VOXL-ESC V2 : One of the ESC is not detected
I am using VOXL-ESC V2 along with VOXL2 on custom drone with Sentinel configuration with platform image 0.9.5 and PX4 version 1.12.31. I was able to operate ESC successfully but all of a sudden after updating of one of my parameter file on VOXL ESC, it stopped detecting ESC ID 2 out of 4 ESC's. Parameters were flashed properly for all four ESC initially and after reflashing of parameters again it stopped detecting one of the ESC. I am using voxl-esc tool from gitlab.Also I am using USB to TTL connector for connecting ESC with Host PC. Please see attached logs of voxl-esc-spin command../voxl-esc-spin.py --device /dev/ttyUSB0 --baud-rate 250000 --id 2 --power 15 --timeout 3 Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.2 Found previous connection information in .voxl_esc_cache .. Prioritizing /dev/ttyUSB0 @ 250000 INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000 INFO: ESC(s) detected on port: /dev/ttyUSB0, baud rate: 250000 ID : 0 Board : version 34: ModalAi 4-in-1 ESC (M0117-1) UID : 0x203034305743570C00270034 Firmware : version 38, hash 83faccfa Bootloader : version 183, hash 25317f42 ID : 1 Board : version 34: ModalAi 4-in-1 ESC (M0117-1) UID : 0x203034305743570C003A0054 Firmware : version 38, hash 83faccfa Bootloader : version 183, hash 25317f42 ID : 3 Board : version 34: ModalAi 4-in-1 ESC (M0117-1) UID : 0x203034305743570C00280028 Firmware : version 38, hash 83faccfa Bootloader : version 183, hash 25317f42 --------------------- ERROR: Specified ESC ID not found--exiting.Also check output of voxl-verify-param.py command as well
./voxl-esc-verify-params.py Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.2 INFO: All COM ports: /dev/ttyUSB0 : USB-Serial Controller INFO: UART Port Candidates: /dev/ttyUSB0 Found previous connection information in .voxl_esc_cache .. Prioritizing /dev/ttyUSB0 @ 250000 INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000 INFO: ESC(s) detected on port: /dev/ttyUSB0, baud rate: 250000 ERROR: ESC ID 2 not found ERROR: Some params are invalid or not the same! Number of ESCs expected : 4 Number of ESCs found : 3 Number of invalid params : 0 Number of matched params : 3Also during startup ESC ID 0, 1 and 3 LED blinks and only ESC ID 2 LED dosent blink with rest of the LED's. ESC ID 2 LED blinks after rest of the three LED have completed their blinking.
How to debug further what's wrong with ESC ID 2?
@Eric-Katzfey Any help on this problem?
It seems one of the ESCs failed to update the params correctly. The delayed blink (and sad beep) is an indication of this.
Not a big deal, we basically need to re-upload the param to the one ESC that had the issue.
If an ESC has corrupted params for some reason, it will go into a fault state and will default to UART baud rate of 57600. So we just need to force
voxl-esctools to communicate at that rate../voxl-esc-upload-params.py --params-file <path-to-your-params-file> --device /dev/ttyUSB0 --baud-rate 57600If this does not work, maybe try
--baud-rate 2000000-- did you use a different baud rate before?Can you please try that? After updating params, you can detect the ESCs using
./voxl-esc-scan.pyAlex
@Alex-Kushleyev This was very helpful thank you. I was able to reset a "sad beep" ESC with no problems
@swickliff , great! hopefully this is not an issue moving forward.
I would like to note the updated path for the ESC is
/dev/slpi-uart-2That is how I got this to work for me
I found this by running
./voxl-esc-scan.pyor
voxl-escand selecting detect...or scan I can not remember
