    Considering purchasing 12x Doodle Labs radios + Sentinel 2's : possible swarm configuration? Please confirm.
    • Slade VillenaS
      Slade Villena
      Hi. We were considering purchasing 12x Sentinels, but were also considering the Doodle Labs radio instead of the Microhards
      https://www.modalai.com/products/mini-oem-smart-radio?variant=40946775621683
      Would the Doodle Labs radio be compatible with the Sentinel? Also, do we have to install + solder the Doodle Labs radios ourselves? (Or do you provide this as a service?)
      For a swarm configuration, would we need
      1x Stand Alone Doodle Labs Radio for our ground station
      12x Add-On Doodle Labs Radio, each mounted on a Sentinel.
      Is the above the proper configuration? Would we need extra dongles / add-on boards purchased to have the radios mounted? (ie, like the Microhard dongles/add-ons etc).
      Would like this confirmed, since we are now writing out a bill-of-materials, and will be making a purchase soon.
      VinnyV 1 Reply Last reply Reply Quote 1
      • VinnyV
        Vinny ModalAI Team @Slade Villena
        Hi @Slade-Villena
        Both radios are interfaced to Voxl2 over USB.
        For Microhard, we have a more tightly integrated HW solution with our direct plug-in modules (and standalone too, 2nd link)
        https://www.modalai.com/products/voxl-microhard-modem-usb-hub
        https://www.modalai.com/products/mh-sa
        For Doodle Labs, it requires a different plug-in board, such as our M0090 5G modem board (without a modem) to expose the USB host ports to connect to Doodle.
        https://www.modalai.com/products/m0090?variant=40594936463411
        When we sell a Doodle radio, we include a cable that plugs into our 4-pin USB port.
        https://docs.modalai.com/cable-datasheets/#mcbl-00068
        Note: The 4-pin USB cable can plug into the Microhard Radio board, but that design only supports USB2 spec 500mA (not enough to power a Doodle radio). Only our newer plug-in boards (such as the M0090 for Voxl2) can support up to 5W on VBUS.
        Hope that helps you decide, and if you need further info, please reach out!
        Slade VillenaS 1 Reply Last reply Reply Quote 0
        • Slade VillenaS
          Slade Villena @Vinny
          @Vinny thanks for this info, it looks like our group will go with a Doodle Labs configuration.
          I do have some further questions.
          1. Is it possible to order a complete Sentinel kit + the M0090 5G board + a Doodle Labs air-radio, all pre-installed (or pre-soldered? does this require soldering?) by Modal AI? Was hoping this was a service you all could provide.
          2. For the Doodle Labs ground-radio, do we require any other add-on boards to connect to a Laptop USB? How about connecting to an Android USB-C port? Curious how that configuration would go.
          We're definitely prepared to order, just want to confirm these two pieces of critical info above, before we place the order.
          • Chad SweetC
            Chad Sweet ModalAI Team
            Soldering is not required, though there is no direct mount. The Doodle radio connects to the Sentinel via USB. You will need to design a mount for the Sentinel to hold the radio
            The standalone kit is intended to plug into the laptop
            Please note, the Doodle radios have a 4 week lead time and each drone is built to order
            The Sentinel is a development platform for open, UAS software development.
            • Slade VillenaS
              Slade Villena @Chad Sweet
              @Chad-Sweet thanks for that.
              We'll be placing an order soon!
