  3. Voxl2/Microhard/NV Trip 2
voxl-2
29 Posts 6 Posters 8.1k Views 2 Watching
  • M McMason
    Nevermind its the 4gLte carrier.
    Hi @McMason
    Of course, we want you to be successful!!
    That 4G modem board works just like the Microhard boards we have... you have the same USB hub and the same VBUS capabilities, and you do not need to install a modem to get that functionality.
    Hope that helps!
    • M Offline
      M Offline
      McMason
      @Vinny , made the decision to just go with MH for better downrange reception.
      Is there a guide or anything you can point me too that would be a good start to set up a non MIPI camera? it will be connected via ETH from the trip2
      I would be ecstatic if it were as simple as voxl-configure-cameras lol.
      VinnyV 1 Reply Last reply
      • M McMason
        @McMason
        Sorry, I'll have to tag team this one off to @tom or someone else from software...
        Not sure how the USB based cameras show up different (if they do) from MIPI based cameras.
        Keep us posted!!
        • M Offline
          M Offline
          McMason
          Will do @Vinny thank you again
            @McMason For normal USB cameras (UVC), we use voxl-uvc-server. However, we haven't tested an ethernet to USB camera so I'm not sure how much guidance we'll be able to provide there.
            • M Offline
              M Offline
              McMason
              wrote on last edited by McMason
              #25
              @vinny Is there any other VREG_S4A_1P8V test pads beside TP21 i can get power from on the bottom of the MH carrier? I put a meter to verify power and wasnt getting voltage out
              • M McMason
                @McMason
                TP21 is it unfortunately.
                All the rest are component pads which can easily break something. Right next to it is TP17 which is a GND.
                This is only present on the "plug-in" version FYI (even if it's obvious, I need to say it) and it's not present on the dongle based versions (but in which case you can't have access to the UART either).
                • M Offline
                  M Offline
                  McMason
                  @Vinny Thank you. Looks like ill be getting something on order soon.
                  • R Offline
                    R Offline
                    rogerli
                    Hello @McMason ,
                    Have you successfully connected VOXL2 and NV Trip2? Currently, I am using Ethernet and the Microhard Add-on board to connect VOXL2 and NV Trip2, and I can confirm successful connection using the ping command. However, I am unable to perform image transmission. Do you have any suggestions on how to resolve this issue?
                    • R rogerli
                      Hello @McMason ,
                      Chase RileyC Offline
                      Chase Riley
                      @rogerli or @McMason Were either of you successful in getting the VOXL2 to connect to the NV Trip2? Working the same issue on my end.
