    No RTSP video feed through voxl-streamer on SEEKER drone.
    Seeker
    • nickyblanchN
      nickyblanch
      Hello all,
      First of all, thank you for reading this, I'm new to Linux based operating systems and ModalAI products, so I appreciate any help.
      The issue is that I cannot get any camera output over an RTSP stream using voxl-streamer on my SEEKER development drone. voxl-streamer is enabled and running, along with voxl-camera-server, although I have tried with voxl-camera-server disabled as well.
      Curiously, although I can start voxl-streamer without any issues, it seems that I can't configure this service. Any attempts to configure it will lock up until I hit CTRL + C and receive 'ERROR: Timeout on input parameter initialization.'
      All cameras are streaming their data to the VOXL Web Portal without issue. Neither VLC or QGroundControl can connect to rtsp://<ip>:8900/live. If it makes a difference, I am running the seeker in WiFi station mode connected to a common network with my laptop, so the IP address is not default (it's now 192.168.1.124 on my local network).
      Any ideas?
      Best,
      Nick B
      • nickyblanchN
        nickyblanch
        Below are the contents of /etc/modalai/voxl-streamer.conf. There's more in this file than I expected based on the documentation here. Should the port (8900) be explicitly stated in this file?
            "conf-version":"1.3",
            "configuration": "hires",
            "uvc-generic": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "uvc" },
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "decimator": 1,
                        "bitrate": 1000000 } }
            "uvc-flir-boson": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 512,
                        "decimator": 2,
            "uvc-flir-lepton": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 160,
                        "height": 120,
                        "bitrate": 500000 } }
            "hires": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "hires" },
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "hires-logo": {
                "input": {
                    "interface": "mpa",
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
                        "bitrate": 1000000 } },
                "overlay": {
                    "location": "/etc/modalai/modalai.png",
                    "offset_x": -1,
                    "offset_y": -1 }
            "stereo": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "stereo" },
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 960,
                        "decimator": 2,
            "tracking": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "tracking" },
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "dfs-disparity": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "dfs_disparity" },
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "qvio-overlay": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "qvio_overlay" },
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 544,
                        "decimator": 2,
            "tflite-overlay": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "tflite" },
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 480,
                        "decimator": 2,
            "hdmi-mpa": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "v4l2" },
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 360,
                        "decimator": 2,
            "gphoto2-mpa": {
                "input": {
                    "interface": "mpa",
                    "mpa-camera": "gphoto2" },
                "output": {
                    "stream": {
                        "width": 640,
                        "height": 360,
                        "decimator": 2,
            "video-test": {
                "input": {
                    "interface": "test",
                    "frame": {
                        "width": 640,
                        "height": 480,
                        "format": "yuv420" } },
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 480,
                        "rate": 30,
            "uvc-video": {
                "input": {
                    "interface": "uvc",
                    "device": "/dev/video0" },
                "output": {
                    "stream": {
                        "rotation": 0,
                        "width": 640,
                        "height": 360,
                        "rate": 15,
        • tomT
          tom admin
          @Nicolas-Ethan-Blanchard What software versions are you running?: voxl-version
          nickyblanchN 1 Reply Last reply Reply Quote 0
          • nickyblanchN
            nickyblanch @tom
            @tom Hi Tom,
            Thank you for your response. I am running the following software versions:
            / # voxl-version
            system-image: 3.8.0
            kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
            hw version:   VOXL
            voxl-suite:   0.7.0
            I also have a second, fresh out of the box Seeker drone that I'm testing. I haven't had as much time to work with this one, so I'm continuing to troubleshoot the video stream, but at the moment I'm not able to get an RTSP stream after configuring, enabling, and starting voxl-streamer. This new seeker has the following software versions:
            / # voxl-version
            system-image: 4.0.0
            kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
            hw version:   VOXL
            voxl-suite:   0.9.5
            Packages:
            Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
            Last Updated: stat: cannot stat '/var/lib/opkg/lists/modalai': No such file or directory
            List:
                    apq8096-dfs-server       0.3.1
                    apq8096-imu-server       1.0.3
                    apq8096-libpng           1.6.38-1
                    apq8096-system-tweaks    0.1.3
                    apq8096-tflite           2.8.3-1
                    libapq8096-io            0.6.0
                    libmodal-cv              0.2.3
                    libmodal-exposure        0.0.7
                    libmodal-journal         0.2.1
                    libmodal-json            0.4.3
                    libmodal-pipe            2.8.2
                    libvoxl-cci-direct       0.1.5
                    libvoxl-cutils           0.1.1
                    voxl-camera-calibration  0.2.3
                    voxl-camera-server       1.3.5
                    voxl-cpu-monitor         0.3.0
                    voxl-docker-support      1.2.4
                    voxl-gphoto2-server      0.0.10
                    voxl-jpeg-turbo          2.1.3-4
                    voxl-libgphoto2          0.0.4
                    voxl-libuvc              1.0.7
                    voxl-logger              0.3.4
                    voxl-mavlink             0.1.0
                    voxl-mavlink-server      0.3.0
                    voxl-modem               0.16.1
                    voxl-mongoose            7.7.0-1
                    voxl-mpa-to-ros          0.3.6
                    voxl-mpa-tools           0.7.6
                    voxl-opencv              4.5.5-1
                    voxl-portal              0.5.0
                    voxl-qvio-server         0.8.2
                    voxl-streamer            0.4.1
                    voxl-suite               0.9.5
                    voxl-system-image        4.0-r0
                    voxl-tag-detector        0.0.4
                    voxl-tflite-server       0.3.1
                    voxl-utils               1.2.2
                    voxl-uvc-server          0.1.3
                    voxl-vision-px4          1.4.0
                    voxl-vpn                 0.0.6
            • nickyblanchN
              nickyblanch @nickyblanch
              @Nicolas-Ethan-Blanchard I got the video stream to work on the drone running voxl-suite 0.9.5; I simply needed to re-configure voxl-camera-server and change the input pipe for voxl-streamer, not a problem at all. No luck on the other drone though.
              • tomT
                tom admin
                @Nicolas-Ethan-Blanchard I would recommend getting the other drone on 0.9.5 as well. There's some major differences between those two releases so I think it would make your life easier.
                • nickyblanchN
                  nickyblanch @tom
                  @tom Apologies for the delayed response, but I took your suggestion and had better luck on 0.9.5. Thanks!
