  3. VOXL 2 Spektrum RC Issue
3 Posts 2 Posters 904 Views 1 Watching
  • Taylor PresleyT Offline
    Taylor Presley
    I'm using the VOXL 2 flight deck, Spektrum receiver, and Spektrum DXs transmitter. They are bound and I'm getting MAVLink messages in QGC, but no RC channels. PX4 is not publishing RC messages. When I attempt to calibrate RC in QGC, I get the error message "Detected 0 radio channels. To operate PX4, you need at least 5 channels."
    voxl2:/$ px4-listener input_rc
    never published
    PX4 is failing to initialize uart 8. Starting voxl-px4 produces the following:
    voxl2:/$ voxl-inspect-services
     docker-autorun       | Disabled  | Not Running |
     docker-daemon        | Disabled  | Not Running |
     voxl-camera-server   | Disabled  | Not Running |
     voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
     voxl-dfs-server      | Disabled  | Not Running |
     voxl-imu-server      | Disabled  | Not Running |
     voxl-mavlink-server  | Disabled  | Not Running |
     voxl-portal          | Disabled  | Not Running |
     voxl-px4-imu-server  | Disabled  | Not Running |
     voxl-px4             | Disabled  | Not Running |
     voxl-qvio-server     | Disabled  | Not Running |
     voxl-static-ip       | Disabled  | Not Running |
     voxl-tag-detector    | Disabled  | Not Running |
     voxl-vision-px4      |  Enabled  |   Running   |     0.0
     voxl-wait-for-fs     | Disabled  | Not Running |
    voxl2:/$ voxl-px4
    Found DSP signature file
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
    Running on M0054
    INFO  [muorb] SLPI: Creating qurt thread hpwork
    INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 82
    INFO  [muorb] SLPI: Creating qurt thread lpwork
    INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 81
    INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 80
    INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
    INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 79
    INFO  [muorb] SLPI: Creating qurt thread wq_manager
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 78
    INFO  [muorb] SLPI: Creating qurt thread qshell
    INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 77
    INFO  [muorb] SLPI: muorb aggregator thread running
    INFO  [qshell] Send cmd: 'icm42688p start -s'
    INFO  [muorb] SLPI: qshell gotten: icm42688p start -s
    INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
    INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
    INFO  [uorb] Advertising remote topic sensor_accel
    INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
    INFO  [uorb] Advertising remote topic sensor_gyro
    INFO  [uorb] Advertising remote topic imu_server
    INFO  [muorb] SLPI: on SPI bus 1
    INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: icm42688p start -s
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 77614428, current timestamp 77614429
    INFO  [uorb] Advertising remote topic qshell_retval
    INFO  [qshell] qshell return value timestamp: 77614428, local time: 77754132
    INFO  [uorb] Advertising remote topic sensor_gyro_fifo
    INFO  [uorb] Advertising remote topic sensor_accel_fifo
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    ERROR [muorb] SLPI: Cannot reset all parameters on client side
    INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Advertising remote topic parameter_update
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
    INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    INFO  [logger] logger started (mode=all)
    Starting Holybro magnetometer
    INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    INFO  [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
    INFO  [muorb] SLPI: Creating qurt thread wq_I2C1
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 75
    INFO  [muorb] SLPI: *** I2C Device ID 0x60e09 396809
    INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1 (external)
    INFO  [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 80719911, current timestamp 80719912
    INFO  [qshell] qshell return value timestamp: 80719911, local time: 80721066
    Starting Holybro LED driver
    INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    INFO  [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO  [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
    INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1 (external)
    INFO  [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 80751723, current timestamp 80751723
    INFO  [qshell] qshell return value timestamp: 80751723, local time: 80753408
    INFO  [qshell] Send cmd: 'icp10100 start -I -b 5'
    INFO  [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
    INFO  [muorb] SLPI: Creating qurt thread wq_I2C5
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 74
    INFO  [muorb] SLPI: *** I2C Device ID 0x9c6329 10249001
    INFO  [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
    INFO  [muorb] SLPI: icp10100 #0 on I2C bus 5
    INFO  [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 80788487, current timestamp 80788488
    INFO  [qshell] qshell return value timestamp: 80788487, local time: 80789647
    Starting modalai_esc driver
    INFO  [uorb] Advertising remote topic sensor_mag
    INFO  [uorb] Advertising remote topic sensor_baro
    INFO  [qshell] Send cmd: 'modalai_esc start'
    INFO  [muorb] SLPI: qshell gotten: modalai_esc start
    INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
