  3. Displaying hires frames with timestamp
3 Posts 2 Posters 686 Views
  • W Offline
    W Offline
    Wei Cui
    Hi everyone, would it be possible to see the timestamp of each hires camera frame in VOXL-portal? Thank you.
    ModeratorM 1 Reply Last reply
    • W Wei Cui
      @Wei-Cui you could write your own hi-res overlay to render whatever information you'd like. You can see the qvio-overlay source code here. You would need to create your own service that received the high-res data, drew the overlay, and then published over MPA as a new pipe. voxl-portal will automatically grab all of the camera pipes and make available as potential streams
      W 1 Reply Last reply
      • ModeratorM Moderator
        W Offline
        W Offline
        Wei Cui
        wrote on last edited by Wei Cui
