  3. m500 drone unable to find it on the wifi network
4 Posts 2 Posters 840 Views 1 Watching
  • Syed OmairS Offline
    Syed OmairS Offline
    Syed Omair
    I was trying to change the drone networking configuration from softAP mode to station mode and I think i successfully changed it but since I have done that It doesn't show up anymore and I can't connect to it. Can you tell me what I can do to reset it into softAP mode ? I was trying the hardware route. but I can't find the correct cable. If anyone can send me a good amazon link for a cable that works. or if any other way to reset the drone to default settings would be great or any other links to other posts that had the same problem or any resources from the documentation ? Anything would work.
    Thank you
    • Syed OmairS Syed Omair
      Thank you
      @Syed-Omair All you need to access the ADB shell is a micro usb cable
      https://docs.modalai.com/setup-adb/
      Syed OmairS 1 Reply Last reply
        Syed OmairS Offline
        Syed OmairS Offline
        Syed Omair
        @tom Thank you for the quick reply
        this is the cable right ? I am trying and I don't know where it will fit on the voxl board.
        thanks
          thanks
          @Syed-Omair This image here: https://docs.modalai.com/images/m500/vehicle-overview-right-144-1024.jpg
          shows where to look for the connector on m500, labeled "USB for VOXL (Under)"
