    What is the correct process to recover the voxl 2?
    987
    • M
      m1baldwin
      The instructions on the documentation for re-flashing the system image on the voxl 2 doesn't quite match what the latest scripts from the voxl2 platform 0.9 image tar provide. The package provides an "install.sh" script as the entry point for re-flashing. The instructions mention there should be a "flash-full.sh" script.
      Assuming the above is supposed to be the correct script, I did try putting my voxl 2 into fastboot state and running the install script. It was able to identify the partition and reset the board, but it hangs at the "Waiting for ADB" step. The voxl 2 is showing up in dmesg as a Qualcomm device, but adb doesn't show it as available, hence it hanging at the waiting for adb step.
      Any ideas on what to try?
        tom admin
        @m1baldwin You're right, the newer releases changed the name to install.sh
        Can you post the output of lsusb on your host PC so we can see exactly what state the VOXL2 is booting into?
        • M
          m1baldwin
          Output from lsusb when voxl2 has been placed in fastboot mode:
          mb@mb-HP-EliteBook-840-G7-Notebook-PC:~/Downloads/voxl2_platform_0.9$ lsusb
          Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
          Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
          Bus 002 Device 017: ID 18d1:d00d Google Inc.
          Bus 001 Device 003: ID 06cb:00df Synaptics, Inc.
          Bus 001 Device 002: ID 04f2:b6bf Chicony Electronics Co., Ltd
          Bus 001 Device 004: ID 8087:0026 Intel Corp.
          Lsusb after the flashing and while the script waits for adb to come back up
          Bus 002 Device 018: ID 05c6:901d Qualcomm, Inc.
          dmesg output for fastboot mode:
          [755391.801828] usb 2-1: new SuperSpeed Gen 1 USB device number 17 using xhci_hcd
          [755391.823072] usb 2-1: New USB device found, idVendor=18d1, idProduct=d00d, bcdDevice= 1.00
          [755391.823082] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [755391.823087] usb 2-1: Product: Android
          [755391.823092] usb 2-1: Manufacturer: Google
          [755391.823096] usb 2-1: SerialNumber: 9ce13470
          dmesg for after fastboot, while waiting for adb to become available:
          [755509.829081] usb 2-1: new SuperSpeed Gen 1 USB device number 18 using xhci_hcd
          [755509.856499] usb 2-1: New USB device found, idVendor=05c6, idProduct=901d, bcdDevice= 0.00
          [755509.856508] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [755509.856513] usb 2-1: Product: QUSB_BULK_SN:A07D5C7A
          [755509.856517] usb 2-1: Manufacturer: Qualcomm CDMA Technologies MSM
          [755509.856520] usb 2-1: SerialNumber: 9ce13470
            tom admin
            @m1baldwin I would double check that your SW2 switch is OFF. If it is, it seems as though your VOXL2 may be in a bricked state and can be recovered via. QDL: https://docs.modalai.com/voxl2-qdl/
            Dmytro StolbovyiD 1 Reply Last reply Reply Quote 0
            • M
              m1baldwin
              Yes, SW2 is in "off" state, so looks like voxl 2 is bricked. I'll try out the qdl instructions and come back with updates.
              • M
                m1baldwin
                @tom That qdl reset did the trick, thanks!
                • Dmytro StolbovyiD
                  Dmytro Stolbovyi @tom
                  @tom Hello. Could you please update this link as it doesn't work. I met with the same situation and need you assistance to recover voxl2
                    tom admin @Dmytro Stolbovyi
                    @Dmytro-Stolbovyi Here is the updated link: https://docs.modalai.com/voxl2-unbricking/
