  3. VOXL2 mavlink topic streaming modifications
voxl-2
14 Posts 3 Posters 3.1k Views 2 Watching
  • J JoeC
    @Eric-Katzfey Thanks Eric! It definitely sort of works. Two things I note as I modified: 1.) The topic streaming rate appears to be double what you set using the '-r' argument in the 'mavlink stream' command. Also, 2.) I was hoping to get RC_CHANNELS and interestingly, that particular topic isn't showing up at QGC. HIGHRES_IMU, ATTITUDE, ATTITUDE_QUATERNION, ATTITUDE_TARGET, LOCAL_POSITION_NED, and ODOMETRY all stream back (at double rate). RC_CHANNELS has nothing...
    @JoeC Okay, interesting, I'll have to look into that.
    • J JoeC
      @JoeC The RC_CHANNELS message relies on the input_rc topic. Are you sure that that is being generated? Can you see it being logged in log files? Can you see it with px4-listener input_rc -n 1 when PX4 is running?
      J 1 Reply Last reply
      • Taylor PresleyT Offline
        Taylor Presley
        @JoeC @Eric-Katzfey following. I'm using the VOXL 2 flight deck, Spektrum receiver, and Spektrum DXs transmitter. They are bound and I'm getting MAVLink messages in QGC, but no RC channels. PX4 is not publishing RC messages. Any feedback is appreciated!
        voxl2:/$ px4-listener input_rc
        never published
        • Taylor PresleyT Taylor Presley
          never published
          @Taylor-Presley How are you starting px4? Is it being started via systemd service or are you starting it from the command line? Are you using the voxl-px4 script or calling px4 directly? You need to make sure that the script is trying to start the spektrum_rc driver otherwise it will produce no output. Can you verify that the spektrum_rc driver is in fact starting and not some other RC driver?
            Taylor Presley
            @Eric-Katzfey I've tried both, below is the output after I disable px4 and then start it using voxl-px4. It does appear to try and start spektrum_rc and then returns the errors "Open failed on 8" and "dsm init failed." I also get "px4io read failed," is it possible they are related? Thanks in advance for your help!
             modallink-relink     | Disabled  | Not Running |
             voxl-camera-server   | Disabled  | Not Running |
             voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
             voxl-dfs-server      | Disabled  | Not Running |
             voxl-imu-server      | Disabled  | Not Running |
             voxl-mavlink-server  | Disabled  | Not Running |
             voxl-portal          | Disabled  | Not Running |
             voxl-px4-imu-server  | Disabled  | Not Running |
             voxl-px4             | Disabled  | Not Running |
             voxl-qvio-server     | Disabled  | Not Running |
             voxl-static-ip       | Disabled  | Not Running |
             voxl-streamer        | Disabled  | Not Running |
             voxl-tag-detector    | Disabled  | Not Running |
             voxl-tflite-server   | Disabled  | Not Running |
             voxl-vision-px4      |  Enabled  |   Running   |     0.0
             voxl-wait-for-fs     | Disabled  | Not Running |
            voxl2:/$ voxl-px4
            Found DSP signature file
            ______  __   __    ___
            | ___ \ \ \ / /   /   |
            | |_/ /  \ V /   / /| |
            |  __/   /   \  / /_| |
            | |     / /^\ \ \___  |
            \_|     \/   \/     |_/
            px4 starting.
            INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
            Running on M0054
            INFO  [muorb] SLPI: Creating qurt thread hpwork
            INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 82
            INFO  [muorb] SLPI: Creating qurt thread lpwork
            INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 81
            INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 80
            INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
            INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 79
            INFO  [muorb] SLPI: Creating qurt thread wq_manager
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 78
            INFO  [muorb] SLPI: Creating qurt thread qshell
            INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 77
            INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
            INFO  [uorb] Advertising remote topic sensor_accel
            INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
            INFO  [uorb] Advertising remote topic sensor_gyro
            INFO  [uorb] Advertising remote topic imu_server
            INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 77614428, current timestamp 77614429
            INFO  [uorb] Advertising remote topic qshell_retval
            INFO  [qshell] qshell return value timestamp: 77614428, local time: 77754132
            INFO  [uorb] Advertising remote topic sensor_gyro_fifo
            INFO  [uorb] Advertising remote topic sensor_accel_fifo
            ERROR [muorb] SLPI: Cannot reset all parameters on client side
            INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
            INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
            Starting Holybro magnetometer
            INFO  [muorb] SLPI: Creating qurt thread wq_I2C1
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 75
            INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1 (external)
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 80719911, current timestamp 80719912
            INFO  [qshell] qshell return value timestamp: 80719911, local time: 80721066
            Starting Holybro LED driver
            INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1 (external)
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 80751723, current timestamp 80751723
