  3. M0025-2 camera out of focus
3 Posts 2 Posters 469 Views 1 Watching
  • D Offline
    D Offline
    dtc
    I recently bought a M0025-2 camera. The left side of the image appears out of focus, whereas the right side is in focus.
    Is there anything we can do to fix the focus across the full image?
    Is the lens glued to the sensor or can we adjust it? As shown in another post here: https://forum.modalai.com/topic/1077/stereo-right-side-out-of-focus/4?_=1681159565457
    Thank you
    • Adrian HidalgoA Offline
      Adrian Hidalgo
      @dtc can you clarify which camera you have. The M0025-2 is our hi-res camera.
      However it sounds like you have a stereo-camera pair. Is that correct?
      When you're referring to the left and right side, is that in the same camera or left and right camera? There will be a slight distortion in the cameras on the extreme left and right frames in the same camera, that can't be fixed, only slightly get it better. The forum you're referring to is spot on and you can follow it if you're using the stereo camera.
      • D Offline
        D Offline
        dtc
        Thanks for the response.
        We have the M0025-2 (not a stereo pair). In a single image from the M0025-2, part of the image is in focus and part of the image is out of focus. It looks like the best focus distance varies across a single image from left-to-right.
