LTE concurrent with Microhard
It is possible to run concurrent LTE and Microhard connections on VOXL.
This can be accomplished using a combination of the two modems, either with an add-on LTE modem and a standalone Microhard modem plugged in to the add-on or an add-on Microhard modem with a standalone LTE modem plugged in to the add-on.
In order for both networks to start correctly, the LTE network will need to be brought up first, then the Microhard network. This can be set up easily by creating a custom startup service.
The LTE network will use the
wwan0network interface while the Microhard network will use theeth0network interface.
