  2. VOXL Dev Drones
  3. Sentinel
  4. GPS not working
GPS not working
Scheduled Pinned Locked Moved Sentinel
49 Posts 7 Posters 28.5k Views 4 Watching
  • A Offline
    Andre Moura
    I'm testing the sentinel drone for outdoor flight and we have no GPS data on QGroundControl.
    The light for GPS fixed is blinking, indicating that the sensor is getting signal and being fixed.
    This is the list of voxl-services running:
    Some things that appear to be wrong:
    • NUTTX console is not responding to any commands, on QGC through Wi-Fi;
    • When I tried to upload the parameters file "voxl-4-params/params/v1.12/ekf2_outdoor_gps_mag.params" there were no problems, but I still have no GPS and when I tried to upload "voxl-4-params/params/v1.14/EKF2_helpers/outdoor_gps_baro.params" the following error appears in QGC: "Parameters are missing from firmware. (...) Missing params: 1:EKF2_EV_CTRL, 1:EKF2_GPS_CTRL, 1:EKF2_HGT_REF, 1:SYS_HAS_GPS".
    Would appreciate any help solving this issue. Thank you!
    • A Andre Moura
      @andremoura The VOXL2 version of PX4 is different than what you get on a standard Pixhawk style flight controller (e.g. flight core). On VOXL2 the implementation is split between the application processor (running Linux) and the Sensors DSP (Running Qualcomm's Qurt RTOS). So Nuttx is not used at all on VOXL2 PX4. However, there are still ways to interact with PX4 via the console.
      • A Andre Moura
        @andremoura One way to interact with PX4 on VOXL2 is using PX4 command aliases. For example, if you want to run the command listener sensor_gps to see if the GPS unit is publishing GPS data then you could use an adb shell to enter the following command alias px4-listener sensor_gps and it will show you the latest published data from the GPS sensor or say never published.
        • A Offline
          Andre Moura
          I tested the "px4-listener sensor_gps" command, as you proposed and the output was "never published", even though the GPS is fixed.
          I also tried "px4-gps status" and got "INFO [gps] not running". Then I also tried px4-gps stop and start, but no difference in the status.
          • A Andre Moura
            @andremoura The GPS unit will come up and get a fix on it's own after it has been powered on so that doesn't indicate anything about the health of the connection to the flight controller. If the result of px4-listener sensor_gps is never published then there is likely a problem with your connection to the GPS unit. The GPS driver on VOXL2 runs on the DSP, not on the applications processor so you have to use qshell to interact with it. So, for status, you would use px4-qshell gps status. Have you made any changes to the Sentinel hardware or is it exactly the same as it was shipped?
            A Captain 7thC 3 Replies Last reply
              Andre Moura
              wrote on last edited by Andre Moura
              @Eric-Katzfey The sentinel is as it was on arrival 2 days ago, no hardware changes.
              We ran px4-shell gps status and got:
              voxl2:~$ px4-qshell gps status
              INFO  [qshell] Send cmd: 'gps status'
              INFO  [qshell] qshell return value timestamp: 801929670, local time: 801931434
              • A Andre Moura
                @andremoura Okay, that's not very useful. Let's try something else. First of all can you post the contents of the file /etc/systemd/system/voxl-px4.service? Then, stop the service from autostarting voxl-px4 with the commands systemctl disable voxl-px4 and sync. Then reboot the drone. When you adb back in to the drone you can run voxl-inspect-services to verify that voxl-px4 isn't running. Then you can start voxl-px4 manually from the command line with voxl-px4 and then post all of the output from that.
                Captain 7thC 1 Reply Last reply
                  Andre Moura
                  @Eric-Katzfey After manually stopping and starting the voxl-px4 service, it has been working on startup.
                  Very strange, since when I first noticed the GPS issue, the service was running from startup but not receiving any data (as seen on my console print). However, now it seems to work every time we shut down and power on the drone.
                  Thank you for your help!
                  • A Andre Moura
                    @andremoura Okay, that's unexpected. Oh well, at least it is working now! Let me know if it starts to give trouble again.
                    A 1 Reply Last reply
                      Andre Moura
                      @Eric-Katzfey Unfortunately the GPS is not working as expected. Yesterday we were momentarily able to get between 9-12 satellites, which I think is a little low. With that number of satellites, we were not able to get GPS lock on the drone, QGC displayed an error related to GPS accuracy too low. Even after allowing to arm without GPS lock and flying at about 15 m, the number of satellites didn't change and we couldn't even put the drone in position mode, because of not being GPS locked.
