  3. VOXL2 IMU Server Not Running
2 Posts 2 Posters 501 Views 1 Watching
  • B Offline
    B Offline
    bendraper
    I'm following along with the Voxl 2 Hardware Setup documentation and have an issue with the imu server not starting. I can issue the voxl-imu-server imu0 command and the output looks fine with the exception that it starts with
    "Unit imu_app.service could not be found"
    When issuing the voxl-inspect-imu imu0 command, the output is
    "waiting for server at /run/mpa/imu0/"
    If I go to the path /run/mpa/, the only contents are hires, imu_apps, stereo, and tracking.
    My voxl-version output is as follows...
    system-image: 1.2.1-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Mon Apr 18 20:36:27 UTC 2022 4.19.125
    hw version:   M0054
    voxl-suite:   0.7.0
    and my voxl-inspect-services output is as follows...
    docker-autorun       | Disabled  | Not Running |
    docker-daemon        | Disabled  | Not Running |
    voxl-camera-server   |  Enabled  |   Running   |     0.0
    voxl-cpu-monitor     | Disabled  | Not Running |
    voxl-dfs-server      | Disabled  | Not Running |
    voxl-imu-server      |  Enabled  | Not Running |
    voxl-mavlink-server  | Disabled  | Not Running |
    voxl-portal          | Disabled  | Not Running |
    voxl-px4-imu-server  | Disabled  | Not Running |
    voxl-px4             |  Enabled  |   Running   |     0.0
    voxl-qvio-server     | Disabled  | Not Running |
    voxl-static-ip       | Disabled  | Not Running |
    voxl-tag-detector    | Disabled  | Not Running |
    voxl-vision-px4      | Disabled  | Not Running |
    Any help would be appreciated!
      It is probably worth upgrading the software to the latest release. The version you have is really old. I guess I can't say for sure that it will fix the problem, but it's likely to match the docs better for getting going 🙂
      https://docs.modalai.com/voxl2-system-image/
