  3. vehicle did not respond to command: MAV_CMD_DO_MOTOR_TEST
5 Posts 2 Posters 1.8k Views 1 Watching
  • S Offline
    S Offline
    suvasis
    I connected the qgroundcontrol. I see the parameters set correctly. However, when doing motor testing I see the message pops up:
    How do I resolve this?
    Thanks.
    suvasis
    • S suvasis
      Thanks.
      suvasis
      Eric KatzfeyE Online
      @suvasis Can you explain a little bit about the products you are using? Is this on Flight Core or on VOXL2?
      • S Offline
        S Offline
        suvasis
        I bought calibrated voxl2 and 4-in-1 esc separately and attached to my own holybro drone. I wired up the esc and voxl2.
        1. All the motor testing works fine as the result shows below:
        2. after the test,
          #when done, restore original libpx4.so
          cd /usr/lib/rfsa/adsp
          rm libpx4.so
          cp libpx4.so.bak libpx4.so
          systemctl enable voxl-px4
          reboot
        I started the QGC, i see the sensor details etc. Here i click on the motors on the left side of QGC, then I start motors one by one. after a min or so i see "vehicle did not respond to command: MAV_CMD_DO_MOTOR_TEST" this message and motor never works this way.
        Is there more settings required here as per, modalai documentation doesn't point to this though https://docs.qgroundcontrol.com/master/en/SettingsView/General.html?
        Or there any missing information? The modalai documentation is not clear at this stage, https://docs.modalai.com/voxl2-px4-quickstart/.
        motor testing Test results:
        Installation Instructions for VOXL2
        #stop and disable PX4 while using voxl-esc tools
        systemctl stop voxl-px4 && systemctl disable voxl-px4
        #temporarily move libpx4.so and create symlink for slpi bridge to libpx4.so
        #this is required because currently the slpi application loader looks for libpx4.so (hardcoded)
        mv libpx4.so libpx4.so.bak
        ln -s ./libslpi_uart_bridge_slpi.so ./libpx4.so
        #reboot VOXL2
        reboot
        Looks now it works after I re-did the steps:
        result:
        voxl2:~$
        voxl2:~$ cd /usr/lib/rfsa/adsp
        voxl2:/usr/lib/rfsa/adsp$ ls -l libpx4.so
        lrwxrwxrwx 1 root root 29 Mar 16 17:41 libpx4.so -> ./libslpi_uart_bridge_slpi.so
        voxl2:/usr/lib/rfsa/adsp$ cd
        voxl2:~$ pwd
        /home/root
        voxl2:~$ cd voxl-esc/tools/
        voxl2:~/voxl-esc/tools(dev-python3)$ ./voxl-esc-scan.py
        Detected Python version : 3.6.9 (default, Jun 29 2022, 11:45:57)
        [GCC 8.4.0]
        Found voxl-esc tools bin version: 1.1
        VOXL Platform: M0054
        Detected VOXL2 M0054 or M0104!
        INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 250000
        INFO: Detected protocol: firmware
        INFO: Additional Information:
        INFO: ---------------------
        Board : version 34: ModalAi 4-in-1 ESC V2 RevC (M0117)
        UID : 0x203034305743570C00360052
        Firmware : version 36, hash f75f1fdb
        Bootloader : version 183, hash 25317f42
        UID : 0x203034305743570C0036004C
        UID : 0x203034305743570C0036004B
        UID : 0x203034305743570C0042001C
        • S Offline
          S Offline
          suvasis
          hi Eric,
          Is there any update on the issue?
          Thanks.
          suvasis
          • S suvasis
            hi Eric,
            Thanks.
            suvasis
            @suvasis Unfortunately, motor testing using the QGC motors tab is not supported on VOXL2.