    INFO  [uorb] Advertising remote topic test_motor
    INFO  [muorb] SLPI: Ok executing command: modalai_esc start
    INFO  [muorb] SLPI: Opened UART ESC device
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 80881200, current timestamp 80881201
    INFO  [qshell] qshell return value timestamp: 80881200, local time: 80883293
    INFO  [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
    INFO  [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
    INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 71
    INFO  [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 80962353, current timestamp 80962354
    INFO  [qshell] qshell return value timestamp: 80962353, local time: 80964191
    INFO  [uorb] Advertising remote topic actuator_outputs
    INFO  [uorb] Advertising remote topic multirotor_motor_limits
    INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    INFO  [muorb] SLPI: Creating qurt thread wq_I2C2
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4169
    INFO  [muorb] SLPI: *** I2C Device ID 0x784411 7881745
    INFO  [uorb] Advertising remote topic battery_status
    INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
    INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 81015254, current timestamp 81015255
    INFO  [qshell] qshell return value timestamp: 81015254, local time: 81017021
    INFO  [uorb] Advertising remote topic power_monitor
    Starting Holybro GPS
    INFO  [qshell] Send cmd: 'gps start -d 7 -b 115200'
    INFO  [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
    INFO  [muorb] SLPI: Creating qurt thread gps
    INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 70
    INFO  [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 81067431, current timestamp 81067432
    INFO  [qshell] qshell return value timestamp: 81067431, local time: 81070463
    INFO  [qshell] Send cmd: 'px4io detect'
    INFO  [muorb] SLPI: qshell gotten: px4io detect
    INFO  [muorb] SLPI: serial port fd 2
    ERROR [muorb] SLPI: px4io read failed
    ERROR [muorb] SLPI: px4io io_reg_get(0,0,1): data error -5
    ERROR [muorb] SLPI: IO not installed
    ERROR [muorb] SLPI: Detection attempt 2 failed
    ERROR [muorb] SLPI: Detection attempt 1 failed
    ERROR [muorb] SLPI: Detection attempt 0 failed
    ERROR [muorb] SLPI: Failed to execute command: px4io detect
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 81127227, current timestamp 81127228
    INFO  [qshell] cmd returned with: -17
    INFO  [qshell] qshell return value timestamp: 81127227, local time: 81130928
    ERROR [qshell] Command failed
    M0065 not detected, starting Spektrum RC driver
    INFO  [qshell] Send cmd: 'spektrum_rc start -d 8'
    INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -d 8
    INFO  [muorb] SLPI: Creating qurt thread spektrum_rc_main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 67
    INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -d 8
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 81177434, current timestamp 81177435
    ERROR [muorb] SLPI: Open failed on 8
    ERROR [muorb] SLPI: dsm init failed
    INFO  [qshell] qshell return value timestamp: 81177434, local time: 81180285
    INFO  [qshell] Send cmd: 'sensors start'
    INFO  [muorb] SLPI: qshell gotten: sensors start
    INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 4163
    INFO  [muorb] SLPI: Ok executing command: sensors start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 82265425, current timestamp 82265426
    INFO  [uorb] Advertising remote topic vehicle_angular_acceleration
    INFO  [uorb] Advertising remote topic vehicle_angular_velocity
    INFO  [qshell] qshell return value timestamp: 82265425, local time: 82269473
    INFO  [muorb] SLPI: Creating qurt thread wq_INS0
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 66
    INFO  [uorb] Advertising remote topic vehicle_imu
    INFO  [uorb] Advertising remote topic vehicle_imu_status
    INFO  [uorb] Advertising remote topic sensors_status_imu
    INFO  [uorb] Advertising remote topic vehicle_acceleration
    INFO  [uorb] Advertising remote topic vehicle_magnetometer
    INFO  [uorb] Advertising remote topic sensor_preflight_mag
    INFO  [uorb] Advertising remote topic vehicle_air_data
    INFO  [qshell] Send cmd: 'ekf2 start'
    INFO  [muorb] SLPI: qshell gotten: ekf2 start
    INFO  [uorb] Advertising remote topic sensor_selection
    INFO  [uorb] Advertising remote topic sensor_combined
    INFO  [muorb] SLPI: Ok executing command: ekf2 start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 82536895, current timestamp 82536896
    INFO  [qshell] qshell return value timestamp: 82536895, local time: 82539136
    ERROR [muorb] SLPI: 0 - vehicle_magnetometer lost, generation 0 -> 12
    INFO  [uorb] Advertising remote topic ekf2_timestamps
    INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
    INFO  [qshell] Send cmd: 'mc_pos_control start'
    INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 82596219, current timestamp 82596219
    INFO  [qshell] qshell return value timestamp: 82596219, local time: 82598209
    INFO  [qshell] Send cmd: 'mc_att_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_att_control start
    INFO  [muorb] SLPI: Ok executing command: mc_att_control start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 82672105, current timestamp 82672106
    INFO  [qshell] qshell return value timestamp: 82672105, local time: 82676085
