  3. ERROR: No ESC(s) detected, exiting.
19 Posts 2 Posters 3.0k Views 1 Watching
  • S Offline
    S Offline
    suvasis
    hi Alex,
    I have wired wrongly some of the drone motors to esc. Do you sell individual cable connector?
    I am new to soldering and don't want to re-solder the esc.
    thanks.
    suvasis
    • Alex KushleyevA Offline
      It is great to hear that you got it working!
      Regarding motor wiring.. Are you saying that some motors are spinning in wrong direction? If so, you can use PX4 params to reverse the motor directions. Also, when using voxl-esc tools for testing, some scripts (but maybe not all) support commanding negative power and rpm, which will cause the motor to spin in opposite direction (specifically, voxl-esc-spin.py supports negative power and rpm commands).
      Regarding soldering, I would encourage you to practice soldering on some other boards that are "junk", so you can gain some experience with soldering. This will help you make sure that the motor connections that you already made are good! Sometimes bad solder joint can result in failure to spin motor or can come loose in flight.
      The motors are typically soldered to the ESC directly in order to avoid another connection (potential point of failure) between the motor and ESC..
      • S Offline
        S Offline
        suvasis
        hi Alex,
        I run tests on motors, I see the following result:
        What does "RPM COMPARISON TEST FAILED" this mean?
        command:
        voxl-esc/tools$ python voxl-esc-spin.py --device /dev/ttyUSB0 --baud-rate 250000 --id 3 --power 15 --timeout 300
        //result snippet:
        [299.950] (3) RPM: 1828, PWR: 15, VBAT: 12.19V, TEMPERATURE: 36.48C, CURRENT: 0.11A
        [299.960] (3) RPM: 1828, PWR: 15, VBAT: 12.18V, TEMPERATURE: 36.50C, CURRENT: 0.14A
        [299.970] (3) RPM: 1828, PWR: 15, VBAT: 12.18V, TEMPERATURE: 36.50C, CURRENT: 0.14A
        [299.980] (3) RPM: 1830, PWR: 15, VBAT: 12.18V, TEMPERATURE: 36.52C, CURRENT: 0.10A
        [299.990] (3) RPM: 1830, PWR: 15, VBAT: 12.18V, TEMPERATURE: 36.52C, CURRENT: 0.11A
        Finished!
        [1678327467.651517] TX=30008, RX=30007 packets, RX CRC ERRORS=0
        Average RPMs: 0.00 0.00 0.00 1829.42
        Average RPM deviation between ESCs : 1829.42
          Actually you can ignore this. At the end of the test, the script compares the average rpms between 4 motors and reports if they are close to the same or not. In your case,
          You only spun one motor. I will fix this in the script, but please ignore it for now.
          • S Offline
            S Offline
            suvasis
            hi Alex,
            Thanks. I see it "RPM_COMPARISON TEST PASSED":
            command:
            voxl-esc/tools$ python voxl-esc-spin.py --id 255 --rpm 2000 --timeout 30
            result snippet:
            [29.991] (2) RPM: 2006, PWR: 16, VBAT: 12.15V, TEMPERATURE: 37.05C, CURRENT: 0.09A
            [29.991] (3) RPM: 1989, PWR: 16, VBAT: 12.15V, TEMPERATURE: 37.05C, CURRENT: 0.14A
            Finished!
            [1678328032.787829] TX=3008, RX=2999 packets, RX CRC ERRORS=1
            Average RPMs: 1996.62 2000.80 2003.73 1993.21
            Average RPM deviation between ESCs : 10.52
            • S Offline
              S Offline
              suvasis
              hi Alex,
              There is no documentation on which cable from motor go esc. Does it matter?
              Thanks.
              suvasis
                For all 3-phase BLDC motors, the following rule applies: if you switch the order of any two (out of three) wires, the direction is reversed.
                With that in mind, the ModalAI ESC has a parameter how to control the direction of motor based on the ID (0-3).
                https://gitlab.com/voxl-public/flight-core-px4/voxl-esc/-/blob/dev-python3/params/old/esc_params_modalai_4_in_1_revb.xml#L40
                In this example, the value 2 means ID-based, this means:
                ID0 = normal direction
                ID1 = reversed direction
                ID2 = normal direction
                ID3 = reversed direction
                This is convenient so that if you solder the wires the same way to the ESC, the ESC will alternate directions, since in a Quadrotor, the motor direction alternates as you go around from ID 0 to 3.
                If you want all four IDs to spin in the same direction (and you switch wires yourself to alternate directions), then you can set the dir parameter to 0 or 1.
                However, please note that an ESC cannot know the true spin direction, as the three phases are (almost) identical.
                S 1 Reply Last reply
                  S Offline
                  S Offline
                  suvasis
                  hi Alex,
                  I connected the esc after testing from PC.