                      What we did to be able to even get those satellites was systemctl disable voxl-px4 , systemctl disable voxl-mavlink-server, rebooted the drone and, in two different ssh shells, ran both services manually.
                      Today, using this approach, I'm not even able to get any satellites at all. All the following tests were done with the ekf2_outdoor_gps_mag.params configuration file from your Gitlab.
                      The output from voxl-px4 was:
                      voxl2:~$ voxl-px4
                      Found DSP signature file
                      ______  __   __    ___
                      | ___ \ \ \ / /   /   |
                      | |_/ /  \ V /   / /| |
                      |  __/   /   \  / /_| |
                      | |     / /^\ \ \___  |
                      \_|     \/   \/     |_/
                      px4 starting.
                      INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
                      Running on M0054
                      INFO  [muorb] SLPI: Creating qurt thread hpwork
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 82
                      INFO  [muorb] SLPI: Creating qurt thread lpwork
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 81
                      INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 80
                      INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 79
                      INFO  [muorb] SLPI: Creating qurt thread wq_manager
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 78
                      INFO  [muorb] SLPI: Creating qurt thread qshell
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 77
                      INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
                      INFO  [uorb] Advertising remote topic sensor_accel
                      INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                      INFO  [uorb] Advertising remote topic sensor_gyro
                      INFO  [uorb] Advertising remote topic imu_server
                      INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 23323798, current timestamp 23323799
                      INFO  [uorb] Advertising remote topic qshell_retval
                      INFO  [qshell] qshell return value timestamp: 23323798, local time: 23327958
                      ERROR [muorb] SLPI: Cannot reset all parameters on client side
                      INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                      INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                      Starting Holybro magnetometer
                      INFO  [muorb] SLPI: Creating qurt thread wq_I2C1
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 75
                      INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1 (external)
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26405496, current timestamp 26405497
                      INFO  [qshell] qshell return value timestamp: 26405496, local time: 26406391
                      Starting Holybro LED driver
                      INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1 (external)
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26445017, current timestamp 26445018
                      INFO  [qshell] qshell return value timestamp: 26445017, local time: 26445673
                      INFO  [qshell] Send cmd: 'icp10100 start -I -b 5'
                      INFO  [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
                      INFO  [muorb] SLPI: Creating qurt thread wq_I2C5
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 74
                      INFO  [muorb] SLPI: *** I2C Device ID 0x9c6329 10249001
                      INFO  [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
                      INFO  [muorb] SLPI: icp10100 #0 on I2C bus 5
                      INFO  [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26486020, current timestamp 26486021
                      INFO  [qshell] qshell return value timestamp: 26486020, local time: 26487682
                      INFO  [uorb] Advertising remote topic sensor_mag
                      INFO  [qshell] Send cmd: 'modalai_esc start'
                      INFO  [muorb] SLPI: qshell gotten: modalai_esc start
                      INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
                      INFO  [uorb] Advertising remote topic sensor_baro
                      INFO  [uorb] Advertising remote topic test_motor
                      INFO  [muorb] SLPI: Ok executing command: modalai_esc start
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26546800, current timestamp 26546801
                      INFO  [muorb] SLPI: Opened UART ESC device
                      INFO  [qshell] qshell return value timestamp: 26546800, local time: 26548152
                      INFO  [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
                      INFO  [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
                      INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 71
                      INFO  [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26609932, current timestamp 26609933
                      INFO  [qshell] qshell return value timestamp: 26609932, local time: 26611050
                      INFO  [uorb] Advertising remote topic actuator_outputs
                      INFO  [uorb] Advertising remote topic multirotor_motor_limits
                      INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
                      INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                      INFO  [muorb] SLPI: Creating qurt thread wq_I2C2
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4169
                      INFO  [muorb] SLPI: *** I2C Device ID 0x784411 7881745
                      INFO  [uorb] Advertising remote topic battery_status
                      INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
                      INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26674290, current timestamp 26674291
                      INFO  [qshell] qshell return value timestamp: 26674290, local time: 26675325
                      INFO  [uorb] Advertising remote topic power_monitor
                      Starting Holybro GPS
                      INFO  [qshell] Send cmd: 'gps start -d 7 -b 115200'
                      INFO  [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
                      INFO  [muorb] SLPI: Creating qurt thread gps
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 70
                      INFO  [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26712883, current timestamp 26712884
                      INFO  [qshell] qshell return value timestamp: 26712883, local time: 26713903
