Offline
        S Offline
        saegsali
        Hi @wilkinsaf
        Thank you for this post!
        I had the same issue and was able to solve it using these steps.