            INFO  [qshell] qshell return value timestamp: 80751723, local time: 80753408
            INFO  [qshell] Send cmd: 'icp10100 start -I -b 5'
            INFO  [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
            INFO  [muorb] SLPI: Creating qurt thread wq_I2C5
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 74
            INFO  [muorb] SLPI: *** I2C Device ID 0x9c6329 10249001
            INFO  [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
            INFO  [muorb] SLPI: icp10100 #0 on I2C bus 5
            INFO  [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 80788487, current timestamp 80788488
            INFO  [qshell] qshell return value timestamp: 80788487, local time: 80789647
            Starting modalai_esc driver
            INFO  [uorb] Advertising remote topic sensor_mag
            INFO  [uorb] Advertising remote topic sensor_baro
            INFO  [qshell] Send cmd: 'modalai_esc start'
            INFO  [muorb] SLPI: qshell gotten: modalai_esc start
            INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
            INFO  [uorb] Advertising remote topic test_motor
            INFO  [muorb] SLPI: Ok executing command: modalai_esc start
            INFO  [muorb] SLPI: Opened UART ESC device
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 80881200, current timestamp 80881201
            INFO  [qshell] qshell return value timestamp: 80881200, local time: 80883293
            INFO  [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
            INFO  [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
            INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 71
            INFO  [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 80962353, current timestamp 80962354
            INFO  [qshell] qshell return value timestamp: 80962353, local time: 80964191
            INFO  [uorb] Advertising remote topic actuator_outputs
            INFO  [uorb] Advertising remote topic multirotor_motor_limits
            INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
            INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
            INFO  [muorb] SLPI: Creating qurt thread wq_I2C2
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4169
            INFO  [muorb] SLPI: *** I2C Device ID 0x784411 7881745
            INFO  [uorb] Advertising remote topic battery_status
            INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
            INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 81015254, current timestamp 81015255
            INFO  [qshell] qshell return value timestamp: 81015254, local time: 81017021
            INFO  [uorb] Advertising remote topic power_monitor
            Starting Holybro GPS
            INFO  [qshell] Send cmd: 'gps start -d 7 -b 115200'
            INFO  [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
            INFO  [muorb] SLPI: Creating qurt thread gps
            INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 70
            INFO  [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 81067431, current timestamp 81067432
            INFO  [qshell] qshell return value timestamp: 81067431, local time: 81070463
            INFO  [qshell] Send cmd: 'px4io detect'
            INFO  [muorb] SLPI: qshell gotten: px4io detect
            INFO  [muorb] SLPI: serial port fd 2
            ERROR [muorb] SLPI: px4io read failed
            ERROR [muorb] SLPI: px4io io_reg_get(0,0,1): data error -5
            ERROR [muorb] SLPI: IO not installed
            ERROR [muorb] SLPI: Detection attempt 2 failed
            ERROR [muorb] SLPI: Detection attempt 1 failed
            ERROR [muorb] SLPI: Detection attempt 0 failed
            ERROR [muorb] SLPI: Failed to execute command: px4io detect
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 81127227, current timestamp 81127228
            INFO  [qshell] cmd returned with: -17
            INFO  [qshell] qshell return value timestamp: 81127227, local time: 81130928
            ERROR [qshell] Command failed
            M0065 not detected, starting Spektrum RC driver
            INFO  [qshell] Send cmd: 'spektrum_rc start -d 8'
            INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -d 8
            INFO  [muorb] SLPI: Creating qurt thread spektrum_rc_main
            INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 67
            INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -d 8
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 81177434, current timestamp 81177435
            ERROR [muorb] SLPI: Open failed on 8
            ERROR [muorb] SLPI: dsm init failed
            INFO  [qshell] qshell return value timestamp: 81177434, local time: 81180285
            INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 4163
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 82265425, current timestamp 82265426
            INFO  [uorb] Advertising remote topic vehicle_angular_acceleration
            INFO  [uorb] Advertising remote topic vehicle_angular_velocity
            INFO  [qshell] qshell return value timestamp: 82265425, local time: 82269473
            INFO  [muorb] SLPI: Creating qurt thread wq_INS0
            INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 66
            INFO  [uorb] Advertising remote topic vehicle_imu
            INFO  [uorb] Advertising remote topic vehicle_imu_status
            INFO  [uorb] Advertising remote topic sensors_status_imu
            INFO  [uorb] Advertising remote topic vehicle_acceleration
            INFO  [uorb] Advertising remote topic vehicle_magnetometer
            INFO  [uorb] Advertising remote topic sensor_preflight_mag
            INFO  [uorb] Advertising remote topic vehicle_air_data
            INFO  [uorb] Advertising remote topic sensor_selection
