  3. Voxl2 Camera calibration fails for hires camera
3 Posts 2 Posters 741 Views
  • Darshit DesaiD Offline
    Darshit Desai
    What hardware are you using? Voxl2 Starling
    What version of software are you using?
    system-image: 1.6.2-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.0/binary-arm64/
    Last Updated: 2023-09-20 22:12:41
    List:
    	libmodal-cv              0.3.2
    	libmodal-exposure        0.0.8
    	libmodal-journal         0.2.2
    	libmodal-json            0.4.3
    	libmodal-pipe            2.8.5
    	libqrb5165-io            0.2.0
    	libvoxl-cci-direct       0.1.5
    	libvoxl-cutils           0.1.1
    	mv-voxl                  0.1-r0
    	qrb5165-bind             0.1-r0
    	qrb5165-dfs-server       0.1.0
    	qrb5165-imu-server       0.6.0
    	qrb5165-slpi-test-sig    01-r0
    	qrb5165-system-tweaks    0.2.2
    	qrb5165-tflite           2.8.0-2
    	voxl-bind-spektrum       0.1.0
    	voxl-camera-calibration  0.4.0
    	voxl-camera-server       1.6.2
    	voxl-configurator        0.2.7
    	voxl-cpu-monitor         0.4.6
    	voxl-docker-support      1.2.5
    	voxl-elrs                0.0.7
    	voxl-esc                 1.2.2
    	voxl-gphoto2-server      0.0.10
    	voxl-jpeg-turbo          2.1.3
    	voxl-lepton-server       1.1.2
    	voxl-libgphoto2          0.0.4
    	voxl-libuvc              1.0.7
    	voxl-logger              0.3.4
    	voxl-mavcam-manager      0.5.1
    	voxl-mavlink             0.1.1
    	voxl-mavlink-server      1.2.0
    	voxl-modem               1.0.5
    	voxl-mongoose            7.7.0-1
    	voxl-mpa-to-ros          0.3.6
    	voxl-mpa-tools           1.0.4
    	voxl-opencv              4.5.5-1
    	voxl-portal              0.5.9
    	voxl-px4                 1.14.0-2.0.34
    	voxl-px4-imu-server      0.1.2
    	voxl-px4-params          0.1.8
    	voxl-qvio-server         0.9.3
    	voxl-remote-id           0.0.8
    	voxl-slpi-uart-bridge    1.0.1
    	voxl-streamer            0.7.1
    	voxl-tag-detector        0.0.4
    	voxl-tflite-server       0.3.1
    	voxl-utils               1.3.1
    	voxl-uvc-server          0.1.6
    	voxl-vision-hub          1.6.6
    	voxl2-system-image       1.6.2-r0
    	voxl2-wlan               1.0-r0
    How have you configured the software?
    voxl2:~$ voxl-inspect-services
    Scanning services...
     docker-autorun       | Disabled  | Not Running |
     docker-daemon        | Disabled  | Not Running |
     voxl-camera-server   |  Enabled  |   Running   |    41.1%
     voxl-cpu-monitor     |  Enabled  |   Running   |     0.4%
     voxl-dfs-server      | Disabled  | Not Running |
     voxl-imu-server      |  Enabled  |   Running   |     4.0%
     voxl-lepton-server   | Disabled  | Not Running |
     voxl-mavcam-manager  |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server  |  Enabled  |   Running   |     2.9%
     voxl-portal          |  Enabled  |   Running   |     0.5%
     voxl-px4-imu-server  | Disabled  | Not Running |
     voxl-px4             |  Enabled  |   Running   |    25.5%
     voxl-qvio-server     |  Enabled  |   Running   |    30.3%
     voxl-remote-id       | Disabled  | Not Running |
     voxl-softap          | Disabled  | Not Running |
     voxl-static-ip       | Disabled  | Not Running |
     voxl-streamer        |  Enabled  |   Running   |     0.0%
     voxl-tag-detector    | Disabled  | Not Running |
     voxl-uvc-server      | Disabled  | Not Running |
     voxl-vision-hub      |  Enabled  |   Running   |     2.8%
    voxl2:~$
    Do you have any logs?
    I have a screenshot of the issue below:
    Another Requests: How to do calibration of Time of flight camera or is there a intrinsic matrix?
    ModeratorM 1 Reply Last reply
      hw version:   M0054
      voxl-suite:
      Packages:
      List:
      	libmodal-cv              0.3.2
      	libmodal-json            0.4.3
      	libmodal-pipe            2.8.5
      	libqrb5165-io            0.2.0
      	mv-voxl                  0.1-r0
      	qrb5165-bind             0.1-r0
      	voxl-elrs                0.0.7
      	voxl-esc                 1.2.2
      	voxl-libuvc              1.0.7
      	voxl-logger              0.3.4
      	voxl-mavlink             0.1.1
      	voxl-modem               1.0.5
      	voxl-opencv              4.5.5-1
      	voxl-portal              0.5.9
      	voxl-streamer            0.7.1
      	voxl-utils               1.3.1
      	voxl2-wlan               1.0-r0
      voxl2:~$
      @Darshit-Desai the hires camera is not a fisheye, so you could try not using a fisheye but we don't calibrate the hires as a normal part of our factory processing. We do not have a method currently for calculating the extrinsics between hires and tof.
      Darshit DesaiD 1 Reply Last reply
      • ModeratorM Moderator
        Darshit Desai
        @Moderator Ok I will try calibrating with the ros method of calibration. I was asking this because I want to make an aligned depth image by combining hires and tof camera like the realsense cameras have. If you could also reply on the following. I am not really sure if Tofs can be calibrated
        @Darshit-Desai said in Voxl2 Camera calibration fails for hires camera:
