    imu_apps seems to be publishing in bursts
    • tanguy sagereT
      tanguy sagere
      Hi! I'm working with a ModalAI Sentinel right now equipped with the VOXL2, and I've noticed after running a few test flights that the recorded imu_apps data is very patchy, with bursts of messages followed by entire seconds of silence. This puts alot of stress on my VIO. Am I missing something or is this a known issue, and if so how do I fix it?
      my voxl-imu-server.conf params are the default.
      Thank you in advance!
      • ModeratorM
        Moderator ModalAI Team
        Hi Tanguy,
        That sounds like the CPU is being overloaded. Which version of SDK are you running (voxl-version) and can you show the output of voxl-inspect-cpu when you are seeing this issue?
        tanguy sagereT 1 Reply Last reply Reply Quote 0
        • tanguy sagereT
          tanguy sagere @Moderator
          @Moderator Hi! I'm using :
          system-image: 1.5.5-M0054-14.1a-perf
          kernel:       #1 SMP PREEMPT Fri Mar 24 00:48:55 UTC 2023 4.19.125
          hw version:   M0054
          voxl-suite:   0.9.5
          Packages:
          Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-0.9/binary-arm64/
          Last Updated: 2023-08-24 23:20:47
          When experiencing the message dropout, this is the output of voxl-inspect-cpu :
          • tanguy sagereT
            tanguy sagere
            I've solved the problem by setting the voxl-imu-server.conf to
            "imu0_enable":  true,
            "imu0_sample_rate_hz":  200,
            "imu0_lp_cutoff_freq_hz":      92,
            "imu0_rotate_common_frame":     true,
            "imu0_fifo_poll_rate_hz":       200,
            Tested on 2 different VOXL2 boards, this reduces the number of lost messages sequences from 60% to <0.5% of all messages. Information on why this is the case would be interesting, as it is stated here that the default config is optimized for VIO.
            • tomT
              tom admin @tanguy sagere
              @tanguy-sagere I wonder if you upgrade to SDK 1.0 if the issue resolves itself
              • ModeratorM Moderator referenced this topic on
