  2. VOXL Compute & Autopilot
  3. VOXL Flight
  4. QGC connection problem
Scheduled Pinned Locked Moved VOXL Flight
4 Posts 2 Posters 836 Views 2 Watching
  • Caleb RievleyC Offline
    Caleb Rievley
    We had the flight controller lose connection to the ESC's
    To fix that I tried to redownload parameters.
    We had multiple parameter download failures and now QGC cannot connect to the VOXL
    We can see the board connect and add a comport, but is not recognized by QGC.
    It says on pX4 that there is likely a problem with the hardware at the OS level. How do we fix that?
      Please try loading new firmware and let us know if that works https://docs.modalai.com/flight-core-firmware/
      Caleb RievleyC 1 Reply Last reply
        Caleb Rievley
        • Chad SweetC Chad Sweet
          Caleb Rievley
          @Chad-Sweet That worked! After I did the reinstall, it would not connect. I closed and reopened QGC, switched the usb cable, and then went into the auto-connect section of the general settings and disabled the NMEA GPS device drop-down.
          Thank you Chad!
