    Drone does not switch to Position mode indoors
    Seeker
    1514
    • Umut JohnU
      Umut John
      We have just received a pair of Seeker drones. One of them works flawlessly indoors (w/ Vision enabled, w/o GPS); however, the other does not switch to the Position mode under the same circumstances, regardless of our efforts. It can switch to Manual, Altitude, and Stabilized modes, though. I made sure that the parameters were the same by exporting/importing; and made the calibrations as well. What else should be considered?
      Best
      • Adrian HidalgoA
        Adrian Hidalgo ModalAI Team
        @Umut-John Sorry to hear you're having troubles with one of your Seekers. Let's see what we can do to remedy that.
        First off, some questions to get a baseline where we're sittin.
        Was any custom software loaded?
        Have you configured MPA?
        When I see that the Seeker doesn't go into Position mode, VIO hasn't started or didn't start properly.
        Can you post the result of:
        voxl-inspect-services
        What software are you utilizing?
        voxl-version
        If you look at local position ned in QGC(Q Ground Control) What does the X and Y data show? If they're zeroed out, then you will have to restart VIO. To get to local position ned, open QGC, navigate to analyze, mavlink inspector, local position ned.
        Umut JohnU 1 Reply Last reply Reply Quote 0
        • Umut JohnU
          Umut John @Adrian Hidalgo
          • Umut JohnU
            Umut John
            Hello Adrian, thanks for the prompt response. There is no custom software/hardware. Configuring MPA didn't seem to help either. And here is the output of "voxl-inspect-services" command:
            docker-autorun       | Disabled  | Not Running |
            docker-daemon        | Disabled  | Not Running |
            voxl-camera-server   |  Enabled  |   Running   |    23.5
            voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
            voxl-dfs-server      | Disabled  | Not Running |
            voxl-imu-server      |  Enabled  |   Running   |     0.0
            voxl-mavlink-server  |  Enabled  |   Running   |     1.8
            voxl-qvio-server     |  Enabled  |   Running   |     1.8
            voxl-tag-detector    | Disabled  | Not Running |
            voxl-vision-px4      |  Enabled  |   Running   |     1.8
            And here is the output for "voxl-version":
            system-image: 4.0.0
            kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
            hw version:   VOXL
            voxl-suite:   0.9.5
            Packages:
            Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
            Last Updated: stat: cannot stat '/var/lib/opkg/lists/modalai': No such file or directory
            List:
                    apq8096-dfs-server       0.3.1
                    apq8096-imu-server       1.0.3
                    apq8096-libpng           1.6.38-1
                    apq8096-system-tweaks    0.1.3
                    apq8096-tflite           2.8.3-1
                    libapq8096-io            0.6.0
                    libmodal-cv              0.2.3
                    libmodal-exposure        0.0.7
                    libmodal-journal         0.2.1
                    libmodal-json            0.4.3
                    libmodal-pipe            2.8.2
                    libvoxl-cci-direct       0.1.5
                    libvoxl-cutils           0.1.1
                    voxl-camera-calibration  0.2.3
                    voxl-camera-server       1.3.5
                    voxl-cpu-monitor         0.3.0
                    voxl-docker-support      1.2.4
                    voxl-gphoto2-server      0.0.10
                    voxl-jpeg-turbo          2.1.3-4
                    voxl-libgphoto2          0.0.4
                    voxl-libuvc              1.0.7
                    voxl-logger              0.3.4
                    voxl-mavlink             0.1.0
                    voxl-mavlink-server      0.3.0
                    voxl-modem               0.16.1
                    voxl-mongoose            7.7.0-1
                    voxl-mpa-to-ros          0.3.6
                    voxl-mpa-tools           0.7.6
                    voxl-opencv              4.5.5-1
                    voxl-portal              0.5.0
                    voxl-qvio-server         0.8.2
                    voxl-streamer            0.4.1
                    voxl-suite               0.9.5
                    voxl-system-image        4.0-r0
                    voxl-tag-detector        0.0.4
                    voxl-tflite-server       0.3.1
                    voxl-utils               1.2.2
                    voxl-uvc-server          0.1.3
                    voxl-vision-px4          1.4.0
                    voxl-vpn                 0.0.6
            Finally, there is no Local Position NED tab in the MAVlink Analyzer Tool in QGC.
            By the way, "voxl-qvio-inspect" command gives the following output:
            waiting for server
             dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state| error_codes |
               30.3 |    0.00    0.00    0.00|   0.0   -0.0    0.0|     0  |   -1% | FAIL | CAM_MISSING STALLED
            • Adrian HidalgoA
              @Umut-John can you try restarting the voxl-vision-px4 service and qvio server?
              systemctl restart voxl-vision-px4
              systemctl restart voxl-qvio-server
              • Umut JohnU
                Umut John
                Tried both multiple times, no changes, unfortunately. I'd like to add that in the VOXL Portal, there are no camera streams for the tracking cam and Qvio overlay channels (which are all black), although stereo cams and tof streams seem to work.
                • Adrian HidalgoA
                  @Umut-John that's interesting. Do any of the other cameras come up in Portal?
                  Can you post the print out of
                  camera-test
                  Which camera config do you have on your Seeker? Does it have the TOF or Hi-Res?
                  You may want to try configuring the cameras.
                  It's interesting that the tracking camera is not showing up. The Seekers are test flown and tested before shipping out.
                  • Umut JohnU
                    Umut John
                    Stereo cameras and Tof streams work, but not the tracking. "camera-test" returns the following:
                    num_cameras = 4
                    Testing camera id=0
                    camera-test: /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-qmmf-sdk/git-r0/qmmf-sdk/recorder/src/client/qmmf_recorder.cc:326: qmmf::recorder::status_t qmmf::recorder::Recorder::DeleteVideoTrack(uint32_t, uint32_t): Assertion `recorder_client_ != __null' failed.
                    Aborted
                    And this is what I see in the portal:
                    • Adrian HidalgoA
                      @Umut-John hmm. One more thing to check; is there a lens cap on the tracking camera?
                      It does look like the camera is detected
                      • Umut JohnU
                        Umut John
                        OMG! The protective cap on the camera 😬
                        You're right! Just saw it minutes before checking it here. There was no cap on the first drone; it was probably dropped or something, so I did not even feel the need to look for it.
                        Thank you, Adrian; sorry for the trouble. Case closed!
