    Flights in confined dusty environments
    • KrisK
      Kris
      What settings will work for the VIO & VOA when flying in very dusty enviroments?
      Should I lower the detection limits?
      If so, would that be done for VIO, VOA, or both?
      I tried flying in a very confined dusty environment with VIO and VOA enabled.
      The distance for VOA was set at 40cm.
      The area I was flying in was about 10 feet by 10 feet.
      The drone would often drift towards the walls (very unstable flight).
      I would take off in position mode, and either directly after takeoff or soon after takeoff, it would switch to manual flight mode.
      Then I tried with only the VIO enabled and the drone would respond to any of my stick movements, only the thrust (ascend & descend) would respond.
      Are there any settings that would help with these type of flights?
      • Chad SweetC
        Chad Sweet ModalAI Team
        Unfortunately no, computer vision systems need features to operate
        KrisK 1 Reply Last reply Reply Quote 0
        • KrisK
          Kris @Chad Sweet
          @Chad-Sweet
          Ok, thank you. I understand.
