  3. connecting Voxl cam and pixhawk cube
8 Posts 3 Posters 1.5k Views 1 Watching
  • H Offline
    H Offline
    howard
    hey,
    I want to use voxl cam with a external flight controller like pixhawk cube via TELEM2 , I have configured EKF2 parameters (EKF2_AID_MASK=280 and EKF2_HGT_MODE=3) for VIO and have verified MAV_1_CONFIG and other things, I do get Odometry values .But when I switch to HITL , Odometry disappears and also ekf2 status return invalid local position. Do you think it is a firmware issue? what could be wrong?
    Is it a good idea to connect external px4?
    • H howard
      hey,
      @keil In HITL you would want odometry to be coming from the simulation. What simulator are you using?
      H 1 Reply Last reply
        H Offline
        H Offline
        howard
        @Eric-Katzfey I am using gazebo
        • H howard
          @keil Okay, gazebo can support odometry. But you will need to configure it properly to do so.
            H Offline
            H Offline
            howard
            @Eric-Katzfey okay can you please provide any reference for that ? Would be really helpful, meanwhile I will also try to search
            Thank you
            • Zachary LowellZ Offline
              Zachary Lowell
              @keil odomotry should be out the box via gazebo. A minor edit needs to be changed inside PX4-Autopilot. Please do the following:
              1. Move into the PX4-Autopilot/Tools/sitl_gazebo/models/iris_vision directory and edit the following file: iris_vision.sdf
              2. Within this file change the following line: <uri>model://iris</uri> TO <uri>model://iris_hitl</uri>
              3. Once this edit has been made, run the following:
                make px4_sitl_default gazebo_iris_vision
              That will build a gazebo environment with a hitl iris that leverages vision to run VIO - AKA this will return odometry data.
              • Zachary LowellZ Zachary Lowell
                H Offline
                H Offline
                howard
                @Zachary-Lowell thanks a lot, will surely try
                • H Offline
                  H Offline
                  howard
                  wrote on last edited by howard