            INFO  [uorb] Advertising remote topic sensor_combined
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 82536895, current timestamp 82536896
            INFO  [qshell] qshell return value timestamp: 82536895, local time: 82539136
            ERROR [muorb] SLPI: 0 - vehicle_magnetometer lost, generation 0 -> 12
            INFO  [uorb] Advertising remote topic ekf2_timestamps
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 82596219, current timestamp 82596219
            INFO  [qshell] qshell return value timestamp: 82596219, local time: 82598209
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 82672105, current timestamp 82672106
            INFO  [qshell] qshell return value timestamp: 82672105, local time: 82676085
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 82779424, current timestamp 82779425
            INFO  [qshell] qshell return value timestamp: 82779424, local time: 82783625
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 82819473, current timestamp 82819474
            INFO  [qshell] qshell return value timestamp: 82819473, local time: 82821069
            INFO  [muorb] SLPI: Sending qshell retval with timestamp 82868826, current timestamp 82868827
            INFO  [qshell] qshell return value timestamp: 82868826, local time: 82872765
            INFO  [uorb] Advertising remote topic vehicle_land_detected
            INFO  [muorb] SLPI: 83015116: reset position to last known position
            INFO  [muorb] SLPI: 83015116: reset velocity to zero
            INFO  [uorb] Advertising remote topic vehicle_local_position
            INFO  [uorb] Advertising remote topic vehicle_odometry
            INFO  [uorb] Advertising remote topic estimator_states
            INFO  [uorb] Advertising remote topic estimator_status
            INFO  [uorb] Advertising remote topic estimator_status_flags
            INFO  [uorb] Advertising remote topic estimator_innovations
            INFO  [uorb] Advertising remote topic estimator_innovation_test_ratios
            INFO  [uorb] Advertising remote topic estimator_innovation_variances
            INFO  [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
            INFO  [commander] Mission #3 loaded, 1 WPs, curr: 0
            INFO  [muorb] SLPI: Advertising remote topic mission
            INFO  [commander] LED: open /dev/led0 failed (22)
            INFO  [muorb] SLPI: Advertising remote topic led_control
            INFO  [muorb] SLPI: Advertising remote topic tune_control
            INFO  [PreFlightCheck] Failed system power preflight check
            INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
            INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
            INFO  [muorb] SLPI: Advertising remote topic vehicle_status
            INFO  [muorb] SLPI: Advertising remote topic actuator_armed
            INFO  [muorb] SLPI: Advertising remote topic commander_state
            INFO  [uorb] Advertising remote topic rate_ctrl_status
            INFO  [uorb] Advertising remote topic actuator_controls_0
            INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
            INFO  [muorb] SLPI: Advertising remote topic vehicle_command
            INFO  [commander] Handling Commander command 176
            INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
            INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
            INFO  [uorb] Advertising remote topic estimator_sensor_bias
            INFO  [muorb] SLPI: Advertising remote topic telemetry_status
            pxh> INFO  [PreFlightCheck] Failed system power preflight check
            INFO  [muorb] SLPI: 90040983: EKF aligned, (baro hgt, IMU buf: 11, OBS buf: 8)
            INFO  [uorb] Advertising remote topic vehicle_attitude
            INFO  [uorb] Advertising remote topic vehicle_attitude_setpoint
            INFO  [uorb] Advertising remote topic vehicle_rates_setpoint
              J Offline
              J Offline
              JoeC
              @Eric-Katzfey Hi Eric and @Taylor-Presley you might find this helpful as well, I just had a chance to setup the Spektrum bind cable and a Spektrum receiver/xmitter. I AM now indeed getting RC_CHANNELS so I think my situation was because I didn't have the RC transmitter on the last time I was testing.
              @Taylor-Presley I note in your posted photo, most services are not running; on mine that is working at the moment, I've got camera-server, cpu-monitor, imu-server, mavlink-server, portal, px4-imu-server, and vision-px4 all running. One thing you can try as well is to ensure you ran 'voxl-configure-mpa -p --family sentinel' and see if your setup starts working.
                Taylor Presley
                @JoeC I did try that because I figured I may have screwed something up during HITL testing, but input_rc is still not publishing, sensor_gps is not published, and px4io is still failing to read. I'm open to trying anything that may work, all comments appreciated!
                  @Taylor-Presley px4io will fail to read if you do not have a px4io board attached to VOXL2.
                    @Eric-Katzfey You can see in the script that if it fails to detect the px4io board (as you saw) then it will attempt to start the Spektum RC driver instead. However, your output shows that it fails to initialize uart 8. That doesn't look right.
                      @Eric-Katzfey Sounds like you have 2 issues here that are not related to the original post. Can you create 2 new forum posts for the Spektrum issue and the GPS issue? Then we can try to solve those independently. Thanks!
                      Taylor PresleyT 1 Reply Last reply
                      -1
                        Taylor Presley
                        @Eric-Katzfey Thanks Eric, for future readers, I've created a new post at Voxl 2 Spektrum RC Issue.