    INFO  [qshell] Send cmd: 'mc_rate_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
    INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 82779424, current timestamp 82779425
    INFO  [qshell] qshell return value timestamp: 82779424, local time: 82783625
    INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 82819473, current timestamp 82819474
    INFO  [qshell] qshell return value timestamp: 82819473, local time: 82821069
    INFO  [qshell] Send cmd: 'land_detector start multicopter'
    INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
    INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 82868826, current timestamp 82868827
    INFO  [qshell] qshell return value timestamp: 82868826, local time: 82872765
    INFO  [uorb] Advertising remote topic vehicle_land_detected
    INFO  [muorb] SLPI: 83015116: reset position to last known position
    INFO  [muorb] SLPI: 83015116: reset velocity to zero
    INFO  [uorb] Advertising remote topic vehicle_local_position
    INFO  [uorb] Advertising remote topic vehicle_odometry
    INFO  [uorb] Advertising remote topic estimator_states
    INFO  [uorb] Advertising remote topic estimator_status
    INFO  [uorb] Advertising remote topic estimator_status_flags
    INFO  [uorb] Advertising remote topic estimator_innovations
    INFO  [uorb] Advertising remote topic estimator_innovation_test_ratios
    INFO  [uorb] Advertising remote topic estimator_innovation_variances
    INFO  [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
    INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    INFO  [commander] Mission #3 loaded, 1 WPs, curr: 0
    INFO  [muorb] SLPI: Advertising remote topic mission
    INFO  [commander] LED: open /dev/led0 failed (22)
    INFO  [muorb] SLPI: Advertising remote topic led_control
    INFO  [muorb] SLPI: Advertising remote topic tune_control
    INFO  [PreFlightCheck] Failed system power preflight check
    INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
    INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
    INFO  [muorb] SLPI: Advertising remote topic vehicle_status
    INFO  [muorb] SLPI: Advertising remote topic actuator_armed
    INFO  [muorb] SLPI: Advertising remote topic commander_state
    INFO  [uorb] Advertising remote topic rate_ctrl_status
    INFO  [uorb] Advertising remote topic actuator_controls_0
    INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
    INFO  [muorb] SLPI: Advertising remote topic vehicle_command
    INFO  [commander] Handling Commander command 176
    INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
    INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    INFO  [uorb] Advertising remote topic estimator_sensor_bias
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    pxh> INFO  [PreFlightCheck] Failed system power preflight check
    INFO  [muorb] SLPI: 90040983: EKF aligned, (baro hgt, IMU buf: 11, OBS buf: 8)
    INFO  [uorb] Advertising remote topic vehicle_attitude
    INFO  [uorb] Advertising remote topic vehicle_attitude_setpoint
    INFO  [uorb] Advertising remote topic vehicle_rates_setpoint
    I'm using the VOXL 2 GPS / Mag / RC Module. All help troubleshooting is appreciated!
    Thanks in advance,
    Taylor
    • Taylor PresleyT Taylor Presley
      never published
      voxl2:/$ voxl-px4
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      Running on M0054
      INFO  [muorb] SLPI:
      Thanks in advance,
      Taylor
      @Taylor-Presley I have never seen the Open failed on 8 before so we're going to have to do some troubleshooting here. One possibility is that the attempt to detect the px4io board using that same serial port is causing some sort of conflict. Can you modify that section of /etc/modalai/voxl-px4.config the remove the check for the px4io board? For example, remove this whole section:
              qshell px4io detect
              PX4IO_STATUS=$?
              if [ $PX4IO_STATUS -eq 0 ]; then
                  /bin/echo "Found M0065, starting px4io"
                  # On M0054 we also support PWM output from M0065 (aka PX4IO)
                  # If there are no pwm escs then that connector will be empty.
                  qshell px4io start
                  qshell px4io recovery
                  qshell mixer load /dev/px4io quad_x_io.main.mix
                  PWM_RATE=`param show -q PWM_MAIN_RATE`
                  PWM_MAIN_DISARM=`param show -q PWM_MAIN_DISARM`
                  PWM_MAIN_MIN=`param show -q PWM_MAIN_MIN`
                  PWM_MAIN_MAX=`param show -q PWM_MAIN_MAX`
                  /bin/echo "  PWM_MAIN_RATE:   ${PWM_RATE}"
                  /bin/echo "  PWM_MAIN_DISARM: ${PWM_MAIN_DISARM}"
                  /bin/echo "  PWM_MAIN_MIN:   ${PWM_MAIN_MIN}"
                  /bin/echo "  PWM_MAIN_MAX: ${PWM_MAIN_MAX}"
                  qshell pwm rate -c 1234 -r ${PWM_RATE}
                  qshell pwm disarmed -c 1234 -p ${PWM_MAIN_DISARM}
                  qshell pwm min -c 1234 -p ${PWM_MAIN_MIN}
                  qshell pwm max -c 1234 -p ${PWM_MAIN_MAX}
                  qshell pwm failsafe -c 1234 -p -1 -d /dev/px4io
              else
                  /bin/echo "M0065 not detected, starting Spektrum RC driver"
                  qshell spektrum_rc start -d 8
              fi
      and just replace it with:
        Taylor Presley
        @Eric-Katzfey I've been stuck on travel for the past month but happy to report that your solution worked! input_rc is publishing and I was able to calibrate in QGC.