                      INFO  [qshell] Send cmd: 'px4io detect'
                      INFO  [muorb] SLPI: qshell gotten: px4io detect
                      INFO  [muorb] SLPI: serial port fd 2
                      ERROR [muorb] SLPI: px4io read failed
                      ERROR [muorb] SLPI: px4io io_reg_get(0,0,1): data error -5
                      ERROR [muorb] SLPI: IO not installed
                      ERROR [muorb] SLPI: Detection attempt 2 failed
                      ERROR [muorb] SLPI: Detection attempt 1 failed
                      ERROR [muorb] SLPI: Detection attempt 0 failed
                      ERROR [muorb] SLPI: Failed to execute command: px4io detect
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26777758, current timestamp 26777759
                      INFO  [qshell] cmd returned with: -17
                      INFO  [qshell] qshell return value timestamp: 26777758, local time: 26778378
                      ERROR [qshell] Command failed
                      M0065 not detected, starting Spektrum RC driver
                      INFO  [qshell] Send cmd: 'spektrum_rc start -d 8'
                      INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -d 8
                      INFO  [muorb] SLPI: Creating qurt thread spektrum_rc_main
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 67
                      INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -d 8
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 26822566, current timestamp 26822566
                      INFO  [qshell] qshell return value timestamp: 26822566, local time: 26823292
                      INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 66
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 27885493, current timestamp 27885494
                      INFO  [uorb] Advertising remote topic vehicle_angular_acceleration
                      INFO  [uorb] Advertising remote topic vehicle_angular_velocity
                      INFO  [qshell] qshell return value timestamp: 27885493, local time: 27890054
                      INFO  [muorb] SLPI: Creating qurt thread wq_INS0
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 65
                      INFO  [uorb] Advertising remote topic vehicle_imu
                      INFO  [uorb] Advertising remote topic vehicle_imu_status
                      INFO  [uorb] Advertising remote topic sensors_status_imu
                      INFO  [uorb] Advertising remote topic vehicle_acceleration
                      INFO  [uorb] Advertising remote topic vehicle_air_data
                      INFO  [uorb] Advertising remote topic sensor_selection
                      INFO  [uorb] Advertising remote topic sensor_combined
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 28080230, current timestamp 28080231
                      INFO  [qshell] qshell return value timestamp: 28080230, local time: 28081490
                      INFO  [uorb] Advertising remote topic ekf2_timestamps
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 28141872, current timestamp 28141873
                      INFO  [qshell] qshell return value timestamp: 28141872, local time: 28143606
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 28193889, current timestamp 28193890
                      INFO  [qshell] qshell return value timestamp: 28193889, local time: 28194908
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 28277320, current timestamp 28277321
                      INFO  [qshell] qshell return value timestamp: 28277320, local time: 28277781
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 28316740, current timestamp 28316741
                      INFO  [qshell] qshell return value timestamp: 28316740, local time: 28317757
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 28355231, current timestamp 28355232
                      INFO  [qshell] qshell return value timestamp: 28355231, local time: 28356012
                      INFO  [uorb] Advertising remote topic vehicle_land_detected
                      INFO  [muorb] SLPI: 28570980: reset position to last known position
                      INFO  [muorb] SLPI: 28570980: reset velocity to zero
                      INFO  [uorb] Advertising remote topic vehicle_local_position
                      INFO  [uorb] Advertising remote topic vehicle_odometry
                      INFO  [uorb] Advertising remote topic estimator_states
                      INFO  [uorb] Advertising remote topic estimator_status
                      INFO  [uorb] Advertising remote topic estimator_status_flags
                      INFO  [uorb] Advertising remote topic estimator_innovations
                      INFO  [uorb] Advertising remote topic estimator_innovation_test_ratios
                      INFO  [uorb] Advertising remote topic estimator_innovation_variances
                      INFO  [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
                      INFO  [commander] LED: open /dev/led0 failed (22)
                      INFO  [muorb] SLPI: Advertising remote topic led_control
                      INFO  [muorb] SLPI: Advertising remote topic tune_control
                      INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
                      INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
                      INFO  [muorb] SLPI: Advertising remote topic vehicle_status
                      INFO  [muorb] SLPI: Advertising remote topic actuator_armed
                      INFO  [uorb] Advertising remote topic rate_ctrl_status
                      INFO  [uorb] Advertising remote topic actuator_controls_0
                      INFO  [muorb] SLPI: Advertising remote topic commander_state
                      INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
                      INFO  [muorb] SLPI: Advertising remote topic vehicle_command
                      INFO  [commander] Handling Commander command 176
                      INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
                      INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                      INFO  [uorb] Advertising remote topic estimator_sensor_bias
                      pxh> INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                      INFO  [muorb] SLPI: 34702200: EKF aligned, (baro hgt, IMU buf: 11, OBS buf: 8)
                      INFO  [uorb] Advertising remote topic vehicle_attitude
                      INFO  [uorb] Advertising remote topic vehicle_attitude_setpoint
                      INFO  [uorb] Advertising remote topic vehicle_rates_setpoint
                      Inside the pxh console, we ran the gps status command and got:
                      Command 'gps' failed, returned -1.
