    Which FLIR Lepton breakout board
    • H
      hmlow
      Hi devs
      I understand from the docs that in SDK 0.9, the voxl-lepton-server (if using SPI) and voxl-uvc-server (if using USB) both provides the means to stream video from the lepton to MPA and subsequently to be used by voxl-streamer for RTSP.
      For SPI-
      May i know if this breakout board would work (or alternatively, which one did you guys test with?):
      https://store.groupgets.com/products/purethermal-breakout-board
      The SPI interface to be used on the VOXL2 should be the J10 (SPI bus 14), right?
      For USB-
      Would this work? (https://store.groupgets.com/products/purethermal-mini-pro-jst-sr)
      Does it work on the J12 of the 5G modem addon board?
      • VinnyV
        Vinny ModalAI Team @hmlow
        Hi @hmlow
        I'll let the SW team speak for how to use the Lepton, but yes, we have been evaluating the SPI unit from the Pure Thermal link you posted (1st one, I didn't even notice there was a USB one, that might be an easy one to try out).
        So, regarding SPI, there are a few notes/caveats about that interface.
        J10 has no INTERRUPT input and no I2C bus on it, so you can configure the Voxl2 to receive data in polling mode, but you cannot reconfigure the default settings of the Lepton (an I2C bus is needed).
        Because of that, we are in process of validating a new plug-in board that has a SPI + I2C port specifically tailored around Lepton that also has a dedicated INT input so polling would not be needed anymore and you could reconfigure it over I2C. I am not sure when we will have that product ready, probably a couple more months. However, if you already have some of our plug-in boards, you can possibly make it work better than J10 in the meantime.
        One final note, the PureThermal solution is on the edge of electrical performance for the I/O interface since it operates at 2.8V, whereas all Voxl2 JST's are 3.3V, so be sure you have a very clean cable solution and try to keep it short or noise can impact that interface and hurt the existing small noise margin (it still "passes" electrical analysis in both directions, but with very little margin).
        Our cable tech docs page will have an update soon showing the cable we are making for the PureThermal product. Clever eyes can see it listed in the file linked here as MCBL-00070:
        https://docs.modalai.com/cable-userguides/#comprehensive-modalai-cable-spreadsheet-and-examples
        Hope this helped.
        H 1 Reply Last reply Reply Quote 0
        • Chad SweetC
          Chad Sweet ModalAI Team
          Regarding USB, the docs call out "PureThermal Mini Pro" which does look like what is found here
          • H
            hmlow @Vinny
            @Vinny said in Which FLIR Lepton breakout board:
            Hi @hmlow
            Hope this helped.
            Great explanation.
            Thanks and i'll look into it
            • H
              hmlow @Chad Sweet
              @Chad-Sweet said in Which FLIR Lepton breakout board:
              Thanks! But are you able to advise which of the many USB interfaces on the VOXL2 would the purethermal mini pro (as a UVC camera source) work on?
              • Chad SweetC
                Sorry, J12 on the 5G (M0090) add-on should work fine. Any host port from a VOXL 2 add-on should work.
                • H
                  hmlow @Chad Sweet
                  ok thanks
