  3. m500 ROS
m500 ROS
3 Posts 3 Posters 446 Views 1 Watching
  • S Offline
    S Offline
    sesem738
    Hi team:
    Following the procedure from “How to Run MAVROS on VOXL with PX4” we successfully get in to the process of testing mavros in off board flight mode.
    When it runs, it show warning that:
    [ WARN] [1162.141889870]: CMD: Unexpected command 520, result 0
    [ INFO] [1164.120257369]: waiting for offboard mode
    [ INFO] [1171.123370231]: HP: requesting home position
    [ INFO] [1176.127489500]: WP: mission received
    [ INFO] [1181.123081373]: HP: requesting home position
    How can we get position from the drone?
      Have you seen voxl-mpa-to-ros? https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros
      That might help?
      • T Offline
        T Offline
        TPSetati
        Good day
        We are working on a Sentinel with VOXL2 and are getting a similar CMD warning as well as similar INFO logs. The documentation for VOXL MPA to ROS says "Coming soon", so does the voxl-mpa-to-ros package also work for VOXL2 on Sentinel?