                      I find this strange since when we ran the voxl-px4 service it had the start command for the gps. Since gps was not running, I decided to test again the gps start by doing gps stop and then gps start -d 7 -b 115200, that appeared on the output of ```voxl-px4``. The console output was:
                      ERROR [gps] GPS: failed to open serial port: 7 err: 2
                      We also tried the same with qshell.
                      qshell gps status outputted:
                      pxh> qshell gps status
                      INFO  [muorb] SLPI: qshell gotten: gps status
                      INFO  [muorb] SLPI: Main GPS
                      INFO  [muorb] SLPI: protocol: UBX
                      INFO  [muorb] SLPI: status: NOT OK, port: 6, baudrate: 115200
                      INFO  [muorb] SLPI: sat info: disabled
                      INFO  [muorb] SLPI: rate reading: 		     0 B/s
                      INFO  [muorb] SLPI: Ok executing command: gps status
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 318302556, current timestamp 318302557
                      INFO  [qshell] qshell return value timestamp: 318302556, local time: 318308860
                      We also tried to stop and run it again with qshell gps stop and qshell gps start.
                      After this, the output of qshell gps status was:
                      INFO  [muorb] SLPI: status: OK, port: 6, baudrate: 115200
                      INFO  [muorb] SLPI: rate reading: 		   695 B/s
                      INFO  [muorb] SLPI: rate position: 		  5.00 Hz
                      INFO  [muorb] SLPI: rate velocity: 		  5.00 Hz
                      INFO  [muorb] SLPI: rate publication:		  5.00 Hz
                      INFO  [muorb] SLPI: rate RTCM injection:	  0.00 Hz
                      INFO  [muorb] SLPI:  sensor_gps_s
                      INFO  [muorb] SLPI: 	timestamp: 405957015  (0.197956 seconds ago)
                      INFO  [muorb] SLPI: 	time_utc_usec: 0
                      INFO  [muorb] SLPI: 	lat: 0
                      INFO  [muorb] SLPI: 	lon: 0
                      INFO  [muorb] SLPI: 	alt: -17000
                      INFO  [muorb] SLPI: 	alt_ellipsoid: 0
                      INFO  [muorb] SLPI: 	s_variance_m_s: 1000.0001
                      INFO  [muorb] SLPI: 	c_variance_rad: 3.1416
                      INFO  [muorb] SLPI: 	eph: 4294967.5000
                      INFO  [muorb] SLPI: 	epv: 3772217.5000
                      INFO  [muorb] SLPI: 	hdop: 99.9900
                      INFO  [muorb] SLPI: 	vdop: 99.9900
                      INFO  [muorb] SLPI: 	noise_per_ms: 93
                      INFO  [muorb] SLPI: 	jamming_indicator: 30
                      INFO  [muorb] SLPI: 	vel_m_s: 0.0000
                      INFO  [muorb] SLPI: 	vel_n_m_s: 0.0000
                      INFO  [muorb] SLPI: 	vel_e_m_s: 0.0000
                      INFO  [muorb] SLPI: 	vel_d_m_s: 0.0000
                      INFO  [muorb] SLPI: 	cog_rad: 0.0000
                      INFO  [muorb] SLPI: 	timestamp_time_relative: 0
                      INFO  [muorb] SLPI: 	heading: -nan
                      INFO  [muorb] SLPI: 	heading_offset: 0.0000
                      INFO  [muorb] SLPI: 	fix_type: 0
                      INFO  [muorb] SLPI: 	jamming_state: 0
                      INFO  [muorb] SLPI: 	vel_ned_valid: False
                      INFO  [muorb] SLPI: 	satellites_used: 0
                      INFO  [muorb] SLPI: Sending qshell retval with timestamp 406155973, current timestamp 406155974
                      INFO  [qshell] qshell return value timestamp: 406155973, local time: 406158054
                      Any ideia of what the problem could be?
