  3. USB2.0 to Ethernet
USB2.0 to Ethernet
voxl
8 Posts 3 Posters 1.1k Views 2 Watching
  • Rowin LeemeijerR Offline
    Rowin Leemeijer
    I want to use the USB2.0 port on the expansion board to route ethernet. This sort of works in our current setup, but when pinging it randomly stops and says "Request timed out" after that it continues pinging fine until another "Request timed out". I've tried another device instead of the VOXL and that works perfectly with the same setup.
    Anyone knows what could be causing an issue?
    • Rowin LeemeijerR Rowin Leemeijer
      @Rowin-Leemeijer Which Ethernet dongle are you using?
        Rowin Leemeijer
        I've tried several, here's a few ones:
        UGreen
        UGreen
        UGreen
          UGreen
          UGreen
          UGreen
          @Rowin-Leemeijer In our documentation (https://docs.modalai.com/usb-to-ethernet-with-voxl/) we recommend this one: https://www.amazon.com/Apple-MC704LL-A-Ethernet-Adapter/dp/B00W7W9FK0/ref=sr_1_3?keywords=usb+to+ethernet+apple&qid=1575492214&s=electronics&sr=1-3
            Rowin Leemeijer
            @Eric-Katzfey That works, thanks. Are you guys testing any alternatives? As it seems the apple adapter is not widely available anymore.
            • tomT Offline
              @Rowin-Leemeijer We've also used these
                Rowin Leemeijer
                The ones I linked or did you mean other ones? @tom
                • tomT Offline
                  @Rowin-Leemeijer Oops forgot to stop the link: https://www.cablecreation.com/collections/usb-2-0-3-0/products/usb-ethernet-adapter
