    VOXL2 difficulty in connecting to WiFi
    • R
      rohitpillai
      I am attempting to connect to the WiFi using the Microhard Add-on board and the ALFA wifi dongle connected to the board using the JST USBA adapter. However, when I do voxl-wifi station <SSID> <Password>. Nothing happens. No IP address is being seen under wlan0when I do ifconfig. I made sure the SSID and password are correct. Is this a known issue recently cause I don't remember having this much trouble before. This is a brand new VOXL2 board running 0.9.5.
      • modaltbM
        modaltb ModalAI Team
        Hi @rohitpillai ,
        Sorry for the lag, no this isn't a known issue with WiFi, are you still experiencing issues with this?
        • R
          rohitpillai
          Yep. It seems to be random. We tried different WiFi dongles and while it would fix the issue temporarily. It would cause issues a few days later.
          Siyu ChenS 1 Reply Last reply Reply Quote 0
          • Siyu ChenS
            Siyu Chen @rohitpillai
            @rohitpillai Maybe use directly the name of the AP instead of the SSID?
            • R
              rohitpillai
              I found out that the WiFi dongles were broken which is what was causing the issue 🙂
