How to calibrate modalai esc v2 Rev B ?
Thanks @Chad-Sweet
I am having this issuetamas@tamas:~/Develop/voxl-esc/tools$ python2.7 voxl-esc-scan.py Traceback (most recent call last): File "voxl-esc-scan.py", line 37, in <module> from libesc import * File "tools/libesc/__init__.py", line 8, in <module> File "tools/libesc/esc.py", line 8, in <module> ImportError: No module named numpy tamas@tamas:~/Develop/voxl-esc/tools$ python3 voxl-esc-scan.py File "/home/tamas/Develop/voxl-esc/tools/voxl-esc-scan.py", line 49 print 'ERROR: Please provide baud rate with --baud-rate option' ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ SyntaxError: Missing parentheses in call to 'print'. Did you mean print(...)?How to fix it?
Also, the current tools are supported on python 2.7 only but we are working on update for python 3
@Alex-Kushleyev Do I have calibrate the esc to fly voxl2 based quad?
ESC calibration is required whenever you change motor or propeller or battery voltage. Do you have a custom quadrotor or was it pre-built when you purchased it with VOXL2?
@Alex-Kushleyev I am making a quadcopter with voxl2 and the modalai esc. I am trying to calibrate the esc. I am able to run the script but having this issue while scanning the esc with ftdi cable although I am able to run the motors with voxl2 J18 port.
/voxl-esc/tools$ python voxl-esc-scan.py INFO: Device and baud rate are not provided, attempting to autodetect.. Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000 Scanning for ESC firmware: /dev/ttyUSB0, baud: 2000000 Scanning for ESC firmware: /dev/ttyUSB0, baud: 921600 Scanning for ESC firmware: /dev/ttyUSB0, baud: 57600 Scanning for ESC firmware: /dev/ttyUSB0, baud: 115200 Scanning for ESC firmware: /dev/ttyUSB0, baud: 230400 Scanning for ESC bootloader: /dev/ttyUSB0, baud: 38400 Scanning for ESC bootloader: /dev/ttyUSB0, baud: 230400 Scanning for ESC bootloader: /dev/ttyUSB0, baud: 921600 ERROR: No ESC(s) detected, exiting.Is there any way to calibrate esc using voxl2?
