voxl-px4 service
After fast rebooting to platform "voxl2_platform_0.9.5",i run into the following problem:voxl2:~$ systemctl start voxl-px4 **A dependency job for voxl-px4.service failed. See 'journalctl -xe' for details.** voxl2:~$From the journalctl -f command after activating the "systemctl start voxl-px4":
Aug 23 12:17:30 m0054 systemd[1]: data.mount: Directory /data to mount over is not empty, mounting anyway.
Aug 23 12:17:30 m0054 systemd[1]: Mounting /data...
Aug 23 12:17:30 m0054 mount[3074]: mount: /data: wrong fs type, bad option, bad superblock on /dev/sda8, missing codepage or helper program, or other error.
Aug 23 12:17:30 m0054 systemd[1]: data.mount: Mount process exited, code=exited status=32
Aug 23 12:17:30 m0054 kernel: EXT4-fs (sda8): VFS: Can't find ext4 filesystem
Aug 23 12:17:30 m0054 systemd[1]: data.mount: Failed with result 'exit-code'.
Aug 23 12:17:30 m0054 systemd[1]: Failed to mount /data.
Aug 23 12:17:30 m0054 systemd[1]: Dependency failed for sscrpcd Service.
Aug 23 12:17:30 m0054 systemd[1]: Dependency failed for px4.
Aug 23 12:17:30 m0054 systemd[1]: voxl-px4.service: Job voxl-px4.service/start failed with result 'dependency'.
Aug 23 12:17:30 m0054 systemd[1]: sscrpcd.service: Job sscrpcd.service/start failed with result 'dependency'.Please help to solve the problem.
@relevinsky it looks like you have corrupted flash
@relevinsky Is this happening on every reboot?
@Eric-Katzfey yes
