  3. Voxl2/Microhard/NV Trip 2
29 Posts 6 Posters 7.9k Views 2 Watching
  • M Offline
    M Offline
    McMason
    @Vinny , made the decision to just go with MH for better downrange reception.
    Is there a guide or anything you can point me too that would be a good start to set up a non MIPI camera? it will be connected via ETH from the trip2
    I would be ecstatic if it were as simple as voxl-configure-cameras lol.
    VinnyV 1 Reply Last reply
    • M McMason
      VinnyV Offline
      VinnyV Offline
      Vinny
      @McMason
      Sorry, I'll have to tag team this one off to @tom or someone else from software...
      Not sure how the USB based cameras show up different (if they do) from MIPI based cameras.
      Keep us posted!!
      • M Offline
        M Offline
        McMason
        Will do @Vinny thank you again
        • tomT Offline
          @McMason For normal USB cameras (UVC), we use voxl-uvc-server. However, we haven't tested an ethernet to USB camera so I'm not sure how much guidance we'll be able to provide there.
          • M Offline
            M Offline
            McMason
            wrote on last edited by McMason
            #25
            @vinny Is there any other VREG_S4A_1P8V test pads beside TP21 i can get power from on the bottom of the MH carrier? I put a meter to verify power and wasnt getting voltage out
            • M McMason
              VinnyV Offline
              VinnyV Offline
              Vinny
              @McMason
              TP21 is it unfortunately.
              All the rest are component pads which can easily break something. Right next to it is TP17 which is a GND.
              This is only present on the "plug-in" version FYI (even if it's obvious, I need to say it) and it's not present on the dongle based versions (but in which case you can't have access to the UART either).
              • M Offline
                M Offline
                McMason
                @Vinny Thank you. Looks like ill be getting something on order soon.
                • R Offline
                  R Offline
                  rogerli
                  Hello @McMason ,
                  Have you successfully connected VOXL2 and NV Trip2? Currently, I am using Ethernet and the Microhard Add-on board to connect VOXL2 and NV Trip2, and I can confirm successful connection using the ping command. However, I am unable to perform image transmission. Do you have any suggestions on how to resolve this issue?
                  • R rogerli
                    Hello @McMason ,
                    Chase RileyC Offline
                    Chase Riley
                    @rogerli or @McMason Were either of you successful in getting the VOXL2 to connect to the NV Trip2? Working the same issue on my end.
