  3. Flights in confined dusty environments
3 Posts 2 Posters 691 Views 2 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    What settings will work for the VIO & VOA when flying in very dusty enviroments?
    Should I lower the detection limits?
    If so, would that be done for VIO, VOA, or both?
    I tried flying in a very confined dusty environment with VIO and VOA enabled.
    The distance for VOA was set at 40cm.
    The area I was flying in was about 10 feet by 10 feet.
    The drone would often drift towards the walls (very unstable flight).
    I would take off in position mode, and either directly after takeoff or soon after takeoff, it would switch to manual flight mode.
    Then I tried with only the VIO enabled and the drone would respond to any of my stick movements, only the thrust (ascend & descend) would respond.
    Are there any settings that would help with these type of flights?
      Unfortunately no, computer vision systems need features to operate
      KrisK 1 Reply Last reply
      • Chad SweetC Chad Sweet
        KrisK Offline
        KrisK Offline
        Kris
        @Chad-Sweet
        Ok, thank you. I understand.