                      I also noticed the following errors on the voxl-px4 output:
                      Is this normal?
                      Thank you.
                      • A Andre Moura
                        voxl2:~$ voxl-px4
                        ______  __   __    ___
                        | ___ \ \ \ / /   /   |
                        | |_/ /  \ V /   / /| |
                        |  __/   /   \  / /_| |
                        | |     / /^\ \ \___  |
                        \_|     \/   \/     |_/
                        px4 starting.
                        Running on M0054
                        INFO  [muorb] SLPI:
                        Is this normal?
                        Thank you.
                        @andremoura Yes, the errors related to px4io detection are expected since you do not have a px4io unit attached to the drone. And yes, you have to interact with things on the DSP (where the GPS driver runs) with qshell as you already figured out. Do you have any other Sentinel drones that you can compare against? Or other types of drones with GPS to compare against? When you are able to get 9 to 12 satellites what does qshell gps status show? It does appear to be wired up correctly as sometimes it is obviously communicating with the GPS unit.
                        • A Andre Moura
                          voxl2:~$ voxl-px4
                          ______  __   __    ___
                          | ___ \ \ \ / /   /   |
                          | |_/ /  \ V /   / /| |
                          |  __/   /   \  / /_| |
                          | |     / /^\ \ \___  |
                          \_|     \/   \/     |_/
                          px4 starting.
                          Running on M0054
                          INFO  [muorb] SLPI:
                          Is this normal?
                          Thank you.
                          #12
                          @andremoura It looks like there are at least 2 different issues here. One is that when you do see it working it has poor performance and doesn't get a lock. That is why I wanted to compare against other drones or other GPS units. If other units are working fine and this one isn't then maybe it's a faulty unit. If they all have poor performance then maybe it's something about the test location.
                          • A Andre Moura
                            voxl2:~$ voxl-px4
                            ______  __   __    ___
                            | ___ \ \ \ / /   /   |
                            | |_/ /  \ V /   / /| |
                            |  __/   /   \  / /_| |
                            | |     / /^\ \ \___  |
                            \_|     \/   \/     |_/
                            px4 starting.
                            Running on M0054
                            INFO  [muorb] SLPI:
                            Is this normal?
                            Thank you.
                            @andremoura The other issue appears to be that you don't always get the driver to communicate with the GPS unit on startup. The start line in /etc/modalai/voxl-px4.config is qshell gps start -d 7 -b 115200. When you did qshell gps stop and then qshell gps start was it started with qshell gps start -d 7 -b 115200 or just qshell gps start?
                              Andre Moura
                              @Eric-Katzfey We don't have any other Sentinel drones. We have other drones with GPS, that detect at least the same or higher number of satellites but they all are able to GPS lock.
                              When we had that number of satellites, the qshell gps status seemed ok with number of satellites, latitude and longitude, but we aren't able to replicate that test right now because of bad weather conditions.
                                Andre Moura
                                @Eric-Katzfey I will test the Sentinel drone on a new better location next week, if weather gets better, and I will get back to you.
                                  Andre Moura
                                  @Eric-Katzfey GPS mostly hasn't beeen working on startup again.
                                  We started it with qshell gps start, but we also tested qshell gps start -d 7 -b 115200. Both commands only worked a few times, we are not able to consistently start the GPS, having to stop and start again the service a few times before it works.
                                  • A Andre Moura
                                    @andremoura Is the LED on top of the unit (multicolor LED) coming on?
                                      Andre Moura
                                      #18
                                      @Eric-Katzfey said in GPS not working:
                                      Yes, every time voxl-px4 is running.
                                      • A Andre Moura
                                        @andremoura Okay, good. Holybro changed some of the components in their unit at one point and if that LED wasn't coming on it could indicate that it was one of the older units. But since it is on that indicates to me that it is the correct version of the Holybro unit.
                                        • A Offline
                                          Andre Moura
                                          @Eric-Katzfey Ok, new find! It seems that when voxl-px4 runs, the GPS service isn't able to start immediately, but if we wait a for a bit and start it manually, it works.
                                          Seems like something isn't ready to start immediately after voxl-px4.
