    How to calibrate modalai esc v2 Rev B ?
    239
    • T
      Tamas Pal 0
      • C
        Chad Sweet ModalAI Team
        https://docs.modalai.com/modal-esc-v2-manual/#calibration
        T 1 Reply Last reply 3 Nov 2022, 09:30 Reply Quote 0
        • T
          Tamas Pal 0 @Chad Sweet
          Thanks @Chad-Sweet
          I am having this issue
          tamas@tamas:~/Develop/voxl-esc/tools$ python2.7 voxl-esc-scan.py
          Traceback (most recent call last):
            File "voxl-esc-scan.py", line 37, in <module>
              from libesc import *
            File "tools/libesc/__init__.py", line 8, in <module>
            File "tools/libesc/esc.py", line 8, in <module>
          ImportError: No module named numpy
          tamas@tamas:~/Develop/voxl-esc/tools$ python3 voxl-esc-scan.py
            File "/home/tamas/Develop/voxl-esc/tools/voxl-esc-scan.py", line 49
              print 'ERROR: Please provide baud rate with --baud-rate option'
          SyntaxError: Missing parentheses in call to 'print'. Did you mean print(...)?
          How to fix it?
          • A
            Alex Kushleyev ModalAI Team
            https://gitlab.com/voxl-public/flight-core-px4/voxl-esc/-/tree/master/tools#installation-instructions-for-ubuntu-1604 Please check these steps
            • A
              Also, the current tools are supported on python 2.7 only but we are working on update for python 3
              T 1 Reply Last reply 7 Nov 2022, 14:18 Reply Quote 0
              • T
                Tamas Pal 0 @Alex Kushleyev
                @Alex-Kushleyev Do I have calibrate the esc to fly voxl2 based quad?
                • A
                  ESC calibration is required whenever you change motor or propeller or battery voltage. Do you have a custom quadrotor or was it pre-built when you purchased it with VOXL2?
                  T 1 Reply Last reply 8 Nov 2022, 09:16 Reply Quote 0
                  • T
                    @Alex-Kushleyev I am making a quadcopter with voxl2 and the modalai esc. I am trying to calibrate the esc. I am able to run the script but having this issue while scanning the esc with ftdi cable although I am able to run the motors with voxl2 J18 port.
                    /voxl-esc/tools$ python voxl-esc-scan.py
                    INFO: Device and baud rate are not provided, attempting to autodetect..
                    Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000
                    Scanning for ESC firmware: /dev/ttyUSB0, baud: 2000000
                    Scanning for ESC firmware: /dev/ttyUSB0, baud: 921600
                    Scanning for ESC firmware: /dev/ttyUSB0, baud: 57600
                    Scanning for ESC firmware: /dev/ttyUSB0, baud: 115200
                    Scanning for ESC firmware: /dev/ttyUSB0, baud: 230400
                    Scanning for ESC bootloader: /dev/ttyUSB0, baud: 38400
                    Scanning for ESC bootloader: /dev/ttyUSB0, baud: 230400
                    Scanning for ESC bootloader: /dev/ttyUSB0, baud: 921600
                    ERROR: No ESC(s) detected, exiting.
                    Is there any way to calibrate esc using voxl2?
                    1 out of 8
