    Camera server bug for config 6?
    • H
      hmlow
      Hi devs
      I just upgraded to SDK 1.0
      Is there a bug in voxl-camera-server when selecting config 6 (Hires(IMX214) + ToF + Tracking)?
      voxl-camera-server does not start and throws this:
      DEBUG:   ------ voxl-camera-server: Starting 3 cameras
      Starting Camera: tof
      DEBUG:   ----------- Number of cameras: 1
      DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
      VERBOSE: Successfully found configuration match for camera 0: 224x1557
      VERBOSE: Adding preview stream for camera: 0
      DEBUG:   ALIGNING HEIGHT FOR LARGE IMAGE
      DEBUG:   Allocating img Buffer: width:  224 stride:  224 height: 1557 slice: 2048 size:  688128
      DEBUG:   Successfully set up pipeline for stream: PREVIEW
      VERBOSE: Entered thread: cam0-request(tid: 2217)
      DEBUG:   Started Camera: tof
      Starting Camera: hires
      VERBOSE: Entered thread: cam0-result(tid: 2218)
      Segmentation fault:
      Fault thread: voxl-camera-ser(tid: 2196)
      Fault address: 0x567e5e26cc
      Address not mapped.
      VERBOSE: Found Royale module config: imagerType 2, illuminationConfig.dutyCycle: 4 temp_sensor_type: 5
      VERBOSE: Found Royale module config: maxImgW 224 maxImgH 172 frameTxMode 1 camName X1.1_850nm_2W
      VERBOSE: Found Royale module config: tempLimitSoft 60.000000 tempLimitHard 65.000000 autoExpoSupported yes
      VERBOSE: Found Royale usecase: MODE_9_5FPS - phases: 9 fps: 5
      VERBOSE: Found Royale usecase: MODE_9_5FPS - exposure group[0] = gray
      VERBOSE: Found Royale usecase: MODE_9_5FPS - exposure group[1] = mod1
      VERBOSE: Found Royale usecase: MODE_9_5FPS - exposure group[2] = mod2
      Segmentation fault
      When i flashed back to SDK 0.9.5, everything works.
      Flashed back to SDK 1.0 and the above shows up again.
      Pls help.
      H 1 Reply Last reply Reply Quote 0
      • H
        hmlow @hmlow
        @hmlow I'm using VOXL 2 btw
        • H
          hmlow @hmlow
          @hmlow
          Cameras connected as shown in C6
          https://docs.modalai.com/voxl2-camera-configs/#c6---hires--tof--tracking
          • adminA
            admin admin
            @hmlow ,
            Yes I think we flipped a camera config here inadvertently...
            Can you try this?
            vi /usr/bin/qrb5165-configure-cameras
            Change this:
            6) # D0005 Starling V2 Hires + TOF + Tracking
                            CAM_LIST+=("tof:pmd-tof:0")
                            CAM_LIST+=("hires:${HIRES_SENSOR}:1")
                            CAM_LIST+=("tracking:ov7251:2")
                            BIN_LIST+=("/usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin")
                            BIN_LIST+=("/usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin")
                            BIN_LIST+=("/usr/share/modalai/chi-cdk/${HIRES_SENSOR}/com.qti.sensormodule.${HIRES_SENSOR}_2.bin")
            to this
                            CAM_LIST+=("hires:${HIRES_SENSOR}:2")
                            CAM_LIST+=("tracking:ov7251:1")
                            BIN_LIST+=("/usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin")
                            BIN_LIST+=("/usr/share/modalai/chi-cdk/${HIRES_SENSOR}/com.qti.sensormodule.${HIRES_SENSOR}_3.bin")
            Just tried this on my setup:
            • H
              hmlow @admin
              @admin so i have been using this config 6 for the past week, and i am experiencing VIO faults randomly (CAM_MISSING STALLED showsup on QVIO overlay).
              Upon much trial and error i realized that voxl-camera-server was crashing randomly. Sometimes 3mins, sometimes 15mins, sometimes 30mins.
              I got voxl-camera-server run in debug mode and wait till it crashes, and this are the final few lines that i see:
              VERBOSE: Camera: tof processing preview frame
              VERBOSE: finished sending request for frame 1477 for camera tof
              VERBOSE: returning from SendOneCaptureRequest for frame 1478 for camera tof
              VERBOSE: added request for preview stream
              VERBOSE: Sending request for frame 1478 for camera tof for 1 streams
              VERBOSE: Received result from HAl3 for frame number 1477
              VERBOSE: Received 0 buffers from camera tof, partial result:1
              VERBOSE: Sent tof data to royale for processing
              VERBOSE: Received result from HAl3 for frame number 8847
              VERBOSE: Received 0 buffers from camera tracking, partial result:2
              VERBOSE: Received metadata for frame 8847 from camera tracking
              VERBOSE:        Timestamp: 1277332818009
              VERBOSE:        Gain: 169
              VERBOSE:        Exposure: 5184081
              VERBOSE: Received 1 buffers from camera tracking, partial result:0
              VERBOSE: Received output buffer 8847 from camera tracking
              VERBOSE: tracking procesing new buffer
              VERBOSE: Camera: tracking processing preview frame
              VERBOSE: Preview format HAL_PIXEL_FORMAT_RAW10
              VERBOSE: finished sending request for frame 8852 for camera tracking
              VERBOSE: returning from SendOneCaptureRequest for frame 8853 for camera tracking
              VERBOSE: Sending request for frame 8853 for camera tracking for 1 streams
              VERBOSE: Received result from HAl3 for frame number 8852
              VERBOSE: Received 0 buffers from camera tracking, partial result:1
              VERBOSE: Received royale data for camera: tof
              ERROR:   Received "Buffer" error from camera: tracking
              ERROR:   Received "Result" error from camera: tracking
              VERBOSE: Received result from HAl3 for frame number 8848
              VERBOSE: Received output buffer 8848 from camera tracking
              VERBOSE: Buffer arrive before meta frame 8848
              VERBOSE: finished sending request for frame 8853 for camera tracking
              VERBOSE: returning from SendOneCaptureRequest for frame 8854 for camera tracking
              VERBOSE: Sending request for frame 8854 for camera tracking for 1 streams
              VERBOSE: Received result from HAl3 for frame number 8853
              VERBOSE: Received result from HAl3 for frame number 1473
              VERBOSE: Received 0 buffers from camera tof, partial result:2
              VERBOSE: Received metadata for frame 1473 from camera tof
              VERBOSE:        Timestamp: 1277502314989
              VERBOSE:        Gain: 0
              VERBOSE:        Exposure: 0
              Aborted
              I am running cam config 6 (with the "fix" by @admin above) and i have swapped out the ToF and tracking cam module for new ones in case it was a camera or flex cable fault. But no, the problem is still there.
              This is SDK 1.0
              Can anyone advise?
              • A
                aashry @hmlow
                Hello @hmlow, have you been able to solve this issue? or are you still facing similar issues with the camera-server with sdk 1.0?
