  3. Can't update Flight Core v2 FW using QGC
Scheduled Pinned Locked Moved Flight Core and Legacy VOXL
flight-core-v2
3 Posts 3 Posters 822 Views 3 Watching
    When attempting to update the Flight Core v2 firmware with QGC 4.2.x (perhaps other versions as well) on Ubuntu or OSX, the upgrade always fails with a warning like:
    As a work around, you can upgrade over the same USB port using a simple python script from the PX4 Tools that are maintained by the PX4 community. Please see info here:
    https://docs.modalai.com/flight-core-v2-firmware/#how-to-upgrade-using-px_uploader-tool
    • modaltbM modaltb
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      @modaltb Which is the default port flightcore V2 connects to? In may case I'm using Ubuntu 20 distro.
      • Jetson NanoJ Jetson Nano
        @Jetson-Nano Each host pc will be different depending on what peripherals you have plugged in. Run sudo dmesg -wH and plug in your flight core, you should see which port it enumerates on in the dmesg output
