  3. VOXL 2 I/O and GPS
VOXL 2 I/O and GPS
Scheduled Pinned Locked Moved VOXL 2 and VOXL 2 Mini
voxl-2-io
2 Posts 2 Posters 899 Views
  • ModeratorM Offline
    I'm attempting to set up a system that will use both the M8N GPS and the IO expansion board. However, they each seem to take up the same connector, J19, on the VOXL 2. Is there a cable that allows both to be connected at the same time? If not, can I make my own connector? If so, what is the make/model of the connectors used on the VOXL 2. Any info is appreciated.
    VinnyV 1 Reply Last reply
    • ModeratorM Moderator
      VinnyV Offline
      VinnyV Offline
      Vinny
      @Moderator Yes, we can build a custom one and get it listed soon.
      However, in the meantime, you can start with our MCBL-00061 and add in additional contacts needed for the uBlox module.
      Here is MCBL-00061:
      https://docs.modalai.com/cable-datasheets/#mcbl-00061
      and a purchase link: https://www.modalai.com/products/mcbl-00061
      and then you can follow the tips here to help you add in extra contacts and the shroud for your uBlox module (we are making more updates to this site weekly)
      https://docs.modalai.com/cable-userguides/
      Let us know if this helps!!
      • V valvarez referenced this topic on