                  But when I connect the esc to the vox2 using cable MCBL-00029-1.
                  and followed the document: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev-python3/voxl-esc-tools
                  "Installation Instructions for VOXL2"
                  I get the following message:
                  voxl2:~/voxl-esc/tools(dev-python3)$ python voxl-esc-upload-params.py --params-file ../params/RB5_Flight_V1/esc_params_modalai_4_in_1_revb_holybro2216_880_third_kp.xml
                  Detected Python version : 3.8.16 (default, Mar 7 2023, 22:05:32)
                  [GCC 7.5.0]
                  Found voxl-esc tools bin version: 1.1
                  INFO: Params file name : ../params/RB5_Flight_V1/esc_params_modalai_4_in_1_revb_holybro2216_880_third_kp.xml
                  INFO: Params file size : 6912 bytes
                  VOXL Platform: M0054
                  Detected VOXL2 M0054 or M0104!
                  Couldn't configure flight_controller sensor
                  Error calling voxl_uart_init
                  INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
                  INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200
                  INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 38400
                  Updated baud rate to 38400
                  Segmentation fault
                  voxl2:~/voxl-esc/tools(dev-python3)$ ^C
                    Hi @suvasis , please double check that you followed the instructions here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev-python3/voxl-esc-tools#installation-instructions-for-voxl2 , most importantly including:
                    • disabling px4 using systemctl
                    • creating a symlink for the slpi uart bridge
                    • restarting the board
                    • S Offline
                      S Offline
                      suvasis
                      Thanks. Alex,
                      I followed the document:
                      #stop and disable PX4 while using voxl-esc tools
                      systemctl stop voxl-px4 && systemctl disable voxl-px4
                      #temporarily move libpx4.so and create symlink for slpi bridge to libpx4.so
                      #this is required because currently the slpi application loader looks for libpx4.so (hardcoded)
                      cd /usr/lib/rfsa/adsp
                      mv libpx4.so libpx4.so.bak
                      ln -s ./libslpi_uart_bridge_slpi.so ./libpx4.so
                      #reboot VOXL2
                      reboot
                      Looks now it works after I re-did the steps:
                      result:
                      voxl2:~$
                      voxl2:~$ cd /usr/lib/rfsa/adsp
                      voxl2:/usr/lib/rfsa/adsp$ ls -l libpx4.so
                      lrwxrwxrwx 1 root root 29 Mar 16 17:41 libpx4.so -> ./libslpi_uart_bridge_slpi.so
                      voxl2:/usr/lib/rfsa/adsp$ cd
                      voxl2:~$ pwd
                      /home/root
                      voxl2:~$ cd voxl-esc/tools/
                      voxl2:~/voxl-esc/tools(dev-python3)$ ./voxl-esc-scan.py
                      Detected Python version : 3.6.9 (default, Jun 29 2022, 11:45:57)
                      [GCC 8.4.0]
                      INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 250000
                      INFO: Additional Information:
                      INFO: ---------------------
                      Board : version 34: ModalAi 4-in-1 ESC V2 RevC (M0117)
                      UID : 0x203034305743570C00360052
                      Firmware : version 36, hash f75f1fdb
                      Bootloader : version 183, hash 25317f42
                      UID        : 0x203034305743570C0036004C
                      UID        : 0x203034305743570C0036004B
                      UID        : 0x203034305743570C0042001C
                      • S Offline
                        S Offline
                        suvasis
                        hi Alex,
                        I have 2 questions:
                        1. After the tests are performed:
                        #test voxl-esc tools
                        cd /home/root/voxl-esc/tools
                        ./voxl-esc-scan.py
                        #perform ESC testing / calibration
                        What does this do?
                        #when done, restore original libpx4.so
                        rm libpx4.so
                        cp libpx4.so.bak libpx4.so
                        systemctl enable voxl-px4
                        reboot
                        1. While Uploading Parameters:
                        I don't see any parameters file "params/esc_params_modalai_4_in_1.xml" per se
                        python voxl-esc-upload-params.py --params-file ../params/esc_params_modalai_4_in_1.xml
                        Thanks.
                        suvasis
                          hi @suvasis
                          ./voxl-esc-scan.py
                          this was just a place holder for any testing you want to do with the voxl-esc tools.
                          rm libpx4.so
                          reboot
                          This part restores the PX4 functionality, because in order to use voxl-esc tools on VOXL2, the instructions told you to disable PX4 while using voxl-esc tools. Soon we will not require disabling PX4 to use voxl-esc tools, but currently you have to do it.
                          1. Please note that we just made some updated to the voxl-esc tools and directory structure has slightly changed. Also, you no longer have to download the binary tools package and add it to the voxl-esc/tools directory. Please see an example params file here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-params/old/esc_params_modalai_4_in_1_revb.xml
