    mpa_to_ros publish stereo left and right image in different timestamp
    • Dong LiuD
      Dong Liu
      Here is the code,
      imgL.header.stamp = (_clock_monotonic_to_ros_time(meta.timestamp_ns));
      imgL.width    = meta.width;
      imgL.height   = meta.height;
      imgL.step     = meta.width;
      imgL.encoding = GetRosFormat(meta.format);
      imgR.header.stamp = (_clock_monotonic_to_ros_time(meta.timestamp_ns));
      imgR.width    = meta.width;
      imgR.height   = meta.height;
      imgR.step     = meta.width;
      imgR.encoding = GetRosFormat(meta.format);
      They are all from meta.timestamp_ns, but _clock_monotonic_to_ros is using the current time, so the final times are slight different.
      I think it should be
      imgR.header.stamp = imgL.header.stamp
      • Chad SweetC
        Chad Sweet ModalAI Team
        Thanks for the suggestion! We are happy to incorporate our partners merge requests if you want to make one on gitlab!
        • Dong LiuD
          Dong Liu
          will do soon.
          • Dong LiuD
            Dong Liu
            MR submitted.
            • Dong LiuD
              Dong Liu
              Just tried to calibrated the stereo camera using ROS camera calibrator. Had to run the fixed voxl-mpa-to-ros. Because the ROS calibrator expects left and right to be exactly synchronized.
